Clothes retaining water after final spin
I have had my front loader for approximately eight years and on a few occasions have experienced this problem but it does not seem to be correcting itself. It washes but does not extract all the water from washing load. After the cycle is complete, clothes are 'very heavy' as water has not been extracted. I have tried putting clothes through the final spin cycle again to hopefully remove the water but this is not working. I am not aware of any filters etc. that I should be checking, other than where the washing power is placed - which I regularly clean. I no longer have the instruction booklet so if you can offer any advice, it would be greatly appreciated.
    Scholar:
  • 89 Answers
It seems that your washer might be on its final leg, my friend. because its laying on its side you do not hear the belts slipping as you would a traditional washer. now the belt (or belts depending on your model) but if it has been slipping for a while the pulley could be grooved and that will only speed up your next belt wearing out. the pulley can be replaced. its just up to you on what you want to do. another thing the motor could be getting weak as well. best thing is to have a tech take a look and give you his synopsis of what is wrong.
good luck
Jason
Posted on Jan 19, 2009
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Kenmore front loader tub fills with water when not in use
your water fill valves are leaking severely,you should see water dripping in there all the time if its this bad and your clothes should still be wet,not damp even after a good spin after the final spin
Mar 23, 2010 | Kenmore 43142 Front Load Washer
My front loader, model #FTF30ES1 won't spin out
This could be due to water discharge. Clean filter/ pump if needd be could also be slow motor speed , worn belt/ brushes in motor. good luck
Nov 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Front loader washing machine is not draining
Hi Is this a whirlpool? Sounds like something is in the pump or the pump is bad.
Get me model # and I can help you further. Thaks
Vic
May 16, 2009 | Washing Machines
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
OLDE WASHING MACHINE LEAKING AFTER FINAL SPIN BUT NOT ALL THE TIME
Not too familiar with top loaders. With front loaders good pressure is required to keep the inlet valve closed, when not in operation. If the pressure is not there water leaks even when the machine is off. The problem cld be with the pressure from your faucet or your inlet valve; mysterious why it happens after the final spin, & your second machine.... I can't be of much help here. You hv to surf......
May 31, 2008 | Kenmore Washing Machines
No final spin
is there stil standing water in the unit at the end??
Jan 26, 2008 | Frigidaire GLTF530DS Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
