Question about Vizio L32 32 in. LCD HDTV
Olevia 42" lcd tv won't turn on.
It had a bad fuse. We replaced it and it immediately blew when we turned it on. I don't think it is the power inverter board as it doesn't turn on at all. Could it be the rectifier diode? Can it be tested? thanks
    Problem Solver:
  • 15 Answers
Check your power board not the inverter board. Caps, diodes usually go first. get them replaced with a higher voltage capacitor, same value (1000 uF 15v with a 1000 25- 35v is ok)
Posted on Jan 24, 2009
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
Olevia 537-b11, blue light won't come, even when power cord is replaced. Please help!!!!
Since you've already replaced the power cord and still the led light won't came on, this is an indication that the power supply board of your unit is dead. If it is not under warranty period(if so, avail it because the manufacturer will fix it for free) open the back cover and check the continuity of the fuse using the multimeter, if you found it open replaced it with the same current(ampere) ratings and then try to turn on the TV. If the replacement fuse blew again, this is an indication of more serious problem on that board. If the replacement fuse didn't resolve the issue, other parts on that board gone to malfunction as well. If this is the case, I would advice you to replaced the entire board for your convenient. The cost will almost the same rather than troubleshoot it. Check the actual part no of your board and check this LINK.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Sep 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Blew fuse, replaced it,turned it on and fuse blew.... options?
There is something wrong inside that is causing the fuse to blow. The fuse is the first defense in protecting the rest of the TV. The internal voltage regulator could be bad which is causing the internal power adapter to send too much voltage and current to the rest of the tv. The fuse responds to current going through it than what it is rated for.
With that in mind be sure to not stick in a bigger fuse as it could cause the tv to work for a while until something else gets damaged or the tv smokes.
Jan 02, 2010 | Olevia LT32HVM 32 in. LCD Television
My Olevia 42 inch wont turn on the blue light isnt even on, The TV is only 2 yrs old
Mine had the same problem. You simply remove the dozen or so screws on the back and pop the back off. If you follow where the power cord goes into the tv and trace the wires you will see a small fuse. I believe it was a 5amp and cost less than a buck. I'm not sure why mine blew but I have had no issues since.
Dec 29, 2009 | Olevia LT42HVi 42 in. LCD Television
Olevia 747i won't turn on, no blue led light? Help!
I would start with the power supply. Possibly a fuse. 9 times out of ten though if a fuse goes, something inside the set is causing the fuse to blow.
Oct 13, 2009 | Olevia LT42HVi 42 in. LCD Television
Olevia 242-T11
Screen went black unpluged won't even turn on.
Dec 27, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia 42" model # 542bl
Facing the back of television, if it occured while putting top right screw, that is because, you screw touched power module casing and the fuse inside the TV is gone. All you need to do is goto radio shack or any local store and get a replacement fuse (250v x 5 Amp) and replace it. It may cost you less than 2 bucks.
Symptoms:
TV powers off and never turns on.
May even power in that room or house may have been tripped.
Resolution:
lay the TV face down on the floor.
Remove the screwes ( may be 10 - 15 screws)
Remove rear casing of the TV. It is single casing covering entire rear face of the TV.
Fuse is visibe as soon as you remove the casing.
Replace the fuse.
Put the casing back.
Start enjoying the TV.
Prevention:
Do not use longer screwes to mount monitor brackets on TV casing.
GOOD LUCK!!!
Sep 17, 2008 | Olevia LT42HVi 42 in. LCD Television
Vizio L32 32 in. LCD HDTV Logo
314 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
