Question about Fuji Finepix S5800 Digital Camera
Fuji finepix s5800 flash does not pop up completely
Flash not completely popping up, I have to hold up manually
3 Suggested Answers
SOURCE: the pop up flash on
i have the same problem as above can it be fixed please
regards tony
tony_dj@btopenworld.com
Posted on Oct 17, 2009
  • 4 Answers
SOURCE: Fuji s5700 my flash is not popping up on auto
Don't blame the Fuji Designers for this fault - it was the Fuji Bean Counters that are at fault - the flash design is for TWO springs, the plastic casting has the holes for a second spring on the other side - which wasn't fitted so 100% overloaded the single spring mount.
Anyway if you are brave and handy you CAN fix this.
First remove the back of the camera - 3 screws in battery bay, 1 in the side above the memory card door, The two rear most on the bottom, two in the USB/video door, and the rear most on the left hand carry strap bracket.
Carefully prise the back rearward about 5 to 8 mm.
Now take a look at the two screw holes under the flash (when popped - or flopped out now that is broken) now go and bend a screwdriver of the type you used for the previous screws - you will need a 90 degree bend very close to the tip to fit in this gap and be able to turn the screws a few degrees at at time.
A little at a time lock the screwdriver into the screws and undo until the flash cover comes off.
You can then slide the shaft out of the flash to release the spring which will have the end that should fit into the broken bracket now sitting proud..
Make a suitable bracket like the one in the photo attached to slide over the broken plastic bracket.
make sure it fits really well the epoxy into position.
Getting the spring back in is a fiddly job - I found the best way was to fit the end of the spring into the new bracket, slide the shaft just into the spring - the lever the other end of the spring down into the back of the flash body and then slide the shaft all the way into place.
I did have to file down the little plastic "blade" inside the lid which presumably is designed to assist the the (now broken) bracket from breaking....
reverse the dis-assembly and now you should have a working flash bb61266_2.jpgbb61266_1.jpg
Posted on Dec 05, 2010
Flash repair on fujifilm finepix s5800
When you say flash repair, what exactly is the problem ?
Dec 23, 2016 | Fuji Finepix S5800 Digital Camera
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
Flash fault S5800
If blub not flashing then its a flash tube cut off & need replacement.
Aug 09, 2012 | Fuji Finepix S5800 Digital Camera
Nikon D40. How do i force the flash to work in daylight?
First, you have to be in one of the PSAM modes; in the other modes the camera decides whether it needs the flash and in daylight it will decide there's enough light without it. So, after turning the model dial to one of the PSAM positions, press the flash button on the front of the camera to pop up the flash. In these modes the camera will fire the flash if it's popped up, and not if it's down.
To change the flash mode, hold down the flash button (after it's popped up) and turn the command dial. Depending on the chosen exposure mode, your choices may include Fill flash, Red-eye reduction, Rear-curtain sync, Slow sync, Rear-curtain plus red-eye reduction, and Rear-curtain plus slow sync. Refer to the "Flash Mode" section of the manual for full details.
Jul 30, 2011 | Nikon D40x Digital Camera
Flash will not pop up
Alot problems with this...
The pop up flash only pops up half the way. We had a large dinner party the other night and tried to take pics only to find the flash would not go off. Later, I manually lifted the flash all the way open and took pic and flash did go off. Battery fully charged. In auto mode. Camera only 2-3 years old! Really upset. Went to the web to see if others have same problem AND THEY DO!!! Several have the half pop flash and resolve it by holding the flash up manually. So thought this was a global problem and Chatted with Kodak Customer Service (puleeese). They said, sorry, but $150 to fix or 25% off upgrade camera.
Think it before take some choice.
May 19, 2011 | Kodak EasyShare DX7590 Digital Camera
My Fuji Finepix S5800 tells me my brand new batteries are flat.
It sounds like you have bad batteries. I have had rechargeables that have suddenly done the same thing. I have learned that buying really cheap ones doesn't work out. If you buy a good branded set, I think you will find that they are much better. :)
Jul 17, 2010 | Fuji Finepix S5800 Digital Camera
My Fuji s5800 camera has a 'zoom error'
try pressing the unzoom button and holding it for a couple of seconds until it fixes itself. and if it makes a noise, till it stops!
Apr 10, 2010 | Fuji Finepix S5800 Digital Camera
How do I fix the pop up flash on my fuji finepix s700
fix the pop up flash,,,,select manual M operation,flash donot pop up.
Apr 03, 2010 | Fuji FinePix S700 Digital Camera
The flash will not fully release, only opens up
Having the same problem. We rig it by tucking the strap into the pop up flas to hold it up...
Dec 05, 2009 | Fuji FinePix S700 Digital Camera
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
Fuji Finepix S5800 Digital Camera Logo
219 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
