Question about Radio Communications
Galaxy 94h no frequency counter
Counter doesn't light up, everything else ok
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Get a schematic of the radio and use a volt meter to check out the voltages coming to your counter.
Posted on May 18, 2014
SOURCE: Galaxy DX 88 HL jumping frequency
sounds to me like a bad PLL chip. but then again, I'm no Master tech myself.
Posted on May 27, 2008
SOURCE: frequency counter keeps going off frequency
i was told that i have a couple of chips going bad
Posted on May 30, 2008
SOURCE: Not a Galaxy DX-2517
It sounds like a galaxy saturn, dont know about the knob
Posted on Nov 13, 2008
SOURCE: Rolling Frequency Counter
I'm giving this info from the Master Edition of C.B. Tune-up manual Volume 1 year -1995. The original price of this info was $39.95 But I have had people help me with radio info. so here it is---- on page 60 it says [ Model ] : Galaxy Saturn ( and export models using the same Freq. counter module ) The most common problem with the { Galaxy Saturn } is after it has been on for awhile the read-out becomes unstable. And sometimes it will quit all together. This problem has been traced to a Zener Diode inside the freq, counter module. The square silver box located right behind the speaker. The Zener Diode inside marked D-603. This is a 2.4 volt , 1/4 watt diode next to IC-609 the ( LM-7808 ) regulator. REMEDY: change D-603 to a ( 2.4 volt , 1/2 watt diode) This should restore normal operation. {{{{ 357 - MAVERICK }}}
Posted on Apr 30, 2009
tbirdfan1
  • 3051 Answers
SOURCE: how to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Posted on Nov 14, 2009
Galaxy 94h no frequincy counter
hook up a frequency counter and adjust L14 and L15.
Jan 05, 2013 | Radio Communications
Galaxy 88hl frequency display only has decimal point, channel readout fine
on the face plate is a button for the counter ,try pushing it several times to see if the dot moves. As long as the channel display is reading the correct channel you should be ok but you want to correct this problem . If you can't correct it contact Galaxy and they will have a tech talk to you.
Nov 03, 2012 | Galaxy Radios DX- 88HL Base CB Radio
I have a Galaxy DX 99v and when i key up the frequency counter scrolls up and down on it's one.what can i do to fix it?
the voltage regulator in the freq.counter board is bed and probably a diode common problem that need to go to a professional not a DIY easy job
Sep 17, 2012 | Galaxy Radios DX-99V 40-Channels Base CB...
Galaxy 979 SSB Modulation Problem Voice Cuts Out.
It sounds like you had a cold solder joint. Leaving it in the sun probably temporarily corrected it. I would take it to a tech to have all the solder joints corrected, unless you are handy with a soldering iron. The problem will most likely come back.
All you have to do is pull the top cover off, which will show the bottom, or trace side of the board. Using a soldering iron, make sure any solder joint that doesn't fully look soldered and make sure the solder is fully covering the joint. If need you may have to add solder.
As for the frequency counter going nutty when you modulate, Don't worry about it. There is nothing wrong. Because when you modulate you are modulating the carrier signal you are changing the signal so the counter will interpret that as a different freq because it cannot differentiate. Freq counters are for use with carrier only. As long as the carrier shows correct, it is right.
Aug 11, 2012 | Galaxy Radios 979 40 Channel Am/ssb Mobile...
FC-347 causes radio's transmit frequency to jump around when plugged in.
I don't understand why anyone would want to install one of these when the radio already has one.
Jul 01, 2012 | Galaxy Radios Fc-347 Frequency Counter For...
FC-347 on a cobra 25 wx st
try to follow those direction as much as you can and if it doesn't work then try it a different way. Remember you need a power source and a source for the light to work.
Jun 23, 2012 | Galaxy Radios Fc-347 Frequency Counter For...
Galaxy 959 Testing TP3 for AM, LSB, USB with FC-347 or what other freq. counter can be used for this?
An external freq counter will always do a better test then the one on the unit . Do you have an oscilloscope? A function generator will also have a freq counter . Now the ultimate is a spectrum analyzer. you don't need all these but the function generator will work fine.
Jun 23, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
What are the buts & nubs go to make the cb work which ones trun or push ?
Assuming you're talking about the Galaxy DX88HL, and assuming the mad has been done to reach the 11 meter band, you press the band button in, that put's you to the E-H banks, select the E/A bank which is high bank E. with the frequency counter on, it should read 26.965 for channel 1. If it reads 26.975, then your +10KHz switch is on, turn it off. you'll then be properly set for 26.965 (ch.1) - 27.405 (ch.40). You also have 5 "hidden" frequencies, these are at ch. 3, 7, 11, 15 and 19. To get to the "hidden" frequencies, go to any of the channels listed and turn on your 10KHz switch. Those frequencies are not attainable on radios that do not have a +10KHz switch or a clarifier capable of sliding that far over. To do repairs and for a full list of schematics, diagrams and so forth, I suggest this site, it has the most coverage of the Galaxy DX88HL as well as other galaxies that I've been able to find. http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm .
May 25, 2011 | Galaxy Radios DX- 88HL Base CB Radio
its a mexican kraco clone,lol
Aug 09, 2008 | Galaxy Radios DX-2517 CB Radio
Radio Communications Logo
44 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
