Bush A126QB drum won't spin
I bought a Bush A126QB Washing Machine from Argos and it was delivered the other day, I took out the packaging bolts and it says on the piece of paper that once I take out the rubber bits a plastic white part will lower so to tilt to the right (or forward according to the other piece of paper) to retrieve said part, I tilted all directions and could not understand which part, so plugged it in anyways and the drum wouldn't spin, so I unplugged it and everything and had a good look. The only things I can see that look like it would come out is four white plastic things covered in grease at the top and bottom of the two piston/armllooking things but I'm quite confused so can someone help please?
3 Suggested Answers
SOURCE: machine will not drain and spin
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/4681EA2001D/New.aspx?ModelMfgName=LG+Electronics+Incorporated&ModelBrandName=LG+Electronics%2fZenith&ModelNumber=WM3431HW
you need a new one of these. i took mine COMPLETELY apart and found the impeller jammed. the impeller is a magnet in a sealed plastic carrier with an electro magnet around it. the electro magnet energizes , the two opposing fields spin the inner magnet ( just like a fish tank filter good idea actually!) the inner magnet on mine had a slight crack from factory causing vibration and allowing debris past the seal then jamming the impeller. to check yours drain it with the small drain tube, then get a towel or two and place around the unit at the floor.pull the large black drain cover off and after the gushing tidal wave look inside. you will see the white impeller. try turning it with w screw driver , pen or whatever. you may be able to remove and then clean / reassemble and be good as new. i only needed two tools to tear the machine apart. a Phillips screwdriver and pliers to get the clamps on the pump (2) and the clamp back on the door to drum gasket.
Posted on Apr 25, 2009
defadad
  • 351 Answers
SOURCE: performa washing machine not spinning
you will most probably find that the inside of the belt that runs on the pulley has been breaking away bit by bit and if the pulley stops where there is a bit missing it may not turn when the pulley starts to turn.
Just a thought as it has happened to me a few times
The odor is most probably burning rubber as the pulley spins on the belt
Posted on May 27, 2009
The start button and start light are flashing and it won't drain the water out on a bush a126qb machine can anyone help
Review page 12 (trouble code)s in your users manual. It may be your door is not closed properly. Follow the instructions in your users manual. If you lost it, you can find it online athttp://argos.scene7.com/is/content/Argos/4780948_R_D001pdf
Jun 19, 2015 | Washing Machines
Hi 2 years ago I bought a BUSH washing machine model A1249RLB after having the machine for about 6 months the counter balance weight came off in the middle of a cycle destroying the machine I contacted...
my advice is simple if your disabled like me they contact your local reclimation yard center,,,, there are many across europe they will take your old machine away and provide you with a front loader machine refurbished i can help you via a local charity who will help too get it fitted email me at vsmlibs@talktalk.net i can help you source a machine locally for free exchange ...
this isnt good enough im sorry youve had to ask for help here!!
Mar 05, 2015 | Washing Machines
My bush washing keeps making my fuse box trip
when I put my machine on to do a washing it blows my fuse box 8 mins into every washing cycle I select, It spins ,drains and rinses ok .So what can it be???????
Jan 22, 2013 | Washing Machines
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Samsung Washing Machines
Hi, I own a Whirlpool Thin Twin Model# LT5000XSN1. I bought it used from a CRAPPY dealer (worst mistake EVER), since day one, we have had an issue with the spin cycle. The cycle will agitate then when the...
This sounds like a classic clogged empty pump issue. The empty cycle is timed and then it steps on to the spin cycle. The machine won't spin if there is still water in the bottom of the drum. When you reset it to a spin cycle again, you are making it run through the empty cycle again, finally getting rid of the water that the clogged filter could not evacuate on the first attempt.
You need to clean the empty pump filter. Now... Where is the filter???? Hmmmm... not sure. It MAY be behind a little panel in the front of the machine near the bottom. I can't find a picture of the machine on the net so I'm not sure.
Clean the filter, I'll bet your problem goes away. You have to wonder why the idiot who sold the machine to you hasn't suggested this!
Jun 21, 2011 | Washing Machines
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
