Question about Panasonic Televison & Video
My unit is displaying W OPE. It is not responding to the remote for poweron/off or anything else. The screen is indicating that a disc may not have recorded correctly (I was not trying to record anything) and wants me to press the OK button but it doesn't respond to it. I have tried unplugging the unit and it always comes back to the same message. I have the panasonic Blu Ray player model number BTT273.
SOURCE: Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Posted on Mar 20, 2007
GSAN
  • 106 Answers
SOURCE: dvd player/recorder
Like many RCA products that use a DVD Burner, these burners are not high end ones and go out without warning and the first indication is the dreaded HELLO issue. I have tried contacting RCA and the makers of the DVD-RW drives but still I am in the dark as to any possible firmware/software updates for these devices. No fix to this date, only replacing the DVD-RW will resolve this.
Posted on Sep 29, 2008
abhishek33
  • 1239 Answers
SOURCE: I want to be able to play all my recorded dvds but get message
HI CHECK THESE Steps:
1. Remove the screws that hold the top case on the dvd player. There will be a couple of screws on each side of the player and a couple of smaller screws on the back. They will most often be BLUE RAY head screws.
2. Once the cover is removed, push the eject button to open the cd tray and get it out of your way.
3. Unplug the player from the outlet.
4. Take the can of compressed air and blow out the entire inside of the case. Make sure to blow inside the carriage and around any moving parts of the dvd player including tracks, tray, gears, etc.
5. Check the inside of the carriage using a small flashlight and look closely to make sure there is not debris caught in the spindle or other places like hair, large clumps of dust, dirt, and anything else that should not be there. If you see this kind of material remove it with tweezers and repeat blowing out the inside.
6. Pour a small amount of the rubbing alcohol into the cap and lightly dip a cu-tip in it and shake off any excess.
7. Now and clean off the optical lens (which will look like a small glass bubble in the middle of the carriage) with the cu-tip. Repeat this process a couple of times using a clean cu-tip each time.
8. Let air dry for 2 minutes before plugging the player back in and closing the tray.
9. Replace the cover and clean your discs before placing them back in the player. Test to see if the problem has been fixed.
You should clean your dvd player out at least once or twice a month for good preventative maintenance which will extend the life of your dvd player.
Posted on Jan 04, 2009
Mike Adams
  • 19 Answers
SOURCE: hello?
Symptoms
The unit's remote control and front panel buttons act completely dead. The unit locks up after displaying "hello" on its front panel and refuses to do anything more. In other cases, the front panel display appears completely dead. In this instance, the unit will display "Interface error" or "Interface error! Turn off the power" on the television screen and do nothing more.
In all cases, if a DVD or VHS tape was inserted just prior to the failure, you won't be able to remove either from that point further. They'll remain stuck inside the unit until you've completed the repair contained in the guide below.
Critical information you need to know immediately
If you haven't done so already please unplug the unit's AC power cord and leave it that way until you're ready to begin the repair. Taking this action will guarantee no further extensive electronic or mechanical damage can occur.
Under no circumstances attempt to remove anything stuck inside the unit until the repair has been completed. Should you attempt to do so you'll almost certainly damage its ultra-delicate DVD and VCR mechanisms which are very expensive to replace!
Once the necessary electronic repair has been completed, you'll easily be able to remove them in the customary manner without any problem whatsoever, by simply pressing the EJECT or OPEN/CLOSE button.
Why your unit has recently failed
The cause of all the above symptoms are entirely due to an inherent manufacturing defect in the unit's internal power-supply board, all of which will ultimately fail due to one or more defective capacitors contained on it.
