Question about Toshiba Satellite L500 Series Notebook
An addition to original question re: toshiba
Hello, initial query was that laptop was turning itself off via power but this morning 6.1.2013 it shuts down opened page to what appears like a very light sleep mode as i only have to move mouse to get page open again. this is not to say that things will stay like this. any & all help most welcome but please, not to technical as in that aspect i'm a 'computer pygmy' i wait for all wonderful minds to help solve my probs. lorraine.
  • 3 more comments
  • lorraine pieters Jan 08, 2013
    hi to all who have tried to help me with my problems.& many thanks. i'm going to send machine in under extended warranty for repair as this is driving me crazy. one thing i noticed today is that i was playing a game, paused it for over an hour & game stayed at site i left it. it didn't close down like every other time so this is just another aspect into the on going saga of 'the toshiba' that wouldn't play fair. will let you know the outcome when i get it back. thank you. lorraine.
  • joecoolvette
    joecoolvette Jan 08, 2013
    "The Toshiba that wouldn't play fair" "It's a rough, dirty laptop. Never knew it's mother or father. Growing up in the dingy black world of electronics, it saw no quarter; gave no quarter. Now you can see it here for the first time! Bu tickets now...................WAIT,................what? Would appreciate hearing back about the outcome, Lorraine. Regards, joecoolvette
  • lorraine pieters Jan 09, 2013
    joecoolvette you are either going to have a good laugh & find a corner. i've found the answer to my problem well rather someone else has provided it. i gave my query one last 'qoogle' & answer came uo on windows sevenforum site by DMHolt57 going back 2 yrs. someone had exactly the same problem. o.k. i'll put you & others out of your suspense. it was the settings for screensaver in personalization,blank screen screensaver active for 1MIN. & there in joe was the problem so mystery solved. to you & all others many thanks. until next problem, stay cool joe. reyne.
  • joecoolvette
    joecoolvette Jan 09, 2013
    UNREAL! Outsmarted by a screensaver setting! !O_O! Glad you found the problem Lorraine, and get 'er fixed! Later, joecoolvette
  • joecoolvette
    Got 'er fixed
  • Toshiba Master
  • 5,660 Answers
I looked through your two previous problem statements, Lorraine.
I noticed in the two previous statements, that you indicate the laptop is not overheating.
With all due respect may I ask how you know this?
http://www.fixya.com/support/t15669763-toshiba_turns_itself_off_not_over
This additional statement's problem heading, also contains Toshiba Satellite L500 series of Notebook PC's.
This is the example I will give repair information for.
If it is not the correct model series, please post back in a Comment.
The hardware components inside the laptop are cooled by air.
Air is drawn in from the Bottom of the laptop, and exhausted out the side.
Due to the close proximity of the air intake duct, on the bottom of the laptop to whatever object it is rested on; the cooling system for the laptop can 'inhale' a lot of 'Gunk' quite easily, and quite rapidly.
'Gunk' = Dust, dirt, lint, hair, carpet deodorizer, food crumbs,....you name it.
This foreign material can clog the cooling components, and drop the cooling capacity tremendously.
All it really takes is a fine layer of Gunk. Most of the time the cooling problem has gone way beyond that.
An example using a Dell XPS,
http://www.youtube.com/watch?v=AkAeE5I5E_A
At the first of the video you are greeted(?) with the thick layer of Gunk, that is over the fins of the Heatsink.
The cooling components for your laptop are;
1) Cooling Tube:
A copper tube slightly flattened, sealed on both ends, and filled with Nitrogen. There are also two small metal plates attached to the Cooling Tube.
One plate rests on the Processor; the other plate on the graphics chipset.
[The Processor and graphics chipset, are the two hardware components in a computer that give off the most heat ]
Heat is absorbed from the Processor, and graphics chipset, by their two respective metal plates.
The Cooling Tube absorbs heat from the two small metal plates, and transfers it to the Heatsink.
2) Heatsink:
Small thin piece of metal, that has Tall, Thin fins protruding from it.
The Heatsink absorbs the heat, then radiates it away with it's tall, thin fins.
(House radiator, and automobile radiator work on the same principle; except water is used for the transfer medium, instead of air)
3) Fan Assembly:
The exhaust of the Fan Assembly, blo-ws air through the fins of the Heatsink. The air flow helps carry heat away from the Heatsink.
This is a Bottom view of your motherboard, and a look at the cooling components mentioned above,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L505-L505D/big/remove-laptop-motherboard-23.jpg
The Cooling Tube is the copper colored curved tube. It has two metal plates on it. The one to the left with V-shaped clips on it, sits on the graphics chipset.
The small metal plate to the Right sits on the Processor.
Here's another look at the Bottom of the motherboard, with no hardware components installed, except the graphics chipset.
The pink rectangular object you see, with a multitude of holes in it, and a square hole in the middle; is the processor socket.
