Question about Dishwashers
Standing water in my dishwasher. - Dishwashers
    Problem Solver:
  • 15 Answers
The problem is your water drainage pump
Posted on Jan 05, 2013
5 Suggested Answers
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 17 Answers
So it sounds to me like it is your "pump" I work for an appliance parts dealer and it looks to me like the pump you need is originally part# 99002750 but then it changes to #6-917641....It runs about $57.00 and you can find this product at www.allbrandonline.com
Hope this helps!
www.appliancepartsonline.net
Posted on Feb 16, 2009
  • 21 Answers
SOURCE: standing water in bottom of dishwasher
The first thing to try is to clear out debris from strainer area, you may need a Philips head screw driver for this. Clear out and then attempt to put the unit through its cycle.
The second thing I would try, is unattach drain hose from drain to sink, either blow in it or use a blower side of shop vac to force air into the hose. Reset dishwasher, and try again.
Not knowing how handy you are, you can pull the dishwasher out, please turn off circuit before doing so, also make sure you have towels handy. Unattached drain hose at base of drainage pump. Clear out hose and remove debris on bottom of pump. Reattach the hose and run through cycle..
If these do not work your issue is with a bad pump.
If there is a
Posted on Oct 13, 2009
My GE GSD4060Dss still has standing water
Make sure ur dishwasher is level if it isn't it will not drain all the water u can adjust the little legs on the bottom of dishwasher hope this helps
Apr 09, 2013 | GE GSD4060D Full Console Dishwasher with...
I have standing water in my dishwasher. How do I unclog the drain?
It will be smelly water and if you have access to a shop vac that will help you remove the standing water if not use a bowl or turkey blaster listed below.
Use a small bowl to remove standing water from washer to access screen to remove and check for blockage. Once you have removed all the water that you can with a bowl or cup. You can use a turkey blaster to sucton remaining water from dishwasher.
Then you remove screen and clean out drain and also check drain line for blockage from dishwasher to under sink.
Clean out drain to unclog in bottom of dishwasher and you may have to remove drain line to clean it.
Aug 10, 2010 | Frigidaire Dishwashers
Standing Water
Here is a tip that I wrote that will help you with your problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 06, 2010 | Dishwashers
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Sep 20, 2009 | Tappan Dishwashers
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwasher not draining
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dec 22, 2007 | Dishwashers
Dishwasher leaked water once due to an outlet block, then won't start
It obviously has leaked water on the connections underneath, Lean the dishwasher back and see if any water comes out the bottom, then leave it standing for about a week to dry out and hopefully it should be ok.
Nov 26, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Dishwashers Logo
103 people viewed this question
Top Dishwashers Experts
Owen Barnes
