Question about Toys
My propel execuheli rc helicopter don't charge when I charge it the charging ligh blinks
Don't charge
SOURCE: Yiboo AH-64 3D RC Mini Apache Helicopter
There is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter. I had the same problem with the top rotors, and had to go in and re-insert the rotor shaft and tighten the set screw. I applied locktite to the threads to prevent it from backing out. It works now, but one problem I notice is that there must have been a spacer bushing between the two gear wheels. Without the bushing, it will still fly, but I can feel some play in the upper shaft and wonder if over time that the counter spinning gear wheels will start to wear against eachother.
Posted on Feb 10, 2010
rynanlimpiad
  • 36 Answers
SOURCE: Blinking remote light when charging
check the remote indicator censord
Posted on Apr 08, 2010
  • 3 Answers
SOURCE: I cHarged the helicopter and
try to play around with the trimmer.. i had the same problem but then guessed it was the trimmer and iwas right!
Posted on Dec 25, 2010
SOURCE: propel rc execuheli upper rotor
I had the same trouble this morning, I used the screwdriver that is supplied and removed the right side of the body. I found the gear on the motor shaft had slipped up the shaft and was not meshing with the bottom rotor gear. slide the motor gear down into postion, and install the right side of the body.
SOURCE: MY PROPEL RC EXECUHELI WILL
counter clockwise would be the nose tuning to the left. My sons did this and pressing the right trim button on the controler repeatedly untill it slows is all I had to do. If you go to far it will spin int the oposite direction then you have to trim to the left and find the happy middle
Posted on Dec 27, 2010
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Can I connect the Arduino Uno to my 3.5 Channel RC Helicopter? or any other Smart Board?
i think yes but i don't know how to connect
i've a problem to connect my helicopter RC to my arduino
if you already have a solve for this problem can you share me?
Sep 17, 2012 | Syma Rc Remote Control Helicopter s107g,...
My battery exploded
Not sure what you're asking about but if this just happened and you need to clean it up then you will need to neutralize whatever has spilled. Was it a standard alkaline battery, nickle cadium, don't know...??? Quickly google how to neutralize whatever you have, then add some more details about whatever problem you're having. Be careful!
Sep 15, 2012 | Lujex 4CH 2.4GHz Mini Radio Single...
Gyropter not lifting off after full charge
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
Nov 20, 2011 | JCPenney Gyropter RC Helicopter
The gyropter will not charge when I plug it in
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
Aug 14, 2011 | JCPenney Gyropter RC Helicopter
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
My rc heli wont go up
Are you missing any parts? make sure its charged, i know if you are missing a stabilizer it wont go up the stabilizer is what holds the two propellers together and when the helicopter takes a hard impact it usually comes off so check for that hoped this helped
Feb 12, 2011 | xheli 3 Channel Alloy Falcon Aluminum RC...
I cHarged the helicopter and can get the directional Propeller to spin but cAnnot get the main throttle proPellers to spin. Help
Dec 25, 2010 | JCPenney Gyropter RC Helicopter
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