No Processor installed,
http://www.ebay.com/itm/Toshiba-Satellite-L500-L505-Intel-Motherboard-V000185030-TESTED-/320891315736?pt=Motherboards&hash=item4ab69ce618
To know for a fact that the inside of the laptop is not dirty, the laptop has to be opened up, (Partially disassembled), and checked.
Why would a dirty laptop shut down?
The Processor is overheating.
When a Processor overheats it turns off. (BIOS turns it off)
This is a fail safe feature built-in. Keeps the Processor from burning up.
Laptop IS clean inside?
It was taken to a pro, and cleaned?
Well the Ol' 'tech' may have forgotten something.
Replace the Thermal Paste, and Thermal Pad.
The top of a Processor, top of a graphics chipset, and the bottom of those two small metal plates on the Cooling Tube; are not perfectly smooth.
A magnified view would detail, 'Hills, Valley's and Pitholes'.
When the two parts are mated together; Processor and metal plate; graphics chipset and metal plate; there are air pockets created.
Air is an Insulator, not a Conductor; in this case.
Thermal Paste fills the above mentioned imperfections, and is an Excellent conductor of heat. Helps tremendously in transferring heat.
Due to age, and the constant heat inside the computer, (laptop or Desktop), the Thermal Paste breaks down.
Looses it's thermal conductivity properties.
The Thermal Pad works on the same principle as Thermal Paste. This is because it is a material impregnated with Thermal Paste.
You can see how it breaks down also.
Sometimes the Processor has just Thermal Paste, or may use a Thermal Pad. The graphics chipset most of the time uses a Thermal Pad.
[Examples of Thermal Paste, and Thermal Pad material. The pad size needed, is cut from the material with scissors,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3999975&CatId=503
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1333247&CatId=99
[NOTE* A Thermal Pad NEVER replaces a Heatsink. I think the heading is a typo. Should read "Thermal Pad replaces Thermal Paste."
This is erroneous too! lol! A Thermal Pad is junk, IMHO. Only use if I have to, which most times you do -> Graphics chipset ]
Nope?
Joecoolvette is full of beans, because you know the laptop is clean inside, and has had the Thermal Paste, and/or Thermal Pad replaced?
(Sheesh! I Thought I had it there! lol!)
Power Settings:
You can set the laptop to shut off at various designated times.
Has this been done to your knowledge?
Post back in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 06, 2013
  • lorraine pieters Jan 06, 2013
    joe, thanks for your interest. as for 'not overheating' i was only going by a program 'p.c. health monitor 'which shows me the level of temperature & fan speed' neither of which have gotten up to the 'red' area.maybe i'm putting to much faith in this app. i won't be opening laptop as it's still under wxtended warranty so don't want to mess that lot up. i wanted to try & sort this out without sending in for service. l
  • joecoolvette
    joecoolvette Jan 07, 2013
    Understandable, lol! (Extended warranty, huh? INTELLIGENT woman!) I would try what Max has laid out. (Another intelligent person) This is the Power settings I was referring to. Hate sending laptop in? Ya, I know. Sometimes takes forever, and you don't have the needed access to your laptop. However they BETTER make it good. In the US we can contact the State Attorney General's Office, of out state; and fill out a complaint form. I know the UK has an entity as such, and so does Australia. Want to see a computer manufacturer support company go through changes real fast? Up To a $10,000 a day fine. You'd be surprised in how fast they move, lol! (OK, my bad) Could be a REAL problem. May have to go as far as replacing the motherboard. Better to be on their dime, instead of yours. Regards, joecoolvette
  • Toshiba Master
  • 7,627 Answers
Open the Power settings in Control Panel, Change to High Performance, in Advanced Power settings, Change Sleep and Hibernate to Never, adjust your power settings to your preference. When your laptop is not in use shut down, unplug. Remove battery if you use on AC most of the time. This will protect your laptop from possible power surges and overheating, your laptop will reset with a reboot everyday.
    max, settings were on never as far as power. will remove battery & see how that goes. i do have a surge protector board for all power cords connected to laptop, thought that would be of a major protection. thanks max. lorraine
    max, i've just posted my latest finding for my problem, provided by another forum. have given details under 'joecoolvette' as he also has been helping me. max, thank you for all your time & assistance. next time max. reyne.
5 Suggested Answers
BladedDragon
  • 14 Answers
SOURCE: Laptop apprears to go into sleep mode while I'm using it
To my knowledge it could be hibernate mode for laptops to save battery life when not plugged into the wall, try pressing the power button, my Compaq did that too. Also don't hold down the power button as after 5 seconds it just shuts off the laptop, unless you wanna do that.
Posted on Jan 14, 2008
ruben_barrer
  • 117 Answers
SOURCE: Toshiba Laptop turns itself back on after being shut down
go to toshiba's website
www.toshiba.com select your proper device and go to support put in your model number there have been some bios updates to resolve this issue. load all bios updates and you should eliminate this known issue.
good luck!