Known brands and models affected
Audiovox DVDVCP01
Durabrand DBDVR01
LG RC797T and RC897T
Memorex MVDR2100, MVDR2102, MVDR2102A, MVCD2102 and MVCD2102A
Panasonic DMR-ES15, DMR-ES30V, DMR-ES35V, DMR-EH55 and more
RCA DRC6200N, DRC6355N, DRC8030N, DRC8040, DRC8052N
RCA DRC8060N, DRC8295N, DRC8300, DRC8300N, DRC8310N
RCA DRC8312N, DRC8320N and DRC8335
...plus many others not yet identified - please contact me if your's isn't listed above
Completely restore the unit yourself in under 20 minutes for just a few dollars
This simple repair doesn't require any prior knowledge or experience with electronics, takes less than 20 minutes from start to finish and typically costs between $1.59 and $5.00 for the replacement parts obtained from your local Radio Shack. All that's involved is simply replacing one (or occasionally just a few more) defective capacitors on the unit's internal power-supply board which are most often running painfully hot to the touch.
The repair guide is provided to anyone who needs it simply upon request
Upon discovering the massive quantity of Chinese manufactured combo recorders having this inherent defect, in addition to the callous manner RCA Thomson and other manufacturers were leaving their loyal consumers out in the cold whose units had completely failed thru no fault of their own, it so enraged me I was compelled to fight back. That was just 3 short months ago and the day this Combo Recorder repair brief was born.
How do I obtain a copy?
Just send an email to my public address provided below. Please include your brand and model followed by "repair brief" in the SUBJECT line. For example, "RCA DRC8335 repair brief" and I'll send it using my private ISP address as soon as possible. Email your request to mikeadams110@yahoo.com
Why don't you just post the repair brief directly on Fixya?
Due to the dynamic nature of its content, the repair brief's constantly being updated on nearly a daily basis, as new information becomes known that wasn't previously. Unless the repair brief is kept at one centralized location, it becomes impractical to manage and keep up to date. Many of the DIY repair forums like Fixya don't even provide the author any way of updating their prior submissions.
Why are your posts often so long?
They're whatever length they appropriately need to be. Nobody likes having to read a long post until it happens to be the one supplying the ideal solution to their problem--in which case it's never long enough!
Can I really do this repair myself?
Over 1,000 combo owners just like you have successfully restored their units using this DIY repair guide during the past 90 days! Below is a tiny handful of the nearly 1,000 follow-up messages I've received to date. Ann's follow-up message is an excellent example demonstrating how new strategic information is provided by your direct feedback and why it's essential the repair brief's kept up to date.
December 27, 2008 received by email from Ann M.
Just like John H, my problem was also capacitor C226, but in my case overheating wasn't the give-away here. Instead, I noticed the bottom of the capacitor appeared melted a little and the top looked like it was slightly bulged. I removed the damaged capacitor and replaced it with a new one rated at 35 volts and now my DRC8335 is working perfectly again!
December 15, 2008 received by email from Mike J.
Mike. Just recently discovered the link to your repair brief posted on AnswerBag and wanted to let you know my previously dead DRC8320N combo recorder is now working perfectly again! Even though I'd never worked with electronics before, following your excellent instructions made the task easy. Bless you for having saved me a pile of money.
December 7, 2008 posted by TinyPeanut on AnswerBag
What Mike says works! My nephew went to Fry's Electronics store in California and got the part he suggested, in our case a 1,000µF 50 volt electrolytic capacitor as that's what they had on hand. He and my brother soldered it in and now my DRC8320N combo's working perfectly again! Thanks so much.
December 04, 2008 received by email from John H.
Mike. Thanks for providing this excellent DIY repair guide. My RCA DRC8335 is now performing perfectly again! In my case, the failure was caused entirely by capacitor C226 which I've just upgraded to 35 volts as advised, purchased from Radio Shack. Thanks again.
December 04, 2008 received by email from Glen
Dear Mike. Simply awesome, my DRC8320N combo's now fixed thanks to you! The only thing remaining I need to do is replace the VCR drive belt so its drawer will lock into place properly. Feel free to share my joy. Thanks again for all your help.
