Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
The print quality my 5300 is inconsistent. It varies from black to faded and blurred gray. I have changed both the black and color cartridges. On the menu, I have selected "clean and deep clean" the print head as well as "calibrating" the print head. So far nothing has fixed this problem. A few months ago, I was sent a new print head from your tech center. Please help.
  • glenandlucre Jan 22, 2009
    Yes, they are. How do I get this one replaced? Since they are defective is there a warranty or must I purchase it myself?
  • 45 Answers
Need another printhead, they are defective.
Posted on Jan 21, 2009
Dear Folks, My colour laser is probably my most "valuable" and needed tool, next to my notebook. The black toner cartridge ran out and I replaced it. From that point on, the printing is very...
Well there are few tests you could run to make sure it's not the printer.
1. You said you already tried different print cartridges and it didn't make a difference.
2. Have you tried printing anything else? Like the windows test page? Does that come out gray as well? The reason I suggest this is because sometimes when printing a document you can set the printer settings to always print in "Draft" mode. This mode allows the printer to conserve the ink which make black look faded or gray. If you can make sure the printer settings are set to "Normal" or "High Quality" then test.
3. Also are you buying the printer cartridges from the same vendor? What I mean is that sometimes different vendors have different quality of printer cartridges. Some sell re-use/re-furbished print cartridges for a much lower price, and some sell OEM (original equipment manufacturer) for "an arm and a leg". So make sure you have a good quality print cartridges.
Hope this helps
P.S In the future you should let us know what make and model your printer is, this will help us narrow down the issue, or if we have had this issue happen to us we can let you know.
Mar 17, 2011 | Office Equipment & Supplies
I have a Kodak Easy Share 5300. Just changed both
  1. Check that your color cartridge/toner is not empty or blocked.
    This is the least likely cause of the problem, but an important check to make. Most color printer drivers and/or software provide functions to verify alignment and color output. Consult your manual or open your printer driver by clicking Start : Settings : Printers and right-click on your printer's icon and select Properties. 'Browse' the Properties dialog for options that perform system checks.
  2. Look for a 'Print only Black and White' option.
    Open your printer driver's Properties dialog (see above) and look for a color option that uses black only. Uncheck it or select an option that enables color. Some color printers have different resolutions for color and black-and-white (usually higher resolution in black-and-white). Some applications (not Origin) will force a printer to use a quality mode that affects this option, and if the resolution is forced to its highest the color output may be disabled.
  3. Enable gray scale printing.
    Some combinations of printers and operating system versions can lead to a miscommunication between Origin and a printer driver. Under these circumstances, Origin may 'think' it is dealing with a black-and-white printer when it is actually using a color printer. Beginning with 6.1, the Origin Print dialog displayed one of two messages depending on the print capabilities read by Origin:
    1. Enable color as gray scale
      This check box displays for color printers
    2. Use simplified colors
      This check box displays for black-and-white printers
    If you are seeing the first checkbox and you are using a color printer, then checking the box should tell Origin to send all color information and let the printer handle any conversions that may come up. In earlier versions of Origin there was a rather cryptic "Print color on black and white printers" checkbox which did the same thing.
Apr 30, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak 5500 AIO easy share printer will not print black ink.
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
Oct 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
At first would pring in oolor only with faded
Do several printhead cleaning via the printer menu and make a test print. Mostly printhead cleanings solve the issue.
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
BLACK INK PRINTS LIGHT GRAY. HAVE CHANGED CARTRIDGE TWICE WITH NO DIFFERENCE
The print head is likely fouled beyond the point of self-cleaning.
This thread should answer further questions:
Kodak 5300
Mar 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
It will not print black print information on paper, bad quality
1.800.421.6699 call that number and select option 01 for prints missing black or color ink
Jan 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Inconsistent print quality - from black to blurred gray
please don't say that
kodak is very good and your problem is VERY COMMON
If you call 1.800.421.6699 and select option 01 for prints missing black or color in, Kodak will send you a replacement printhead kit for free.
by the way, I don't work for kodak
Jan 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How can I print a color picture without using a black catridge?
Black ink is an essential part of the printing process. The black color is only made by the black cartridge, the color cartridge does make "black".
One or more optional photo cartridges may be available, depending on your printer model.
  • Use the photo cartridge with a tri-color cartridge for best-quality color photos and graphics, and sepia or antique photos.
  • Choose a gray photo cartridge to print black and white photos with truer grays and richer blacks.
Nov 21, 2008 | HP DeskJet F380 All-In-One Printer
Kodak 5300 not printing colors
Kodak told me to take the printhead off and reseat it several times, which I did. I then deep cleaned it, calibrated it, and replaced the color cartridge. It didn't solve the problem. Kodak will replace the printhead for free, and after I return the defective one, will send me a free color and black cartridge. Very nice service. I've been very happy with the 5300.
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
