Question about Milwaukee Saws
Help... my blade will not stay in the chuck on my reciprocating saw from milwaukee. It is very frustrating. How do I tighten it so it will not come out in the wall
Help
    Champion:
  • 304 Answers
If it does not clamp then it needs checking out, it could be a bit missing.
Posted on Jan 06, 2013
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Milwaukee reciprocating saw blade piston turns,
yes it can, probably the spindle or the primary wobble plce I would also check the conition of the front bushings and also the rear. You can go to Milawukeetool.com for a parts exposion on this tool.
Posted on Mar 17, 2010
  • 377 Answers
SOURCE: I bought a Dewalt DW310 reciprocating saw and
The blade clamp collar is a spring loaded knob of sorts that holds the blade in place. If you are not able to pull the blade shaft out of the saw to get at it, plug the saw in and hit the on/off trigger a few times to get the shaft and knob out of the body of the saw. Once you can get at the knob it should be easy to turn it and insert a new blade. Let me know if you have problems.
Posted on Aug 31, 2010
rowdy45176
  • 2176 Answers
SOURCE: The chuck for my reciprocating saw seized up due
use some penetrating fluid and gently work it back and forth until it frees up, the replacement parts cost around 20.00 if you need them. Let me know if you need more assistance
Posted on Sep 12, 2011
  • 3 Answers
SOURCE: Saw blade loosens no matter how much or often I
There is a little blade retainer pin that is supposed to lock the blade in position. If you accidentally miss-align a blade when tightening the blade clamp, the tightening screw will "press" the retainer pin out, so that only the tightness of the clamping screw is holding the blade. You will get 10 to 30 seconds of cutting action, then the blade will loosen again, till the blade clamp screw strips.
Have not found a replacement blade-clamp anywhere.
Posted on Feb 06, 2012
How do I remove a sawzall blade in a ten amp Milwaukee that's flush at the keyless chuck?
Take the clamp apart by removing the spiral ring that holds the collar on and then remove the pin. Make sure you write down how to put it back together! Once you remove the pin everything else will come off easily! diagram the whole thing as you go!
Nov 04, 2014 | Milwaukee Tool Saws
The chuck for my reciprocating saw seized up due to rust. It is the turn style chuck. How can I in seize it?
Sep 12, 2011 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
My keyless chuck will not tightten all the way closed....seems to catch on something
Open the chuck and see if the screw inside the chuck has backed out. The screw is left hand thread so you will need to turn it to the left to tighten it. It may be an allen or Torx head screw.
Jul 15, 2011 | Milwaukee 2690-24 18-Volt Hammer-Drill,...
Reciprocating saw problems cannot get broken blade out of chuck
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 15, 2010 | Dewalt Saws
How do i change the blade in a reciprocating saw?
heatman101
Aug 05, 2010 | Skil FactoryReconditioned 920501RT 85 amp...
Motor on my sawzall 6572 runs but blade does not move. Blade locked in tight. No reciprocating motion.
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
Jul 27, 2010 | Milwaukee Tool Milwaukee 10 Amp...
Blade stuck in keyless chuck on sawzall. pin or spring must be broken. Any suggestions on how to get the blade out
heatman101
Jul 14, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Cannot get the blade out of the porter cable reciprocating saw
heatman101
May 27, 2010 | Porter Cable Variable Speed Quik Change...
Milwaukee reciprocating saw blade piston turns, allowing blade to flip flop around. Can this be fixed?
Mar 10, 2010 | Milwaukee Tool Milwaukee 10 Amp...
VULCAN RECIPRCTING SAW
heatman101
Jan 08, 2009 | Vulcan Pwt 18V Rs 18V Cordless...
Saws Logo
71 people viewed this question
Top Milwaukee Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Jim London
Jim London
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