November 25, 2008 posted by Norstar448 on Fixya
I printed out Mike Adam's solution and phoned 2 electronic repair shops who refused to listen to how my machine could easily be repaired. The third said to bring in the info and my machine. He quickly located the part and replaced it and my machine is 100%. Thanks Mike!
November 14, 2008 received by email from Brandon
Mike. Since I last wrote, I've already taken my DRC8320N recorder apart, replaced capacitor #C232 and it's now working great! I repaired it myself without any electronics background or having done anything like this before. It really felt rewarding after putting things back together and plugging it in, to discover everything was working perfectly again.
Posted on Jan 10, 2009
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
I have a fujitsu a/c unit. Remote Model AR-RAH2U. If I push the on button, the a/c goes on-screen remains blank. I can not adjust the temperature or anything else. I have replaced the batteries.
seems its display and micro receiver r not working .kindly contact to your local repair man to replace remote receiver And display.
Hope answer the question
Aug 07, 2016 | Fujitsu Heating & Cooling
Sony DAV-C700 DVD player not working
is there any display in the LCD screen of your player??
Jun 28, 2008 | Sony DAV-C700 System
Samsung SMT-H3270 DVR not responding at all
The DVR unit still have power and display functions on the DVR small LED screen indicator on the DVR unit correct?And the DVR unit have not been in used for awhile and alway been plug in the power outlet for power like 24/7 hrs for power correct?Yes to all these questions,possible the DVR unit have software lockup or power glities some where before,possible the DVR unit have lockup and looping the software firmware of DVR unit not responding correctly for to the DVR unit to work or responding to any screen display functions.Tries unplugging the DVR unit for like about an hour and plugging power it back in for the DVR unit for the software to reboot itself.90 to 95% the unit will work again as u first got the DVR unit.
Oct 28, 2012 | Computers & Internet
I have a Sony CDP-CX350. I recently discovered the remote will not control anything on the player. The remote has fresh batteries and displays that a signal is sent out. The same display usually shows...
If you have turned it back on then this would indicate the receiving module that picks up the infrared signal is not working and has become defective, but I would double check your manual so nothing was over looked.
Jan 30, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
Unlock region free?
1. Remove any DVD discs from the tray/unit.
2. Switch off the DVD player and unplug the power cord.
3. Wait 30 seconds, then reconnect the power cord.
4. Turn on the DVD player with the supplied Samsung remote and wait for player to finish loading and display 'no disc' or the Samsung logo before you do anything else.
5. Press Enter on remote. (There will be no on-screen response to you doing this.)
6. Press the following numbers in sequence using the supplied Samsung remote unit's keypad -
8 4 2 6 9
(Again, there will be no on-screen response to this action.)
7. Press Enter on the remote. The DVD Player will automatically shut off.
8. Now, turn the DVD player on.
9. When it is on and showing the "no disc" or Samsung logo, turn it off again.
10. Repeat this action by turning the DVD player on, then off again.
11. The DVD Player should now be Region-free.
Sep 29, 2010 | Panasonic DVD-S54 DVD Player
When I turn on my unit the display is stuck with REMOTE ON
Move the remote to another room to test. It is possible a button on the remote is stuck on.
Beyond that , it probably needs to go in for service.
May 16, 2010 | Sony CDP-CX400 400-Disc CD Changer
Power botton not responding
If it's not ejecting or responding to any of the buttons on the unit, or the remote, but is able to play a DVD, the display microprocessor(computer) within your Harman is damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 22, 2008 | Harman Multimedia HS 300 System
TH-79A amateur radio
TH-79A Kenwood HT and with the power off, hold down the MR button and the PTT switch, and while holding both of these turn on the power. The HT will come up in the remote control mode with the display indication "RC" on one band and the normal display on the other band.
To get the HT out of the "RC" mode just repeat the MR+PTT+Poweron sequence
Oct 30, 2008 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Sanyo Z2000 No Display
see the dealer. its a new unit so they must sort the problem
Feb 23, 2008 | Sony VPL-CX75 Multimedia Projector
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
