Question about Stanley 3in1 Tripod LED Flashlight 95155
How do you chance battery on a stranley tripd flashlight
Unscrew the caps at the bottom of each leg - each leg holds 3 AA batteries (9 total)
Posted on Dec 03, 2013
Not sure which bit to unscrew when trying change battery in onyx50
The flashlight uses 1 AA battery. My guess, you should only have to unscrew the end cap. If you finds it very hard to unscrew the end cap off, it could be from the battery has explode and swollen. MAYBE - I see this happen in my daughters MAG flashlight. DO not keep your flashlight in the car with the batteries installed. The amount of heat in the cars can ruin the batteries in the flashlight.
Apr 06, 2016 | Gerber 22-80144 Onyx 50 Flashlight
Tip
Prevent battery damage to flashlight
Any flashlight that uses non-rechargeable batteries, IE... AAA, AA, C, or D batteries. If it is not used on a regular basis and sits for a long time with the batteries still in it, the batteries will leak and damage the flashlight. It is recommended that if the flashlight is not going to be used for long periods of time, that you remove the batteries to avoid leakage into the flashlight. This also is recommended for anything that uses this type of battery. These types of batteries are known leakers.
on Feb 20, 2011 | Camping, Backpacking & Hiking
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
Corroded battery in high beam 1watt
battery sat inside to long or was overcharged... not worth saving
Dec 29, 2013 | Rayovac Highbeam Flashlight 1 Watt Luxeon...
Where do the batteries go in my stanley tripod flashlight?
Hello, The batteries are located inside each leg of the flashlight. Just remove the end cap on each leg by twisting it off. Inside each leg is 3 AA batteries.
Good Luck! Rich L.
Nov 28, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
Batteries got corroded in the flashlight now I can't get it out. How can I get the battery out?
If you can remove both ends of the flashlight, find a piece of pipe that is slightly smaller in diameter than the inside of your flashlight, hold the flashlight body in one hand and the pipe in the other. place the pipe on top of the batteries then strike the pipe on a heavy hard surface that you are not worried about damaging. The blows should dislodge the batteries. Clean the corrosion thoroghly before putting new batteries in
Jun 14, 2010 | MagLite Mag-Lite& Flashlight
® XRF Xenon Rechargeable Flashlight: Where can we find the batteries for Xenon Cyclops ...
I am not familiar with that particular model flashlight. Most of the Cuclops flashlights use the 3.0 Volt CR123 Battery. However, here is the URL for Cyclops Solutions website. www.cyclopssolutions.com/index.html
May 15, 2010 | Cyclops ® XRF Xenon Rechargeable...
LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
Apr 05, 2009 | Stinger Streamlight 75000
Flashlight
You will not find a warranty on this item that covers you problem. These flashlights are not expensive ($5-10). If you want to fix it yourself do this:
Wear rubber gloves and remove any residue using a paper towel. Scrape off any hardened material with the end of a screwdriver. Now, clean the spring with one of those disposable nail files, sand paper, or a wire brush. After it's clean you can coat the spring in some Vaseline petrol jelly. Next time, take out the batteries when not in use to prevent this from happening again.
Oct 10, 2008 | Camping, Backpacking & Hiking
Stanley 3in1 Tripod LED Flashlight 95155 Logo
225 people viewed this question
Top Stanley Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
