Question about ASUS Essentio CM1740-02 Desktop 2.4GHz 4GB 500GB DVDRW
Asus CM1740 installed week ago now no video to monitor
I installed at my parents , installed old hd to move all pertinent sw and all working fine hooked up to hd tv to view streaming movies wireless working fine,checked cables all appear fine the old hd was wiped after all sw transferred. Turned on and off correctly as far as I am told. Any ideas would be appreciated since I'm in Florida and they are in Dallas and hard to fix remotely if it will not at least start up....Kirk
  • ASUS Master
  • 18,201 Answers
After you wiped it, did you reinstall Windows 8? It has to have an operating system on it to do anything.
Computers will not normally connect to a television if you are trying to use it as a monitor.
If the computer is completely dead, check the power to the Power Supply Unit and if there is any voltage coming out of it? Is the fan in the PSU running. There is a glass fuse inside the PSU. If that checks out, remove and reinsert all the memory, the connectors to the motherboard and any cards in the slots.
ASUS CM Series CM1740 Specs
Posted on Jul 09, 2017
Check all the leads first. If leads are all good and the system is powering up, you should check for a failed RAM stick.
Jan 05, 2013 | Computers & Internet
Cannot get monitor to hook up with the new asus computer
? VGA or DVI ? Make sure monitor is set to correct input type, including HDMI.
You may have to log in Safe Mode and lower screen resolution if you have an old monitor that does not support high graphics.
Nov 24, 2012 | ASUS Essentio CM1740-02 Desktop 2.4GHz 4GB...
Intermittent-monitor loses pic for 1 or 2 seconds
So did mine until I upgraded the Video Graphics drivers
Jul 25, 2012 | ASUS Cm1740-us-2af Desktop Computer - Amd...
I installed ASUS EAH5450 video card. Ihave Dell Vostro 200 series with Apple 21" monitor. Computer used to work fine with this monitor and old card which went bad. Now my computer is very...
Hi ,
You are probably facing a power supply issue , though this device isn't exceptionally gready in power consumption .
You will need to replace the PSU by a larger one . 450 Watts will do but don't hesitate to go for a 600 W since these units are fairly cheap .
Best regards
Apr 22, 2011 | ASUS EAH5450 SILENTDI1GD2 graphics adapter...
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Dec 29, 2010 | Princeton Digital VL173 Monitor
I have 256mb pci xpress en7300 gs geforce graphics card of asus company some moths ago its working but one day when i on my pc it cannot dislpay anything monitor light remain yellow but from other slot of...
Hello sifian_786, did you try to uninstall old video driver and restart computer and go to nvidia website and download latest driver for you video card and install, restart computer this should solve problem you have, are you trying to run dual LCD monitors ?
Nov 24, 2010 | ASUS EN7300GS/HTD GeForce 7300 GS, PCI...
Problems booting
It could be either the monitor cable, monitor or motherboard that doesn't work. It could also be that you are running a BIOS version too old to support your new parts. I would try to update the BIOS and then troubeshoot a little to find out if, and which, part is broken.
Jun 11, 2009 | ASUS P5N-E SLI Motherboard
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
New cpu but no video output
Feb 28, 2008 | Intel Motherboard
ASUS Essentio CM1740-02 Desktop 2.4GHz 4GB 500GB DVDRW Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
