Question about Dell Dimension 8400 PC Desktop
Cannot print I have a Dell Dimension 8400 with 1 gb memory & running XP. I installed a HP Officejet J6450 and was not able to print emails, web pages or MS 2003 Office Professional documents such as Excel, etc. After jumping thru the hoops with HP trying a number of their suggestions I gave up & bought a Epson Workforce 500. I am having the same issues - no comm with the printer or only partial prints. Now I am thinking that perhaps the new all-in-one printers are no longer compatible with my Dell PC or vice-versa. Any ideas?? Thanks - Rex
  • 1 more comment
  • crtrent5 Jan 24, 2009
    Let me add that I have returned the HP printers (I had tried 2 different models) and have since purchased an Epson WorkForce 500. I am getting the same results. I have upgraded the Bios and installed a new USB 2.0 PCI card. I have also tried 3 different USB cables. So far, no joy. According to the specs for my PC I am also running a 350 Watt power supply. The OS is XP Pro with SP2. Being a mainframe software engineer this is a bit humbling.
  • Mike Gleim
    Mike Gleim May 11, 2010
    Did you try checking the installed printer ports that I mentioned earlier? I'm a systems administrator and was surprised to learn once upon a time that that LPT1 port wasn't showig?
  • Mike Gleim
    Right-click your My computer icon and choose properties, click the Hardware tab and then Device Manager, expand "Ports (Com & LPT)". What is listed underneath? We're looking for something like ECP Printer Port (LPT1). Seeing the (LPT1) is critical here. Let me know what you see.
    Problem Solver:
  • 10 Answers
Hi what my have happened is go to
START > PRINTERS > and make sure that your printer is the default printer and not onenote
Posted on Jan 23, 2009
Reinstalled Windows XP on a Dell Dimension 8400 and The local area connection is not detected. Cannot seem to find drivers through Dell support
Dell Dimension 8400 PC"s use either Broadcom Extreme Ethernet controllers OR, on SOME models of the 8400 that do NOT have ON-board Ethernet connections, SMC Networks Ethernet Drivers. I've seen MANY a Dell Dimension.
Sep 11, 2013 | Dell Dimension 8400 PC Desktop
Set up cd rom dell dimension 8400
Hello Download drivers here at dell:
http://www.dell.com/support/drivers/us/en/19/Product/dimension-8400
The drivers can be downloaded one by one.
You maybe need to unzip the file before you install.
Here is only drivers for win xp.
You can`t download a setup disk but you can call dell support
to order the software from them (if they still have it) by the service tag.
Good luck
Dec 02, 2012 | Dell Dimension 8400 PC Desktop
Pci device driver
Hello Download here at dell:
Download and install the chipsetdriver.
Good luck
Sep 28, 2012 | Dell Dimension 8400 PC Desktop
Dimension 8400 locks up. Keyboard won't respond.
Generally and indication of a software issue that is locking the system. There can be hardware causes too.
  1. Run diags on the system (From Resource CD or F12 menu) see if any failure. If you have a hardware failure then address it and see if the problem is solved.
  2. Update bios and drivers from support.dell.com
  3. Edit MSCONFIG, startup group, remove entries that are not required (Generally only AV and printer scanner items are needed here, most other items will function without and item here)
  4. Edit the Virtual Memory settings, and set it to Custom and an amount double the RAM (EG: 4 GB RAM set initial and Mas to 8200 MB VRAM)
Apr 04, 2010 | Dell Dimension 8400 PC Desktop
J6450 Prints multiple copies
After spending a lot of time on the net looking for an answer I decided to spend some time to see what was different betweent the computers. It turns out that the 2 computers that I was having the problem on had Zone Alarm installed and the 3rd computer that it was working on did not. So I dug around in Zone Alarm and marked every HP software item as allowed. I then rebooted the computer and submitted a test page to the printer. Low and behold 1 copy as I wanted. I proceeded to test it some more and now am only getting one copy when I ask for one. The problem appears to be that Zone Alarm was messing it up. I still have Zone Alarm running, I just needed to mark HP as an accepted program under every listing in Zone Alarm.
Jun 20, 2009 | HP Officejet 6310 All-In-One InkJet...
My dell dimension 8400 bios a03 fails to bootup and displays this alert on the screen: Many attempts to boot the system have failed at checkpoint [Ithr]. how can i recover from this?
You need to reset your bios settings. Open your case and remove the cmos battery for 10 minutes. Caution: unplug all ac plugs before you open your case. put the battery back in and turn it on you should see an error message saying: you need to set system time and date. If you see this then you have successfully reset your bios settings and the defaults should load up. follow the instructions to change your time and date settings and save. reboot and hopefully you can boot up. I hope this works.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Can Dell Dimension 8400 intel celeron work with 3 gig ram
Yes it can but try to match up at least two, to gain the advantage of dual channel and when you buy your extra ram, check that it matches the other two that you have in size, speed and technology (like 3x1G DDR2 same speed). Also you may have to play with which slot to put the third one but I had this one run with three modules before yes.
Otherwise your Dell Dimension 8400 can see upto a maximum of 4.0 GB memory, with maximum of 1GB per slot in 4 (2 banks of 2) memory slots.
Feb 14, 2009 | Dell Dimension 8200 PC Desktop
Dell 8400 new memory
If you are using Windows XP, go into your control panel, double click System (from classic view), and look towards the bottom where it says "Processor x.xx GHz, x.xx GB of RAM" and make sure your 2.00 GB of RAM is recognized by Windows. Next I would make sure you are using 400- or 533-MHz DDR2 unbuffered SDRAM. If you are, try removing one of the two modules and see if the computer runs smoothly. If it does, I would install a different brand of memory.
Dec 31, 2008 | Dell Dimension 8400 PC Desktop
Dell 922 aio printer
it's unusual to have same problem if completely uninstalled printer(removing printer, then uninstalling,after which use printer installation cd then re connect printer when prompted). If you have a spare usb port install software then connect printer to a different usb port. Lastly try; go to printers and faxes folder>right click on printer icon>properties>advanced, then click the radio button 'Print Directly to the Printer' and see if it prints. Also make sure this printer is set to default printer Try an updated driver, if any,from the Lexmark web site, as they are the same printer without the Dell logo. Your rating is appreciated.
Nov 13, 2006 | Dell 922 All-In-One InkJet Printer
Dell Dimension 8400 PC Desktop Logo
97 people viewed this question
Alun Cox
