Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Price of Reddy Heater Professional Series 125T
tinytrees
  • 92 Answers
SOURCE: fuel filter
take the side cover of and you will see where the fuel line goes into the tank. typicall the cap turns clockwise to remove and the filter is hooked right to the cap.
Posted on Jan 27, 2009
  • 188 Answers
SOURCE: I need a wiring diagram
Here is a link to a owner's manual for a RL125T ... http://12.153.20.74/manuals/110429-01C.pdf. You can find a wiring diagram on page 19. I hope this helps you.
Posted on Apr 13, 2009
tbugger
  • 232 Answers
SOURCE: reddy heater professional series smoking not
Remove the top cover. There is an ignitor that glows at start up. Look to see if yours is functioning. They break easily and yours could be bad.
Troubleshooting tips
Posted on Dec 05, 2009
c7121
  • 160 Answers
SOURCE: IGNITER SWITCH
If you have one of these 125T Models- RH125AT, RHD125AT, RL125AT, RM125AT, RE125AT, M125AT, PKHD125T, TKU125T, UKU125T, RD125T
The web address is:
http://www.reddyparts.com/
There are 3 ways to order your part.
Posted on Dec 21, 2009
  • 120 Answers
SOURCE: Where can I find a
Pretty sure this is the manual as i think DESA make them.
http://www.fncuthbert.com/pdfs/masman1.pdf
Just cut and paste this link
Posted on Aug 31, 2010
Need to find pump pressure & nozzle part # for reddy heater 125T
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 05, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a Reddy heater 125T and the transistor for the ignition is burned into, i was wondering if it is possible to solder a new transistor to the board, and if so what would be the part number for the...
Yes, I have done it and got transistor from a electroic story. took old one to them and they match it. When soldering it on use very little heat not meld the other solder tracks. Ken'Repair
Jan 22, 2011 | Reddy HEATER RH125T 125,000-BTU...
Where can I find a manual for a Reddy Heater 125T?
Aug 29, 2010 | Reddy Heater RH125T Kerosene Forced Air...
IGNITER SWITCH
The web address is:
Dec 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 125t won't restart on its own after first cycle.
Sounds like a bad thermostat! (A common problem with this model) replace and it should work again!
Jan 30, 2009 | Desa International RH125AT Utility Heater
Fuel filter
Jan 26, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
RH125T won't fire
Not much to check. The element comes out and makes a square loop back to the ceramic portion. This element is extremely brittle and will break if touched or wiped off.
You can check the 2 wires with a voltage tester set on continuity. The needle should swap sides if the ignitor is intact. I don't ever remember an ignitor failing, except for breakage.
View this page. Be sure you get the correct ignitor. 2 different ones have been used on the RH125T.
http://www.reddyparts.com/125T%20ignitors.htm
Dec 28, 2008 | Reddy HEATER RH125T 125,000-BTU...
I need a wiring diagram for a Reddy Kerosene Heater Series 125T
Dec 26, 2008 | Reddy Heater RH125T Kerosene Forced Air...
REDDY HEATER 125T WON'T INGNITE
  1. Does the ignitor glow for 5 seconds when the unit is started?
  2. What is the air pump pressure reading?
These are the starting points for troubleshooting a heater that has an ingntor.
Answer these questions and maybe someone can get you started.
Dec 16, 2008 | Desa International RH125AT Utility Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
198 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
