Question about Estate Washing Machines
Estate washer shakeing after couplor replaced
Woke up went downstairs to wet cloths did not know why assumed it did not spin tried it again it would not spin.took it apart to see whats wrong temporarly fixed the switch to go forward to see if it was the motor it was not fixed the coupler kit because the gears were stripped on those. now if cloths are put in there it shakes horribly without cloths it spend and drains fine? can you give me any ideas is it the metal bar to the gear or switch or ....its completly apart im a woman and i just racked my brain to death
My washer tangles up my clothes. I swear someone goes downstairs and ties the clothes up. They are always a tangled mess thats hard to pull apart when they are wet! Help!!!
Make sure you are not over filling the washer, when my mother in-law does the laundry, it ends in a tangled mess. However when I wash them, no problem I shake the clothes out before I put them in and I try not to overload the washer.
Feb 27, 2011 | Hotpoint VBSR3100GWW Top Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Does not spin all water out, towels are still wet, not overloading, could it be the timer?
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 01, 2010 | Estate ETW4400VQ Top Load Washer
Washing machine spin problem!!!!!
whirlpool estate washer is dun the clothes are ring Wet
Jan 13, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Spin problems
f11cf48.jpgYour coupling has broken most likely. Here are some pics and directions amigo: WISDOM
Dec 14, 2008 | Estate TAWS800JQ Top Load Washer
Spin=wet drippy clothes
if it shakes so hard it makes me wonder if one of the dampners is lose. If yo haven't moved it and it normally worked ok than that will be the thing. It leaves it wet because the machine cant get to the high rpm's because of imbalance
Apr 11, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge washers are horrible
Mar 20, 2008 | Estate TAWX700JQ Top Load Washer
Kenmore washer shakes violently during spin cycle
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
