Question about Magic Chef MCM1110B
Microwave turns on & off byself
The microwave comes on for 1:35 seconds and then it turns off for a minute and turns back on by itself. it does this until i get up and unplug it.
3 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave turns on by itself
You have a shorting keypad. This can be very dangerous and result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it;s not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find Magic Chef parts here.
If not, please reply back with your model number so we can help you.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
Posted on Nov 08, 2008
  • 6771 Answers
The problem is in the keypad control board, in order to fix this the part alone starts around $100.00 and must be replaced to fix this, also it would be a good idea to get the door switches checked.
Posted on Apr 27, 2012
Magic chef mco160s microwave control panel not working
That would be a defective membrane keypad.
If it's still available, and you or someone you know might want to replace it, here's a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag in or on the microwave here.
Jan 08, 2013 | Microwave Ovens
Cannot read the touch screen & only easy minute works
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
You can also download the owner's manual from the page at the second link.
Jun 06, 2010 | Dacor DMT2420SS Microwave Oven
Panasonic dimension4 microwave
check the damper motor is opening and closeing
Jan 17, 2010 | Panasonic NN-T888S Convection/Microwave...
I THOUGHT I WAS TURNING ON THE TIMER AND WAS RUNNING THE MICROWAVE INSTEAD. IT GOT HOT AND SHUT ITSELF OFF. HELP
If it didn't come back on in 15-20 minutes you blew the cavity thermal fuse you'll have to have a technician replace it.
Aug 19, 2009 | Microwave Ovens
Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jun 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Shuts itself off mid cooking cycle -- as if unplugged; then after 5 minutes or so turns itself back on as if it was just plugged in (forgetting all previous settings)
If you just put the fan blade back on, it will almost certainly fall off again.
The best bet is to slightly rough up the contact area of the shaft with sandpaper and use a little super glue to hold the blade assembly on the shaft, and let it set a few minutes before using it.
I always recommend that you use the hood vent exhaust fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2009 | GE Profile Spacemaker Over-the-Range...
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven starts by itself
sounds like you have a stuck key. if you take the control panel off and un plug the ribon cable and blug it back in if the problem continues it is the control board.
Let me know if you need further assistance
Nov 30, 2008 | Magic Chef CMV1000B Microwave Oven
Lights dim when microwave runs. if runs more than 3 minutes it turns itself off and then resets after approx 10 minutes. I have had an electician here to see if it were the amps, it isn't.
As long as those lights don't draw too much current, that will probably be okay.
The microwave may consume 1500-2000W (the model number tag or manual will tell you). Add that to the total of the wattage of the lights. Then divide that grand total of watts by 120 (the voltage) and that will give you current in amps that your oven and lamps draw.
Make sure your breaker is rated about 25% above that.
If that holds true, then then I would say your magnetron or high voltage transformer is failing.
If you can post back with your brand and model number I can give you some info on those.
Apr 11, 2008 | Microwave Ovens
Magic Chef MCM1110B Logo
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
