Question about 2wire (2701HG-B) Wireless Router
Wireless light flickers and computer is looking for networks in short intervals
My downloads peeds are super low, it should be 11 mob, but i am getting only 300 kb max and it goes down to 10 mb and fluctuates constantly in between. on the router the wireless light flickers constantly, shouldn't it be solid?
  • 7,627 Answers
If the wireless device is working properly the LED's blink when transfering and receiving data. Even when not in use the ISP modem and the wireless device will blink. I would start by Checking ALL cables in the network, verify the cable connections. Have your ISP verify the signal, if necessary have a ISP tech come out to analyze the signal.
Posted on Jan 06, 2013
  • 5 more comments
  • hanslangfeld
    hanslangfeld Jan 06, 2013
    thanks, max. i actually played with all the wires and connections and it seems to work better now.
  • max carson
    max carson Jan 06, 2013
    Get so known good cables, splitters, etc., move through the cabling from the place where it comes into the house, to the wireless verifing/ changing each cable, splitter, etc. Sounds like a bad connection/cable. If a copper plug/connection gets oxidized it will degrade the signal, sometimes just reseating the cable will help. I use Electronic Contact Cleaner Spray, you can find most hardware stores.
  • hanslangfeld
    that sounds good,i have some spray i use on my amps, i will go back and use it on connectors and splitters. thanks, hans
  • max carson
    Let us know if you find the problem.
  • hanslangfeld
    hi max, i clean and rechecked all cables and cleaned connectors between incoming phone-jack and router. then i restarted the router. the wifi indicators on both of our i-macs still show a constant pattern of "on" and " looking for networks. it stays on "on for about 8 seconds and the looks for about 2 secs. while it is on the download speed is about 300 kb/s and it drops to 10 kb/sec while it is looking. the modem should be getting 11 mb/sec.
  • max carson
    Contact your ISP to analyze the incomming signal, have a ISP tech come out to verify the inside signal. Has it worked with the Apple products before? Does it connect using a Ethernet Cable? Take a look at this:http://www.dslreports.com/forum/r2631299...
  • hanslangfeld
    hanslangfeld Jan 08, 2013
    hi max,i contacted the isp and we checked the download and upload speeds and they were where they should be, the tech pointed out that downloads work much better when you connect your computer to the modem with ethernet ins tea of using wifi like i was doing. he said that competing wifi signals are the cause for this problem.i hooked up the modem to my computer via ethernet cable and it seems to work a lot faster. thanks for your help. hans
duxxyuk
  • 46 Answers
SOURCE: loosing wireless connection
It sounds to me like your wi-fi client might be affected by some sort of timeout or overload type kick. Is it just the PC or both the PC and the Xbox?
By "timeout" this could be your "IP Lease" that is too short (look in your ADSL PPP/PPOE configuration)
Otherwise would you be using any P2P software? If so you might want to look in the settings for something called MTU. Set this to something like 1500 then if that doesn't do it reduce it to 1492.
The only other thing I can think of is that your pc might be having authentication problems. Degrade your wi-fi security (go from WPA to WEP) and test to see if that makes any improvements.
Posted on Oct 18, 2007
  • 19 Answers
SOURCE: I cannot keep my connection to my wireless modem/router.
the router may be bad i would take it back and exchange it
Posted on Dec 27, 2008
SOURCE: ATT 2wire modem will not work. Red light on power button.
its the power  cord.  the fail after a year to 1 1/2 yrs.  get a new power cord
Posted on Apr 08, 2009
kakee
  • 1268 Answers
SOURCE: 2wire 2701hg-b on mac browsing great, bittorrent bad...
Try to look for MTU settings on your 2wire router. Reduce that to 1492 then do a power cycle. Check if that helps your download speed
Posted on Jun 10, 2009
  • 75 Answers
SOURCE: i have a 2 wire wireless router. Both computers
you should your lan to ruter cable install it again carefully.
Posted on Apr 28, 2010
I have WDF_VIOLATION on my computer and I can't access bios or even start up it keeps shutting down wanting to fix itself but it doesn't
It sounds like you have some type of virus. I have fixed almost all of my computer programs myself with Malwarebytes, SuperAnti Spyware. I did have to use RKill once on a super nasty virus. But, first you need to get the computer working. Here is how to get your computer into SAFE MODE WITH NETWORKING (you need the networking to download the software from Malwarebytes or Super Antispyware to fix your computer.)
  1. Immediately after the computer is powered on or restarted (usually after you hear your computer beep), tap the F8 key in 1 second intervals.
