Question about HP LaserJet 4200n Printer
When printing a 40 page report, my HP 4200 printer prints about 30 copies, then spits out ablank sheet & paper jams
Prints 30 of 40 page report,blank page,thenjams
  • HP Master
  • 1,121 Answers
Check pick Tray 2 up rollers surface, if its soft replace them.. try..
Posted on Jan 06, 2013
  • Vinaya Kumar Kuchipudi
    Vinaya Kumar Kuchipudi Jan 10, 2013
    Its tray 2 pick up rollers.. Sorry for spelling mistake.. & see the snap shot of pick up roller
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
PeteG0429
  • 34 Answers
SOURCE: My printer HP Photosmart C7200
Here's a solution. Easy fix. Hope it helps!
Posted on Apr 02, 2009
SOURCE: my HP printer spits out a blank page before printing document
I had same problem with hp psc 2410 all-in-one. Finally ran "HP all-in-one Series Web Release Uninstaller version: 4.1.1.00.1332 (3/20/2007) that I had downloaded several years ago. Then plug and play took over and installed the correct driver that Vista kept insisting I already had.
Posted on May 09, 2009
SOURCE: prints hieroglyphic rubbish in the middle of printing mult copies
MY HP PSC 1410 WILL NO LONGER SCALE PHOTOCOPIES TO LARGER SIZE THAN THE ORIGINAL.
Posted on Jul 13, 2009
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
Hp4620 wont copy pages
Hi try removing the print head, run it under the tap, dry, then replace the head and retry
Aug 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
How do I repair Paper jam message but no jam
First step is to unplug your printer, leave it unplugged for 30 seconds and then plug it back in.
Aug 03, 2014 | HP Hewlett Packard Laserjet Pro 200 M275nw...
Hp laserjet 4200 will print a 50 page paper path test, print an extra page and then jam.
The paper feed solenoid is sticking. There is a foam material that deteriates over time and becomes sticky. I remove what's left and put masking tape in its place.
Oct 03, 2012 | HP LaserJet 4200 Printer
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
My HP 2600n printer always jams if there is more than one sheet in the paper tray. If there is only one sheet in the tray, it never jams but if there is more than one sheet, the first prints and while its...
Hello ,
The pad of solinoied become teared & only gum left on solenoied by which on the paper picking proces it fix on the base,by which the picking rooler continious mooves & pick another paper & become jam.so clean that path & remove the gum & paste the tape .your problem will be resolved 100%.
jm
Sep 07, 2011 | HP Color LaserJet 2600n Printer
My printer will not print any documents, it does print a test page, when I select print the paper is ejected. I have re installed the software.
Try to print a self test page from the printer directly using the below steps....
  1. Make sure the printer is loaded with plain, white paper. Remove any special or colored paper.
  2. Press Setup on the front panel of the product.
  3. Press 1 , to select Print Report , then 5 , to select Self Test .After you have the report printed, check for 4 horizontal color bars in that report, the first color should be the the black one, if the black one is missing, issue seems to be with black cartridge, that may be the reason the printer spits out blank paper, try to replace the black cartridge and then copy if it copies or not.
Sep 26, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Prints hieroglyphic rubbish in the middle of printing mult copies
Jul 13, 2009 | HP Photosmart C4480 All-In-One InkJet...
HP LaserJet 4200n Printer Logo
205 people viewed this question
Seeker5211
Seeker5211
