Question about Numatic Henry Bagged Canister Vacuum
My numatic Hoover is brilliant but it smells what part needs changing? It's not a burning smell, but a musky almost cabbage smell?
It's an industrial numatic but that's not an option when choosing. The Hoover now just smells bad? It's quite old but I'm reluctant to give it up as its the best Hoover I have ever owned. It never used to smell but just wondered if anyone knew what it was? It's the air it blows out that smells? Any help really appreciated thanks :)
  • Fay Evans Jan 29, 2013
    Thanks Graham, I have recently purchased a cloth reusable bag for the Hoover and tis seems to have stopped most of the smell? It's much better now :)
    Champion:
  • 304 Answers
It could be the sponge filters or the dust partition that need replacing. But it might also be coming from the motor, best bet is to get it checked out.
Posted on Jan 29, 2013
4 Suggested Answers
SOURCE: my hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Posted on Nov 21, 2009
SOURCE: Numatic Henry Hoover
They should just pull out with a little pressure and a pair of pliers. Good luck with your repair
Posted on May 28, 2008
  • 389 Answers
SOURCE: Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Posted on Mar 01, 2009
Burning smell from motor
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
Aug 27, 2010 | Numatic HVR200P Bagged Canister Vacuum
Wet vac motor making noise and smells like burning
Hi I would suggest that the burning smell and the noise will mean that the motor is burnt out. You can get them pretty cheaply from the internet and they are quite easy to fit.
Mar 04, 2010 | Henry Numatic "" Canister Vacuum
My hoover smells of ammonia
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Vax hoover bagless, there is a burning smell coming from it
Most common burning smell is the belt in the power nozzle. check & replace.
Oct 11, 2009 | Hoover S3639 WindTunnel Bagged Canister...
Burning smell
the belt needs changed. its slipping. make sure its not clogged with carpet or string ect. first. if not buy a belt at walmart. in stock...
Sep 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Can i wash the filter on my numatic henry hoover?
If it is a recent model 2007 onwards, it may not be too successful, but you could try if absolutely necessary. Although not normally required, earlier filters can be gently washed by hand in a soapy solution, thoroughly rinsed and left to dry naturally.
Jun 07, 2009 | Numatic Henry Bagged Canister Vacuum
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Numatic Henry Bagged Canister Vacuum Logo
466 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
