Daewoo KOR-860A 1350 Watts Microwave Oven
Problem for Daewoo KOR-860A 1350 Watts Microwave Oven
Blowing fuse problems
By Bogdan on Jun 28, 2007
Actually my oven is a MIDEA brand (whatever no name brand that is) and the problem is with the mains fuse. After I repaired some contacts problem that prevented the oven to start microwaves when I close the door (the contact wasn't turned) now I have a problem with the fuse. It blew up after one day of the initial repair. I have dissasembled the oven, done a quick check and replaced the fuse. I've done some testing, all seemed to be ok, the oven worked properly, no fuse blowing out, no nothing. After some hours, next day when I tried to use the oven the fuse blew again. Once again I've dissasembled the oven, did some checks - all ok, oven working - next day the same :). The fuse blows when I open the door, in the same moment. After I change it I can power on the oven, all works, but after some 15-20hours when I open the door the fuse blows out instantly.
Could anyone help me. I have all the tools and can change components or other stuff, but my field of expertise is laptop and desktop repairs not ovens.
Comments:
Jul 10, 2007
- I thought of that, but I don't understand how I can't duplicate the problem the first day I change the fuse. The oven works during this time, whatever tests I can make on it and nothing bad happens when I open or close the door in any way possible. The contacts seem to be in a good shape. However, the next day the problem will manifest again whatever I do and however I try to open the door (more firmly, slowly etc).
Best Solution
posted on Jul 10, 2007
Very Helpful)
pilky
Rank: Master
Rating: 90%, 33 votes
The door latch switches, and monitor switch assembly needs adjusting. With the door open the two latch switches should be normally open,and the monitor switch closed. Opposite way when door is closed. MAKE sure oven is unplugged before testing
Was this helpful?
Yes
No
Popular Solutions for Daewoo KOR-860A 1350 Watts
Questions and Unsolved Problems for Daewoo KOR-860A 1350 Watts
Do you recommend Daewoo KOR-860A 1350 Watts Microwave Oven?
Answer
Answer
I have daewoo kor 860a microwave,it was working fine,but now everything working except heating. any... (More)
Answer
i popped 2 bags of popcorn in a brand new microwave we bought 2 hrs ago and now i have no power
Answer
I want to help me send all the details of the Bmkrooev Daewoo 860a, Watt 1350 because I do not know... (More)
Answer
my oven doesn't work , its internal rotating motor is not rotating and it also doesn't heat or cook... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Ovens Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
