Question about Symantec Norton GoBack 4.0 for PC
I want windows to take over restore points instead of this norton goback 4.0
This program was already installed when i got my gateway pc running windows xp home edition and has been updated often thru windows update- now with sp3 - i believe this norotn goback 4.0 is slowing certain features and is a resource hog- so i want to remove it without reformatting if possible and without damage to my system so that windows can start take over the restore point function as it normally would if norton goback 4.0 was not installed- but dont know really where to start- afraid if i uninstall it will still leave pieces of itself behind although i have not had any problems except slow performance and it is out dated and just not a fan of norotn foback 4.0 after researching it-so is this just going to be as simple as uninstall thru add and remove programs???? lol
    President:
  • 623 Answers
I totally agree with you. Although Norton makes great products, they are system hogs (I once brought a system to a screeching halt installing Norton AV ;-)
Yes - you can easily uninstall the program and Windows will take over the handling of restore points again.
I would suggest you use a program like revouninstaller (you can find it here.) The free version is perfectly fine - you don't need all the bells and whistles of the Pro version.
The reason is that revo also looks for leftover files in the Registry and Program Files folder and removes unnecessary files usually "forgotten" by the program's uninstaller. The way it works is:
1: It opens the uninstaller of the program.
2: It looks for leftovers and cleans them.
The trick is to NOT reboot the computer when the uninstaller asks for it, but letting revo run and do it's job. Revo has multiple stages of cleaning, but "Moderate" is usually fine.
If you really want to clean your Registry - and I strongly advise you NOT to do that manually! - use ccleaner (also free and you can get it here) and clean your hard drive and the Registry with it. You will be amazed how much old stuff it will find that was never cleaned out. (Use the program function to save a copy of your registry just in case.)
Just let me know if you have any questions - I'm happy to help.
Posted on Jan 06, 2013
  • Symantec Master
  • 27,725 Answers
Norton will slow your computer up.
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here.
Hope this helps and you are finally rid of norton.
If you need more help with this post a reply.
SOURCE: trying to reinstall norton ghost v14
I have the same problem with you. Lukily enough I found the solution from this website.
http://www.techspot.com/vb/topic107021.html
However, I didn't uninstall the NOD32 in my PC prior to double click the Norton Removal Tool.
It seems to work fine anyway. As soon as the NRT finishes its task which takes only a few minutes,
I reintall the Norton Ghost 14 and it works without any problem.
Good luck.
Chaiwat
Posted on Jan 22, 2009
leecom72
  • 4806 Answers
SOURCE: Norton Internet Security 2009 Causes Blue Screen of Death.
Hi there
Thats Norton for you! this is a very heavy and memory hungry program, it takes control of your computer and if you have not got enough system or virtual memory it will cause the pc all kinds of problems. To fix this either upgrade the system memory or don't use Norton, use AVG free instead, its a lighter program and lets you have some speed back over the internet.
good luck and thanks for using Fixya!!
Posted on Feb 11, 2009
Bheshaj
  • 163 Answers
SOURCE: trying to remove norton Ghost
yes it is available download the latest version of norton removal........
if the problem is same then download the perfect uninstaller ......it uninstall that software perfectly........
Posted on Jul 18, 2009
alexpawwath
  • 64 Answers
SOURCE: i installed norton 360 v2, but it did'n't fully
you can download Norton removal tool from this link www.norton.com/nrt
or go to www.symantec.com/autotools and download first tool
Posted on Jul 29, 2010
  • 111 Answers
SOURCE: Here is my problem they tell me I need an
Professionally, I use Microsoft Security Essentials. You can download it here: http://www.microsoft.com/security_essentials/
Please rank me.
Posted on Mar 04, 2011
Testimonial: "This was a good response however I have found mcafee to be stronger and more secure so I stick with it thank you for your time I will keep searching"
Gateway desktop critical error code
Which operating system ???
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Jul 02, 2013 | Computers & Internet
My gateway dv4200 09 power plan settings are not working properly
May 20, 2013 | Gateway Computers & Internet
I restored my PC to previous system restore point and Norton 360 dissapear. I cannot find the CD to install it again where I can download the installation. I dont want trial version
download the latest version of Norton 360 from the link www.norton.com/n360s_5
Follow the simple installation steps to install the latest version of the Norton program.
Regards,
Muhaim
Jun 11, 2011 | Symantec Norton 360 for PC (037648318846)
Windows 7 Security Essentials and Norton Internet Security 2010
Its not necesarry that you need to download and install this software as you already have Norton on your notebook. Moreover, performance of the notebook may degraded if you have more than one security programs installed on the notebook.
May 23, 2010 | Computers & Internet
My computer keeps showing a code 19 everytime i tried to install a driver for my cd drive hl-dt-st dvdram gsa-t20n ata device. i recently installed norton and since then i cant load or run any cd's
before you do all this i suggest you try going to start and running system restore under start programs accessiories system tools - system restore and restore to a previous point when you were not having these problems... if that don't work try the next best thing
First uninstall Norton from your add remove programs in your controlpannel
Download the norton removal tool from there site
Here Run the uninstall tool.. then uninstall any drivers that you have for your cd drive then try reinstalling the cd driver once you have everything working reinstall norton
Dec 08, 2009 | Acer Aspire 5315 Notebook
The speed of my computer
What antivirus did you install? If it was Norton, then ... well, you see the result. When Norton was "Norton" their tools were excellent, but ever since they were bought by Symantec, the quality has nosedived. Norton security suite is reputed as being a performance killer.
I'd recommend resetting your computer to a restore point prior to the time you installed the antivirus. Uninstall routines are not particularly effective in many (if not most) cases.
1.Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2. On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3. On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
4. On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5. Click Next if you are ready to proceed or click Back to change the restore point.
6. The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
Mar 04, 2009 | HP Computers & Internet
Norton not loaded purchased from internet, did not get email with produt key, i'm 79 and mest it all up, please help me. mr james monksfild, email pelican12@talktalk.com. thank you.
ø First of All Shut Down your Computer.
ø Restart Computer and Keep Tapping F8.
ø Choose Safe mode with Networking and Press Enter. (Win XP or 2000).
ø Run Windows in Safe Mode Click Yes.
ø Restoring Windows to a previous point
ø Click Start, Programs or All Programs, Accessories, System Tools, and then System Restore. The Welcome to System Restore window opens.
ø Select restore my computer to an earlier time, and click Next. The Select a Restore Point window opens.
ø Select a bolded date and a restore point, and then click next
ø (Note: - You need to choose a Date before the installation of Norton)
ø Click OK if a pop-up window about closing programs appears. The Confirm Restore Point Selection window opens.
ø Click Next. The computer should shut down and turn back on automatically after the restoration completes. The Restoration Complete window appears.
ø Click OK. The computer has now been restored to a previous time when it worked correctly.
ø (Note: - If an error message appears saying that the computer cannot be restored to the point you selected, try a different restore point)
After the System Restore is complete, and the computer starts successfully, update the computer software as follows: - 1). Update the system virus definitions. 2).Get the latest critical system updates using Microsoft's Windows update.
Once all this is Done you Need to Download and Install Norton Again.
Jul 04, 2008 | Computers & Internet
Getting Around Norton GoBack
try going to dafe mode if that does not work then do a system restore from dos this should fix the problem..
system restore will uninstall the norton and your files will be safe
you can also visit
http://support.microsoft.com/kb/q279736/
thanks
Jun 04, 2008 | HP Compaq dc5100 PC Desktop
Symantec Norton GoBack 4.0 for PC Logo
47 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
