Question about Maytag EPIC MFW9700S Front Load Washer
Maytag 5000 series with steam code f30
While washing, the stopped and was flashing "f30"
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Posted on Jul 03, 2009
SOURCE: maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Posted on Jan 03, 2011
SOURCE: My Maytag 5000 front leader
We had the same exact problem. Service tech came out and diagnosed bad pressure switch, Part # W1015652. Swapped it for a $135 new one and it seems to work just fine now.
This would have been an easy fix for me to make had I known what to look for. Unplug and shut water, remove top cover, follow small diameter (1/4"?) black tube up from wash drum to where it plugs into the plastic pressure switch housing. Remove switch from its bracket, unplug wire harness and black tube, and replace.
Service tech said that this is due to using too much detergent, suds will creep up into the pressure tube from the wash drum and get into the small circuit board inside the pressure switch housing. He also recommended against using Kirkland Signature brand detergent even though it has the HE emblem on it. Best to use one of the major brands and only 1 to 1.5 tablespoons at most.
A google search for "Maytag 5000" reveals that this is a major problem because it is the 5th search result. "Maytag 5000 problems" search shows that this is the #1 problem with these washers.
soundman4305
  • 40 Answers
SOURCE: what does code f35 mean
I found this for you:
"F35" Analog Pressure Sensor Failure
If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  • Press the Pause / Cancel / Stop button twice to clear the display.
  • Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Posted on Mar 07, 2011
jsrock516
  • 5911 Answers
SOURCE: my maytag 5000 series steam
"F21" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system. Most commonly, this is an indication something is lodged in the drain pump or the inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. On some model washers there is no screw off cap on the pump and you will have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Removing the inlet hose for inpsection is recommended on all these washers just to ensure there isn't anything lodged in the line. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: The washer will not complete a wash cycle until the conditions causing the error are corrected. In addition, a "SUD" or "SD" (Suds lock) error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are very simple repairs that you can perform yourself without the assistance of a repairman.
If the wash tub is full of water, you may want to use a wet/dry shop vac to pull a vacuum on the drain line and drain the wash tub. This will minimize any potential mess you may have to clean up.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: The error codes are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
NOTE: If you determine the pump to be defective, and the pump housing is still in good condition, you only need to replace the pump motor. However, the pump is usually sold as an entire assembly and the motor CANNOT be orderd as a separate item. There are several outlet stores that advertise on ebay and sell the pump motor for much less than ordering an entire pump assembly. Replacement is simple and you do not have to remove the pump from the washer. Just drain the pump as previously mentioned and disconnect the electrical plug from the motor. Remove the three screws holding the motor to the pump housing and replace as necessary. Just make sure the o-ring is intact and in place. To get a good seal, you can lubricate the o-ring with a thin film of petroleum jelly.
NOTE: Newer model Maytag washers are manufactured by Whirlpool. These instructions apply to Whirlpool Duet, Kenmore Elite and Maytag Epic series appliances.
Posted on Mar 17, 2011
F 22 code on my Maytag 5000 series with steam how do I fix it?
F22 is a front door lock code. To fix try selecting PAUSE/CANCEL TWICE TO CANCEL CODE
Oct 25, 2017 | Maytag Washing Machines
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
MAYTAG 5000 SERIES WITH STEAM WASHER WONT START
the lid isnt being detected as closed
the switches have a fault in them
Dec 05, 2014 | Maytag Washing Machines
Manual for Maytag 5000 series with steam
Hello, am having some problems with my MAYTAG 5000SERIES WITH STEAM. i cannot operate with it!
Aug 13, 2012 | Maytag Dryers
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
What does the F30 code mean on my Maytag washer?
I just spoke to a repairman who claims he's been working on Maytag washers for twenty years and has never heard of an F-30 error code. He says all Maytag error codes are four digits, and this isn't a real thing. Like I'm lying. While he's saying this, I'm watching the F-30 code flash on my machine. My God, you can't find anybody who knows how to fix anything any more...
Sep 01, 2011 | Maytag MAH6700AWW Neptune Front-Load...
F30 code on 3000 series washer
I don't know the answer, but you can call Maytag @ call 800-688-9900 toll free for a code definition
Feb 26, 2011 | Maytag EPIC MFW9700S Front Load Washer
Screen reads CF1, and does not work
Maytag 3000 series .Dryer screen reads CF1, then CF2... then Cf3 and does not work
Apr 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
F30 code
F30 = DISPENSER SYSTEM ERROR
You might have to replace the damaged one.Or in other words something that cannot be repaired.Well came across this info through other certified websites.good luck.hope this helps out.
Jan 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
126 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
