Question about Soyo DYLT032D 32 in. LCD Television
My soyo 32" flatscreen will not turn on
The green power light turns on as well as the red off light but there is no image or anything for that matter on the screen
  • Soyo Master
  • 933 Answers
Do you have sound? If you have sound but no picture, it is possible you have a backlight problem. Let me know
Posted on Jan 06, 2013
SOURCE: Soyo 32" LCD flat panel
don't buy soyo mine doesn't work either
Posted on Apr 04, 2008
  • 4 Answers
SOURCE: Soyo 32
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Posted on Jan 20, 2009
SOURCE: Soyo 32" won't turn on
The problem is the capacitors on the power supply board. There are two of them, the rating is 220uf - 250v - 105C (M). The back side of the capacitor says V9A PET. You need to remove the board, make sure the capacitor is drained, (you can do this by placing a screwdriver across the posts) Use a soldering iron and remove the capacitors. The only place that has replacement parts is at www.mouser.com, Install them, make sure the polarity is correct, re-solder them back into place. Re-connect the board and it should power back up correctly. Good Luck. Steve
Posted on Jul 27, 2009
  • 8457 Answers
SOURCE: my soyo lcd tv is not turning on properly..It
Ur main video backlight board is dying or dead much be replaced.
Posted on Oct 22, 2009
  • 8457 Answers
SOURCE: Red power light flashes red
Power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 03, 2010
My flatscreen won't turn on it keeps going red to standby
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Power supply looks like this:
Please follow this step on how to fix that problem on your own..
  1. Open the back cover of your TV.
  2. Look at the power supply board..Its normally connected to the power cord..
  3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
  4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
Try to watch this video about capacitors and how to replace it...
I hope this solution will be helpful...
Thanks for using fixya...
Nov 22, 2011 | Emerson LC320EM8 32 in. LCD TV
My soyo wont turn on there is a red light blinking light what could that mean? blinks evey ten seconds
That is an error code of sorts for that brand - I'd open it up and check the power supply for bad capacitors - leaking at the top or bottom - bulged at the top etc - replace them or the power supply and go from there.
Thanks,
Michael
Feb 06, 2011 | Soyo DYLT032D 32 in. LCD Television
My flat screen tv does not have a picture or sound. The stand by red button is on once we press the power button the picture will come on with a message that reads digital television for about a second or...
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Sep 03, 2009 | Emerson LC320EM9 32 in. LCD HDTV
I have a soyo turns off every few min and the i
Ur power board about to go bad.
Go to the net buy the new power board.
Aug 13, 2009 | Televison & Video
Turning on the monitor
Could the batteries in the remote be dying. Did you try changing them?
May 31, 2009 | Soyo DYLT032D 32 in. LCD Television
I have a LG 32 in flatscreen. It wont turn on. The green light blinks and I see the monitor light up some but no picture or sound. I can not see the menus or anything else. What can I do to fix this? I...
hi..the reason due to this problem may be
due to the circuit board.If the soldering is not
done in any part of the main board this type of
problem occurs.check the board completely.
check this out..
thank u..
rate me..
Feb 10, 2009 | Philips Televison & Video
PLTV-26
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
Dec 11, 2007 | Protron PLTV-32 Television
Soyo DYLT032D 32 in. LCD Television Logo
62 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