Ruben
Posted on Jul 19, 2009
dDex
  • 145 Answers
SOURCE: Hello! Ive got Toshiba Qosmio X300-11W laptop the
Use the correct video driver. Maybe you installed the incorrect video dirver. try installing driver from cd.
Posted on Aug 13, 2009
Gort007
  • 1187 Answers
SOURCE: shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Posted on Nov 08, 2009
Initial setup on Bravia 26" won't come up
Try resetting the TV to the original factory settings. After resetting the TV to the original factory settings, you can get the initial setup screen to select Antenna. Make sure that the cable from the Antenna is connected to the TV.
Follow the steps given below to reset the TV to the original factory settings:
(i) Turn ON the TV.
(ii) While holding down the Up arrow button on the Remote control supplied with the TV, press the Power button on the TV set. The TV will turn itself off then back ON again.
(iii)Next, release the Up arrow.
Sep 08, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
HOW DO I UNISTALL A PROGRAM IF IT WON'T LET ME ?
Offhand, a couple of ideas, queries and suggestions:
  • make sure your are logged in as administrator or run the uninstall as administrator (right click);
  • some programs has to be stopped prior to being uninstalled;
  • try doing the uninstall in Safe Mode.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 21, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Jan 21, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Laptop won't turn on!!
dont panic
while you had left it for shut down, was it near by some where the Magnetic field like telephone, Speakers or Power adapter was placed to near to the screen
if your answer is yes, then the changes in colour on the screen is because of that. You need to demagnatized it with the gun. But in case you dont have it, relax it will get solved automatically after few hours of usage.
Turn on the Computer and then turn off properly. leave it for 5 minutes and then you start the Pc now you will be able to use the computer as before.
i hope this resolves your query
all the best
Jan 07, 2009 | Toshiba Satellite A135-S2276 Notebook
Frequent interrruptions
Initially, I would suspect the battery (even when plug to the AC). To confirm, pls try running without the battery and purely on AC adapter. Alternately, it could be a loose component internally such as the memory, LAN or WiFi card and in some models, video card. In my Toshiba, it turned out that the WiFi was consuming too much power that it discharges the battery rapidly and the charger was having a hard time coping up. My solution was to turnoff the built-in WiFi and install a D-Link USB.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Computers & Internet
Toshiba Satellite M55-S1001 Laptop
Your initial concern (auto shutting down) with some Toshiba could be caused by excessive power drain by some of the attached devices such as the WiFi, LAN among others. On the other hand, it could also indicate that the battery is already weak and constantly requires charging and at times eats up most of the power from the adapter leaving nothing for the motherboard to use. In some repairs I have done, switching off / or removing entirely unneeded devices correct the problem. In some instances, auto shut down is caused by dirty/clogged airducts/heatsink of the processor, failing blower/fan and/or poor ventilation.
You can have the Operating System re-installed using any Windows (I am assuming XP) OEM installer CD and to use the key printed in the sticker underneath your laptop to make it legitimate. The next challenge would be getting appropriate drivers to make all the devices in and with the laptop work as expected.
As long as it powers, POSTs and boots or look for an Operating System, then it is repairable and then of course would be usable.
There would be a number of qualified techs who could work on your laptop, ask around those who have experienced similar problems and have received good services.
Jul 21, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite M45 Power Problem
Your concern (auto shutting down) with Toshiba could be caused by excessive power drain by some of the attached devices such as the WiFi, LAN among others. On the other hand, it could also indicate that the battery is already weak and constantly requires charging and at times eats up most of the power from the adapter leaving nothing for the motherboard to use. In some repairs I have done, switching off / or removing entirely unneeded devices correct the problem. In some instances, auto shut down is caused by dirty/clogged airducts/heatsink of the processor, failing blower/fan and/or poor ventilation.
Of course, it could not be ruled out that internal problem with the power supply/regulator to have caused the shut down. Alternately, there are some viruses and malwares that could trigger shutdowns.
Jul 05, 2008 | Toshiba Satellite A45-S250 Notebook
Laptop
If your concern about turning itself of is a notebook or a laptop computer, it may be that the battery is not charged or the AC adapter/charger is not delivering power to the PC.
In some instances (including desktops) this could be because of a fault sensed in the hardware such as the CPU fan not turning, loose connection, dirty memory contacts. Additionally, if you are able to boot to the OS but thereafter shuts down, it is also possible for registry error, driver problems or even a malicious software or a virus.
Mar 07, 2008 | Toshiba A75-S209 P4(HT) 3.06GHz 512Mb 60Gb...
Dell Inspiron 1100 shuts itself off right after powering it on
if i take out the ram it does not shut off it is a problem with the ram
Mar 06, 2008 | Toshiba P25-S670 Notebook
Toshiba Satellite L500 Series Notebook Logo
205 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
