Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
Temperature calibration for white rodgers 1f80-51
2 Suggested Answers
liteswink
  • 99 Answers
SOURCE: * APPEARS NEXT TO TEMPERATURE
The snowflake is displayed on the screen when the system is in cool position. check page four of the installation manual
Link: INSTALLATION MANUAL
Posted on May 29, 2010
My White Rodgers 1F78 programmable thermostat shows a constant room temperature of 83-84 in the afternoon, but I set it at 77 throughout the whole day and night. Should I get a new one?
It sounds like the temp sensor is defective in the T-stat. I would replace it, get the newer programmable ones, they are very reliable and very cheap to buy online.
Sep 21, 2016 | WHITE-RODGERS DIV 1F78-151 White 70 Series...
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
How do I fix my my white rodgers f178 thermostat, no heat
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department.
- Check the wires on the terminals make sure that they are not loose
- Reset the unit by press time, up and down buttons make sure the systems is in on position.
- Set the system to heat then and raise the setpoint above room temperature. There may be up to five minute delay before the thermostat clicks in heating If the thermostat click this means its not a thermostat you have a problem with your heating equipment call your installer. If the thermostat did not click the unit should be replaced.
Let me know if you need anything else.
Jan 11, 2013 | White Rodgers White-Rodgers 1F85RF-275...
I don't want to program the 1f85-275 thermostat, i will adjust when needed
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To manually operate the unit just set the thermostat to heat mode and the fan to auto. Press the hold button one time then set you desired temperature.
Nov 15, 2012 | White Rodgers White-Rodgers 1F85RF-275...
The room temperature on my white-rodgers thermostat model 156-5299 keeps increasing
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. 156-5299 is a invalid model number To better assist you with this contact White - Rodger's technical department at 18002842925.
Sep 02, 2012 | White Rodgers White-Rodgers 1F85RF-275...
I have a white rodgers thermostat 1F80-361 and my air conditioner blows out cool air for about an hour then it stips and blows out a air like temperture. The current temperature always says 80 and above...
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from White- Rodger's. Base on your description you have a system problem not a thermostat issue. You need to contact your installer to check you cool equipment.
Aug 04, 2012 | Heating & Cooling
White rodgers customer service phone number
we are not white rodgers /emerson --the following links can assist you but if the trooble shooting doesnt fix problem just replace the stat
White Rodgers White Rodgers White Rodgers Thermostats Thermostat AC Wholesalers How to Troubleshoot White Rodgers Thermostat eHow
May 30, 2017 | Heating & Cooling
How to you change ferenheit to celcius?
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Jan 29, 2011 | White Rodgers White-Rodgers 1F85RF-275...
May 26, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
Oct 29, 2009 | White Rodgers White-Rodgers 1F85RF-275...
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
185 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
