Question about Sunbeam SCM631-UM Cool Mist Tower Humidifier
Need a replacement water tank for sunbeam scm631 cool mist tower humidifer
2 Suggested Answers
  • 123 Answers
SOURCE: sunbeam ultrasonic cool mist humidifer model 700
The Problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck.
Posted on Apr 21, 2008
When i plug in my sunbeam humidifier I get an er on the screen what should i do
Impossible to know without communicating with Sunbeam. "ER, ERR" and the like are normal failure mode displays whenever the unit can not operate as normal. As there are electronic components involved, a failure of any one will fault the unit.
And it could also be something as trivial as a buildup of scale on the water sensors. (Have you tried a thorough cleaning of the unit?) I would first try soaking the water chamber in white vinegar for several hours.
It that does not fix it, it's probably done for.
Jan 03, 2016 | Sunbeam SCM631-UM Cool Mist Tower...
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
Dec 19, 2009 | Sunbeam Health at Home Warm Mist...
Kenmore HW305 Humidifier putting out hot steam...Is that normal?
this is a steam and misting type humidifier, the water tanks will not heat up, the heating element is internal to the unit, just make sure you clean it periodically and I would suggest having a fan asst to help move the humidification around the room, hope that helps
Jan 20, 2009 | Kenmore Humidifiers
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Sunbeam ultrasonic cool mist humidifer model 700
Good Luck.
Feb 17, 2008 | Sunbeam Ultrasonic Humidifier
Working, but not blowing mist.
I think I found the problem.
unplug humidifer, remove top tank, empty all water out of base. dry off.
turn unit upside down.
unscrew five visible screws.
use a screw driver to pull off the black foam foot pads. you will find more screws there.
pull off the base.
look next to the fan, you will see a metal "tower" going up into the reservoir. Is it dirty such as white chalky substance on it? Clean it with cotton swabs. Clean the fan while your at it if needed.
You will see a small gray box with two metal tabs twisted. Untwist them and pull off the top.
On that metal "tower" you will see a small black chip connected to the circuit board where you just removed the metal top. Does black chip have black marks on the circuit board? Mine does. I suspect the "tower" which draws heat from this black chip was no longer able to cool because of the white chalk buildup on the tower, furthermore, the chip became too hot and caused the black chip to overheat (again black marks on the circuit board).
The chip has on it "FTR 02N" and a "54F" at the bottom. I tried doing some basic searching on internet to see if it could be replaced, but didn't find anything.
For those who don't have this problem yet, just keep that metal cooling tower clean.
Dec 08, 2007 | Sunbeam 701 Humidifier
Sunbeam SCM631-UM Cool Mist Tower Humidifier Logo
228 people viewed this question
Top Sunbeam Humidifiers Experts
Paul Sikkema
Paul Sikkema
 steve
steve
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
