Question about Home Security
Just bought a sentry safe model num: HO60ES with the keypad and cant get it open at all! manual says to remove the key lock pad by twisting it off but cant get it off. can someone please help me???
5 Suggested Answers
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Posted on Apr 27, 2009
  • 80 Answers
SOURCE: Sentry Safe A3750 won't open new batteries
http://www.sentrysafe.com
call them
mj
Posted on Sep 07, 2009
  • 57 Answers
SOURCE: I have a sentry fire safe with an electronic lock
Normal 0 I found this hope it will help. So I called the sentry safe company, (800-828-1438), and waited for about 10 minutes to speak to a representive, (that was alright since I have a speaker phone). The first thing they asked me was about the condition of the batteries. I told them that they were brand new. The person then asked about the brand name and expiration date of the batteries. They were generic batteries, but the expiration date was fine. They suggested a new set of batteries, and mentioned that I could bypass the battery pack, (which sometimes fails), by unplugging the pack and using a regular 9 volt battery.. So just to cover the base, I went down to the store and obtained a brand new 9 volt duracell battery. I unplugged the battery pack and plugged in my new battery. I then pushed the combination numbers and my safe again failed to open.
I called the sentry company back using my speakerphone feature again while waiting to speak with a technician. The tech asked me about the batteries and I told him it had a new 9 volt at the last technician’s recommendation. The person began to talk about the actuator cylinder inside the safe, stating that it did not sound like it was actuating. Then they told me something that really made me wonder about the quality of this safe. They told me I would need to hit the safe with a rubber mallet in an attempt to get the actuator to engage so I could open the sentry safe. OK, so the safe is supposively built to keep my belongings safe from thieves and fire, but now I am going to fix it with a rubber mallet? Good thing my sentry safe was inside, somebody might have wondered about my mental state if they had seen me beating this fireproof safe with a rubber mallet! (PS: If you use the rubber mallet option or any other suggestions that sentry’s customer assistance supplied, and have firearms or dynamite in your safe, you do so at your own risk, use wise judgement for your own safety)
Well it just so happens that I had a rubber mallet and did not need to once again go to the store to get something to personally fix my great sentry fireproof safe. So I begin beating the sentry safe with this mallet and then tried the combination again. Woolah, It opened! I stopped for a moment and began to ponder how many other things I could fix with this magical rubber mallet. I mean, what about the TV, the computer, my fridgerator and that cell phone that always drops calls? Could it be that I have discovered the fix all to all mechanical issues? As I began to look at my belongings in my fireproof safe that I have just opened with a rubber mallet, I thought "so if I close the safes door will I need a sledge hammer next time"?
Time for another phone call, back to the speakerphone. The technician this time listened to my issue and asked me if I had some lubricant like WD-40 with a small tube that attaches to nozzle. I thought, "well of course I do, I was just using that to fix the broken water pipe in the garage." The phone tech tells me where to spray the lubricant on the inside of the sentry safe door. He has me do this in the open and closed combination positions, and it’s now opening when I press the combination numbers with the door open, hurray! The only problem is that after working in the lubricant a few times the handle on the door does not lock into the locked position. I no longer need the combination to unlock my safe, I only need a can of lubricant! OK, this is one really tough safe, what thief would ever think that they would need a rubber mallet and a can of silicon lubricant to open up a safe?
Back to the speakerphone, this time a lady technician. She wants me to get a screwdriver and pry off the plastic piece on the back side of the door. At this point I said to her, you have built a product that I need to have a rubber mallet, a can of 3 in 1 spray lubricant, and a screwdriver to open? She stated that she was doing all she could to help me fix my safe and asked me how long I had owned the safe. I told her about 2 years and she stated that it was out of warranty. I thought, well who needs a warranty when they have a magical mallet, a can of black led, and a screwdriver? Anyway she directs me to pry the plastic backing off of the door and when I do this little piece of plastic falls out onto the floor. I look at this little plastic piece pondering in my mind, what’s it’s part in all of this. Well the technician is directing me to look at the arms and gears and some arrows that line up between the metal arms and plastic gears. What’s wrong with that picture? Metal and plastic don’t really work together long before the plastic breaks. I had to wonder for a moment, is this some really expensive fireproof plastic? The arrows line up and with that information she directs me to the area of the actuator again, she says "you see the circuit board" and a little white button that sticks out from it?" I said well yes, I see the circuit board and the little white button you are talking about seems to be laying on the floor broken off. So I picked it up and said, "this little broken piece of plastic that connects to the metal arm on the safe is why the safe does not work right?" She tells me yes that’s the problem, that i have broken it and since it’s out of warranty that there is nothing she can do to help me. But she then asks me to hold on for a moment…..
She comes back to the phone sounding sincere, like she has just solved all my problems, and tells me that she has spoke to her supervisor and that they can offer me 10% off on any safe that I would like to purchase. I thought what great customer service, now they want to sell me another safe with metal and plastic pieces that break and give me a huge discount of 10%, and I bet it comes with a free maintenance kit which includes a polo stick, some lard oil, and a screwdriver on the rocks! Needless to say I declined their gracious offer.
I will say that all the organizations personnel, (that I spoke with), were courteous and trying to be helpful, (that was within the realm of authority they were given). With a product such as this, and the great customer service I experienced, I thought it was probably best to find a safe that was free of little plastic pieces that break off, cause those plastic pieces won’t save you 10% !
Posted on Oct 08, 2009
I have lost the combination for my safe model V330 my model number V330 Sentry safe
  • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Retype the user code to verify it is working, and then close the safe.
Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
Cant open my programmable key pad safe. the code wont work
Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 12, 2010 | Sentry Fireproof Safe
The Sentry V260 safe will not open. Replace batteries?
Locksmiths agree on how to install sentry safe batteries
reconnect the connector and put back the battery holder. Slide the cover back in place. How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
Mar 11, 2010 | Sentry Fireproof Safe
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
Mar 06, 2010 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Nov 03, 2007 | Sentry Fireproof Safe
Home Security Logo
121 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