  2. After your computer displays hardware information and runs a memory test, the Advanced Boot Options menu will appear.
  3. Use the arrow keys to select Safe Mode or Safe Mode with Networking and press ENTER.
Apr 13, 2016 | Computers & Internet
Our main PC works fine but, laptops cannot receive internet
1.Open the router page
2.Enter the Username and password(default password is admin and leave the username blank)
3.Click Wireless and fill the sections as mentioned
Wireless Network Mode-Mixed
Wireless Network Name-As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID broadcast-Enable and click save settings
4.Click Wireless security and select the Security mode as WEP
Encryption-64 bit 10hex digits
Key1-enter 10 digit or 10 letter password(like your 10 digit telephone number)
and click Save settings.
5.Click Advanced Wireless settings and fill the sections as mention
Beacon interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click save settings.
6.Click the link http://homesupport.cisco.com/en-us/wireless/linksys/
7.Enter the model number of the router
8.Click Download tab and enter the verison of your router (turn the router upside down to get the version)
9.Download the firmware file and save it on your desktop.
10. Click Administration on router setup page and then click Firmware upgrade
11.Select the file that you have saved on the desktop and start upgrade.
12.Turn off the router for 30 seconds after upgrade.
13.You can also delete the network name from your computer and add it again.
i hope this will resolve the issue.
Regards
Chiranjeet
May 23, 2010 | Linksys Wireless-G Broadband Router
I have a WRT150N router and it will not let me connect to it through the wireless. I have tried resetting the password no luck
Hi Friend,
Please follow the steps in order to resolve the issue:
Network Mode-Mixed
Radio band-Auto
Wide channel-Auto
Standard channel-Auto
Encryption-40/64 bit
Beacon interval-75
I hope this will resolve the issue.
Regards
Chiranjeet
May 23, 2010 | Linksys Wireless-N WRT150N Router
My laptop finds wireless router but will not connect to internet
Hi there. You may need to connect to the wireless network manually. What is the operating system running on your computer? If XP, you may follow these. (This is also applicable in other operating system, it may just vary a little) Right click the monitor icon showing on the system tray near the clock. Point the mouse in the icon and it will display the name if it is wireless network connection or network connection. Right click the icon and look for view available wireless network. If it is not showing, look for network connection. Right click and select "open network connection". Right click wireless network connection and select "view available wireless network" . Look for the wireless network you're trying to access or have connection.Highlight and click connect. If encrypted, you need to supply the pass key or security key twice and hit connect. It should allow you now to go online wirelessly. Please remember these, you should be able to go online wired. Make sure that there are other wireless computer connected to the wireless network you're connecting with and can go online wirelessly.
Hope this help :)
May 16, 2009 | Dynamode (R-ADSL-C4-W) Wireless Router
I have a Linksys Wireless-G Network adapter (WUSB54G S ver 2). When I plug it in to usb, the power light flickers once and goes off. I have tried plugging it in w/o drivers and have tried again with two...
http://www.linksysbycisco.com/US/en/support/WUSB54GS/download
You may want to download drivers and new updates for this model from the link above. You have to select your version (2) and you'll see the download to your left on the page.
Try plugging it into another USB port.and or another computer if you have one available. Test the USB port with another device to see if it maybe the problem. Also make certain your plugs are snugly in their sockets. But it I think you are right on target with the defective device point of view.
If you ruled out the things listed above...defective.
Hope this helps, please leave rating, thank you
May 08, 2009 | Linksys WUSB54GS 802.11G USB Adapter...
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Wireless
Next to your clock on your notebook is there an icon that looks like a computer monitor with a radio signal to the right of it?
If so move the mouse over to it and press view available wireless networks.
Im not sure how to scan for it on the Wii. I would check to see if there is a scan funtion on it to look for it.
Does a Wii require a wireless network adaptor or is it built in?
Jun 13, 2008 | NetGear WGR614 Wireless Router
BWI 715 Super G wireless driver for Windows
I have the original CD Drivers, If you want I can share it with you.
Jimmy.
Jun 19, 2007 | Blitzz Technology BWI715 Super G 802.11g/b...
Super G 802.11g/b
ok look in device manager down the list to your wireless card and see if it is listed, if so check that there is not a red cross on it, if so right click and select enable. if a yellow exclamation mark driver not recognised with card. If it is listed and you are unable to enable it restart the pc and press F2 or DEL to enter your bios and on the peripherals menu, see if the wireless controller(if it is built in card) is enabled. If non of the above works, then the code 10 would normally be refering to a faulty peice of hardware.
Mar 18, 2007 | Blitzz Technology BWI715 Super G 802.11g/b...
2wire (2701HG-B) Wireless Router Logo
140 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
