Question about Recoton Advent Advent HT3251A TV
How do I take Closed Caption off?
I have tried several time but failed please help me to take CC off
    Top Expert:
  • Recoton Advent Master
  • 45,114 Answers
Go back to the initial setup routine and deselect it
Posted on Jan 05, 2013
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
How do i turn off the closed caption on my toshiba 51h84 tv? i tried setting via the remote and changed the CC option to OFF but i still see the closed caption wording...it is driving me crazy!! help!
What is the source of your TV signal: Cable? Dish Networks? DirectTV? Antenna?
Many times the Cable/Dish Networks/DirectTV controller also has an option for closed captioning. Please verify that a controller is not setup to deliver the CC data.
Also, try setting the TV CC using 'C1' or 'T1' and selecting 'Enter' to accept the change; then come back and set CC to 'Off' again to see if toggling on/off helps.
Dec 31, 2014 | Toshiba 51H84 51" Rear Projection...
I have samsung tv and de comcast cable,but i try to put the close caption and isn't work,can you help me please
closed caption can be blocked by the cable box- make sure cable box is set to allow closed caption.
on the TV, makes sure CC is set to CC1.
be certain you are on a Closed Caption program...all PBS stations are Closed Caption, all the time.
Apr 13, 2011 | Televison & Video
We have tried several times over thelast few months BUT can NOT get the close caption to work....HELP!!!
Hello
There is a button on the remote control of your TV marked {CC}. This button is used to select the closed caption option to On and OFF. Presing it repetedly will change the options as described below.
CC/Stop - This button will select the Closed Caption menu
in the TV mode. Options include the following: OFF, CC1,
CC2, CC3, CC4, TT1, TT2, TT3 or TT4. Additionally, this
button stops the CD, DVD or VCR when the component is
activated with the remote control. If it doesn't work, means that button on your remote control is not working, and the remote control should be replaced. OK.
Feb 17, 2011 | Vizio L37 Television
Can't turn off closed captions or find option to do so please helphelp
hi,
u can remove the closed caption optoin by the following setup.
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
Dec 26, 2010 | Philips 32PT6441/37 32" TV
How do you get closed caption on
manual below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man Turning On Captions Pressing the CC button displays caption options: ? CC on: Displays captions. ? CC off: Turns off captions. ? CC mute: Displays captions when the Mute button is pressed. To assign your preferences for captions, see “Using the Closed Caption Menu” on page 33.
Mar 17, 2010 | HP PL4260N 42 in. Plasma HDTV
Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
Jan 05, 2010 | Philips Magnavox 20MS233S 20" TV
Cannot turn off Closed Caption
Here's the copy on CC from my manual LC-32SB23U.
1. Press CC.
This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
Press repeatedly until you select the desired closed
caption service.
INFO BOX ON THE SCREEN,
Air ANALOG
Audio : MONO
CC : 1/2 CC1 ------ Closed Caption information
Ratings : NONE
Example:
If a program has three services (Digital CC(ENG), CC1
and Text1), the closed caption display will toggle in this
sequence:
1/3 ENG -- 2/3 CC1 --- 3/3 Text1 -- Off
The CC button keeps a record of the last service
selected in its memory.
If the last closed caption mode (e.g. 1/3ENG) you
selected is not available for the next program, or on
another channel, the closed caption service that is
available is automatically selected, and this service
appears in parentheses, e.g. “1/3(CC1)”.
Closed Caption services that appear in parentheses will
not be stored in the CC button's memory as your last
selected service. Only services that you have selected
with the CC button are stored.
If this doesn't work, the TV may need a software upgrade.
I can get you a copy of my manual LC-32SB23U for you. But, are you sure there is and "A" in the middle of your model number?
Jun 02, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Closed Caption
What we need to do first in a case like this is to first take one of the smaller sets in the house, that have closed caption on it, disconnect the cable from the Mitsubishi TV and reconnect it to the smaller TV set and see and make sure the cable line and or splitter to that line is good. If it still does not work on that line with the differant TV set, Then you know for sure that the cable is at fault or the cable equipment, as I have seen a problem like this a while back. If it does work on the smaller set then we know that the set does have a problem processing the cloised caption circuit and needs a servicer to repair it. You see these sets haqve no user replacable parts inside them because all parts are soldered into place and we need a schematic to trace out the closed caption curcuit. if you think you can handle a problem like this order the schematic online and upload it here and I will be more them happy to assist you to troubleshoot this beast. Good Luck PS Please do not forget to rate this thread.
Oct 27, 2006 | Mitsubishi WS-65712 65" Rear Projection...
Televison & Video Logo
Top Recoton Advent Televison & Video Experts
Rommel Balcita
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
