Question about Sole Fitness Sole F85 Treadmill
Won't go into sleep mode
New treadmill, just delivered today. Bly way I can get the display to go off is to turn off the power. Several times today it sat for over an our and the display never dimmed
Sole treadmill won't go in to sleep mode
You need to go into the maintenance menu.
Take out the red safety stop key, hold down the "start", "stop" and "Enter" buttons, keep holding them down while putting the red key back in (a bit tricky), keep holding the keys down until you see "Maintenance menu" scrolling (this will happen as long as you didn't let go of the three keys).
Initially when you put the red key in it'll might show software version etc, after a few seconds it'll change to maintenance menu. Use the speed UP and Down buttons on the console or arm to scroll through menu until you reach "FUNCTIONS" press enter.
In the functions sub-menu, depending on what year model/software version it has, it should have a selection called "Sleep Timer" if so set it using up down keys to "ON". If your model doesn't have "sleep timer" listed (i.e. a newer model) it's now just called "DISPLAY" and in that case set it to "OFF". That should fix it.
Press Stop, to go back. If you want you can disable the key tone/training beeping as well in the "functions" sub-menu of the "maintenance menu".
To exit press stop repeatedly until you're back to the normal display.
Dec 30, 2012 | Sole Fitness F63 Treadmill
Password reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Aug 24, 2012 | Precor 9.31 Treadmill
My computer won't turn on
when it is blinking red it means its in sleep mode. at that time the fan is turned off by your computer to save power. Press the power button oce again and u should have it up and running.
Aug 15, 2012 | HP Computers & Internet
Computer won't get out of sleep mode
I suggest you to update the display adapter.
Steps to update display adapter.
i. Click Start, type devmgmt.msc and press enter.
ii. Expand display adapter and right click on the sub item and click update driver.
For more information on updating driver, you may visit the link mentioned below:
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Revert us back if you come across the same issue after this.
Hope this information is helpful.
Aug 04, 2012 | Compaq Computers & Internet
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
For a long time the monitor wouldn't come on right away when the computer was in sleep mode, or hibernate. I'd move the mouse around and nothing would happen for 2 to 3 minutes - sometimes. Other...
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
Apr 21, 2017 | ViewSonic VP2030b 20.1" LCD Monitor
Hi FixYa folks, I have a Gateway DX4200-UB001A problem when ruuning in BOTH Vista Home Premium and now in Windows 7 Ultimate and giving me the same problem. When I put it in Sleep Mode, it won't come...
you are cold booting the pc always shut down normally when you shut down just useing button it will eventually corrupt the system I have several computers and never shut them off at all unless installing new hardware if you get a keyboard with the specific button just for the sleep mode this problem will clear up but if you shut down normal it will work rite
Jul 08, 2011 | Gateway DX4200-UB001A Desktop Computer
Sole Fitness Sole F85 Treadmill Logo
43 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
