Question about E-Machines eMachines Desktop PC
No signal to monitor
Colors changed, then monitor went black says no signal now. switch light on computer is on - fans too. e-machine
  • E-Machines Master
  • 27,725 Answers
Or you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Posted on Jan 06, 2013
  • E-Machines Master
  • 7,627 Answers
Check ALL cables, connections, try another monitor/cable. You didn't provide the Model of eMachine? Does it have a PCI Graphics Card? Reseat Card.
4 Suggested Answers
CRDSoftware
  • 66 Answers
SOURCE: w3107 no signal from computer to monitor
check the requirements of your game who you played maybe your VGA card cannot support the requirements of the game. and also check the resolution maybe it cannot support.
Posted on Jan 07, 2009
kamal1984
  • 1383 Answers
SOURCE: Fans work but pc wont power up
refix ram and reattch all connection to mother bord.
ASlo remove cmos cell for 15 minutes from mother bord
also check smps is working fine
Posted on Apr 21, 2009
  • 10 Answers
SOURCE: My dads e-machine 3630 is only a year old and has
Are you sure it was the fan? Was there any type of clicking noise present? If so it points to your HDD... Also check to see if your video card is fully seated in its slot.
Posted on Dec 08, 2009
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
The monitor itself is black, and the power light is changing color from green to yellow to orange and flickering.
Hi there!
Changing the monitor light from green to yellow/orange/amber means that the monitor is in power saving mode. Make sure that the video signal cable is properly connected to the back of the monitor as well as to the computer.
Hope this helps.
Apr 23, 2011 | Acer H233H bmid Monitor
Monitor was in standby mode, computer was on. Now it shows no signal and when we try using the menu button (2) it flashes white, black, red, green, blue then a teal color.
the monitor is not receiving a signal from the computer which is why the multi coloured bars are showing. Ensure the lead is connected and is connected to the correct port of your computer. If it is connected correctly then either your graphics card is faulty or the lead, or monitor is
Apr 03, 2011 | Computers & Internet
I was playing solitaire on our home PC and the power went off and the screen went black. Before it went black it said "no input signal go to power save" Everytime I try to turn the computer on...
It means that your monitor is not getting a signal from your PC. Your monitor is fine though. You will need to plug the video cable from your monitor into the onboard video if you are using a graphics card. If you are not using a graphics card then you will probebly need to get a PC technition to diagnose the problem with your motherboard.
Feb 21, 2011 | Vision Computer (2U-A2200K) (2UA2200K)...
Colors mix
there is a problem in signal cable bend it if change in color is seen then replace the cable problem will be solved
Feb 26, 2010 | CTX S965A (Black) (Black, Silver) 19" LCD...
Monitor screen begins as computer is booting up and then screen goes black. Message says there is no signal.
If the power light dims or changes color after the no signal message comes up, that means the monitor went to sleep.
While the monitor is plugged in and on and the computer is also on, Try unplugging the VGA cable from the monitor. wait 30 seconds and then plug it back in o see if the power button light comes back to normal color and the screen flashes on.
If not, then the monitor is not getting a signal from the computer.
If using a desktop computer,Try a different cord or try the monitor on another computer.
If using a laptop, you need to activate the laptop to use an external monitor. That can be done through the display settings, OR, most laptops have a shortcut key feature which usually involves pushing the Fn key and one of the F keys at the same time. The F key may say CRT/lcd or have a picture of a monitor and a screen.
If the power light does light back up and still no picture, There may be an internal issue on the monitor
Nov 17, 2009 | ViewSonic VG2230WM LCD Monitor
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
W3107 no signal from computer to monitor
Jan 07, 2009 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
