Question about Dell Computers & Internet
Dell Dimension xps R450 won't boot
After power on, there is no video, the floppy and DVD lights are on briefly together then go off, no beeps (usually indicating floppy drive and keyboard have been checked). The hard drive access light stays on for a few seconds and then goes off. The keyboard lights are on and stay on. It appears the normal boot sequence is not being followed. Is there something that can be done to localize or diagnose this problem?
  • S_Nandha May 11, 2010
    When you turn the computer on does anything at all come on the screen?
  • 1,602 Answers
MAYBE A POWER SUPPLY PROBLEM OR THE CMOS BATTERY IS OUT OF JUICE, YOU DIDNT KNOW THAT YOU HAVE A BATTERY THAT KEEP EVERY THING WORKING RIGHT.
NOT KIDDING
CANDYMANGANDY
Posted on Jan 29, 2009
Why wont my xps 700 boot?
Not sure on the beep side but this is what the lights code refer too.
Ensure that all hard drive and CD/DVD drive cables are properly connected to the system board.
If there is an error message on the screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
If the operating system is attempting to boot from a device (such as the floppy drive or CD/DVD drive); check system setup to ensure the boot sequence is correct for the devices installed on your computer.
If the problem persists, contact Dell (see "Contacting Dell" in your Owner's Manual).
May 18, 2014 | Dell Computers & Internet
Dimension E310 6 beep
if the beep pattern and led light pattern it's a memory problem, try reseating the RAM. Problem and solution is described multiple times here
Dimension E310 won boot up 6 beeps
21.June.2015
Apr 18, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
Hello, I have a Dell XPS 400 system that has a bad hard drive. So I went out and bought a new SATA drive, and it's not detecting it upon boot. When I go to the boot menu on F12, it says something about...
Was the original drive also a SATA? If not, then you would need to enter the bios setup and enable the onboard SATA channels. If the bios had gotten defaulted, as from a dead CMOS battery etc. it could have also caused your original SATA drive to be inaccessible.
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
Dell Dimension XPS PC Desktop won't boot
Vista is available in 32 and 64 bit os.
if your system ran xp which was most likely 32 bit. And you have installed a 64 bit version os.
this will be your problem, also Vista requires more system RAM/Memory to run it.
If you get 1 beep at startup, it states the system is ok.
Alternatives are device drivers incompatability.
Check M$ website, regarding vistas minimum system requirements.
Mike @ Compurepair.
Jun 11, 2009 | Dell Dimension XPS PC Desktop
Dell Dimension 4600 will not reconize cd or dvd drive
  1. ensure the drives are jumpered Cable select.
  2. Boot to the BIOS, turn on Caps Lock, Scroll Lock, Numlock. Then press ALT+E (You should hear one beep) then ALT+F (You should hear one beep) if you have no floppy disk drive, turn off the Floppy Drive and the diskette controller the ALT+B to save and reboot.
Mar 01, 2009 | Dell Dimension 4600 PC Desktop
Lights 3 &4 stay on.
Computer beeping at you is usually a problem with the video card or memory. Try re-seating both and see if you still have the same problem. If you do, individually remove each component and power on to test if the beeps persist.
Jan 06, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Computers & Internet Logo
482 people viewed this question
Alun Cox
