Question about iHome IC50 FM Stereo Alarm Clock Radio
When listening to music from my galaxy SIII on the ic50, it keeps shutting off every 3 minutes even though music continues to play. It does not do this when radio is playing. Any way to disable this
  • Tracy Greco May 24, 2013
    It does the same thing when I am playing my iPod...I'd like to know how to fix this as well.
  • afropuff1976 Jul 18, 2013
    me too...have you found a way to fix this??
On my Samsung Galaxy note 3 suddenly when I play a you tube video after a minute the picture freezes but the sound continues to play! Any suggestions how to fix this please?
Having same issue on my Note 3 recently on every video on YouTube. Video stop playing every 20-30 seconds but audio keep going. I have to touch position slider every time to make video playing again. Happens multiple time for each video. My friend suggested me to go for Mobile phone repairs
Samsung Galaxy Note 3
Nov 19, 2014 | Cell Phones
How to unlocked the unit of Samsung Mobile Samsung Galaxy SIII GT-i9300 16GB - Marble White???
It depends on many factors e.g. country/carrier etc. The best way is to contact Samsung and request a factory unlock code (not cheap though)
Oct 13, 2014 | Samsung Galaxy Siii Gt-i9300 16gb Marble...
Samsumg galaxy tab 3 shuts off every 30 minutes
Check the power settings to see if that is the cause of it shutting down. Streaming music does not produce the keep alive activity that is required, so it thinks that it isn't being used and turns off.
Mar 19, 2014 | Samsung Galaxy Tab Tablet PC
My jam speaker is paired with my galaxy tab 2. I have been using it To listen to music and it has been working. I turned the speaker of and a couple hours later went to put it on again and when I did the...
I have a similar device. If you didn't un-pair it or you moved the speaker too far away or didn't play music for over 5 minutes it shuts down. It may show that it is paired but doesn't play on the speaker. You have to un-pair and re-pair the speaker for it to work again.
Nov 09, 2013 | Tablets & eReaders
How do u make it stop moving when u play music?
While your iDog AMP'D is in "Listening Mode", hold down it's tail, and press it's nose. Make sure that you keep holding it's tail down the entire time, even after you pressed it's nose. You should see a spinning light pattern, that signifys that the motor movements are off. To turn them back on, either turn off/on your iDop AMP'D, or do the same thing but hold it's tail upwards. If your iDog AMP'D growls instead, that means it was not in "Listening Mode", and simply wait for it to start showing light patterns to music, then try again.
Hope this helped!
Jul 02, 2009 | Hasbro I-DOG AMP'D
The radio on my Coby 610 turns off after 3 minutes of play
I don't think I am actually solving this, but I think I may have a reason why it is happening. I am having the same problem with the radio turning off after about three minutes (I, too, had to reinstall the firmware).
I think the system sees the player as "inactive" when in radio mode and shuts down after a few minutes of "inactivity" -- even though you are, in reality, listening to the radio. The exact same thing happens when you pause an MP3 you are listening to; the system will see the player as inactive (because the music is paused) and shut down after a few minutes.
Maybe there isn't anything in the system (firmware?) that can differentiate the inactivity of just listening to music coming in through an antenna and the inactivity of paused digital music?
Feel free to send this to Coby tech support and see what comes back.
Apr 02, 2009 | Coby MP-610 MP3 Player
My Zen Keeps Shutting off even though it is charged, I turnit on and when I press play it shuts down
my mp3 player keeps shutting down after 10 minutes of play even thought the battery is charged
Oct 06, 2008 | Audio Players & Recorders
iHome IC50 FM Stereo Alarm Clock Radio Logo
74 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
