Question about Janome Sewing Machines
Janome PowerStitch 1030 not stitching.
I've cleaned the feed dog, checked the needle, it's making a rattling noise but not making stitches.
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
  • 26 Answers
SOURCE: My Kenmore machine sews a straight stitch fine for
timing issue, needs to be serviced and re timed.
Posted on Aug 22, 2009
  • 1788 Answers
SOURCE: When i start to sew
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Posted on Sep 25, 2010
  • 84 Answers
SOURCE: There is a loud squeaky
Is the darning foot aftermarket or genuine darning foot for your particular model...If it is aftermarket, it may not be the correct length. What is you model?
Posted on Jul 23, 2011
Singer sewing machine 1030 feed dog will not pull material in
try using maximum stitch length, if still not working try removing needle plate and clean you teeth
Feb 18, 2014 | Sewing Machines
New home Janome 2039 sewing machine
if these suggestions don't help then the machine needs to be
checked for a timing problem
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 29, 2013 | Janome Harmony 2039 Mechanical Sewing...
My bernina 1030 won't feed material
Make sure the feed dogs are in the raised position and that the presser foot has been lowered before beginning to stitch.
Feb 11, 2013 | Sewing Machines
My new janome 2212 isn't feeding my fabric
ok. Never pull fabric, it will bend the needle and cause you even more problem. So stop doing that.
Look in your manual for where the feed dog switch is. It might be under the "darning" area.
Good luck
Oct 02, 2012 | Janome 2212 Sewing Machine
How do I get the teeth to grab and advance the material on my very old Bernina 830?
Well there's a number of reasons why it may not be advancing the material. First, ensure that the teeth are completely cleaned-out - get an old toothbrush, or similar with firm filaments and, with the stitch-plate removed and the bobbin door open, give the teeth a really firm clean across the teeth to remove anything in between ... this is especially important if you've been sewing with metallised fabric or thread. If the teeth are nice and clean, check if they are still pyramidal with a reasonably 'sharp' point facing backwards - if the machine is very old and very well used, the teeth might be rather rounded and it may be time that you have a new feed dog fitted ... some of the old machines are difficult to obtain spares, but they're mostly still out there. Most commonly, check how far the teeth of the feed dogs protrude above the stitch plate ... this is a bit difficult to do and should really be done with a proper gauge, but generally they should protrude 1mm above the stitch plate - less than that and you wont get the material to move properly, especially if its fine material. Lastly, it could be the foot pressure that's the problem ... if there's inadequate foot pressure, the material will not be pushed adequately onto the dogs. Again, unfortunately, you really need a proper gauge to set the foot pressure, but if the dogs are clean, in reasonable condition and have 1mm of clearance above the stitch plate, you can try increasing the foot pressure a bit. This is done by opening the top cover and you will see a large-ish flat-blade screw in a threaded tube just behind where the needle bar goes up and down and to the left of the takeup arm. If the screw is rather near the top of the threaded tube, you can try screwing it down (clockwise) maybe 2-3 turns to see if it makes a difference ... of not, dont be tempted to just keep screwing up the pressure ... there's something else wrong. Oh .... and by the way .... before you've done any of the above, I assume you've checked that the feed-dogs are not dropped ! You can drop the feed-dogs to do embroidery etc on the 830 - there's a small round knob below the stitch length control - make sure its turned to the position that shows a tooth pattern and not the cross-hathced pattern and make sure the feed dogs do actually come above the stitch plate when turning the handwheel - if they dont, or moving the feed-dog drop control doesn't make any difference, then the link mechanism is almost certainly jammed (really, really common on old machines that haven't been regularly maintained!). To free that off, you need to remove the free-arm cover and look to the front right side of the mechanics - you'll see a linkage that should turn when you rotate the feed-dog drop control - if this doesn't separate or is permanently separated, whatever you do with the control, you need to give it a drop or two of Bernina sewing oil and gently help it move - once free, that should solve the problem. I cant think of any other reasons !!
Hope that helps !
Nov 16, 2011 | Bernina Sewing Machines
New home 535 machine. I've checked the threading, removed any lint or fluff, adjusted the tension and changed the needle. It makes holes but not stitches or gets knotted up and unthreads itself.
check to see if the thread has come off the thread take up lever
check in the needle plate to see if the feed dogs are up or down, if they are down then the knob or switch need to be changed to the up position
if the feed dogs are up then it's possible that they need to be checked
because the feed dogs are what moves the fabric against the presser foot as the machine sews
make sure to have 3 to 6 inch thread tail on top thread & bobbin & pull the thread behind the needle before starting to sew that way the needle does not become unthreaded
and make sure the presser foot in the up position when thread
if none of these suggesions help then it's possible that the machine could be out of time & would have to be serviced by a sewing machine repair tech that has the tools to check the machine
Sep 05, 2011 | New Home Sewing Machines
My Janome Harmony 1017 won't sew all the zigzag stitches. Stitches 5,7 and 8 bog down after just two or three stitches because the fabric isn't moving through the machine. Any suggestions?
when the fabric does not move then the feed dogs under the needle plate need to be checked to see if there up or down.
if the feed dogs are down then the lever or switch needs to be pushed up into the correct position
if the feed dogs are up & they are not moving the fabric like there suppose to, cause it's there job to move the fabric against the presser foot,, then they need to be check
the gears that do the zig zag stitches should be checked to make sure there not worn & weather they might need be be greased
Aug 29, 2011 | Janome Harmony 1017 Sewing Machine
Janome jd 1822 when i'm doing zig zag, the thread is missing stitches and also my threads keep breaking
rethread the machine getting every thread guide
check the thread tension 3 or 4 is usually good
Change needle--make sure the flat side is toward the back of the machine & that it's insert as high as it will go--make sure the needle bar is raised to it's highest position
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin that the bobbin is wound correctly & put into the bobbin case or shuttle correctly
here a tip about needle & thread compatability
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 24, 2010 | Janome Sewing Machines
Everything was fine and then there was a noise and the thread got all bunched up underneath. I oiled it and it happened again.
change the needle
clean under the needle plate where the feed dogs are for lint
clean in the bobbin area for lint & loose threads
check to make sure the bobbin is wound correctly & is inserted correctly
make sure to put the thread thru every thread guide
Nov 18, 2010 | Janome Memory Craft 3000
Sewing Machines Logo
20 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
