Question about Kenmore 73932 Gas Dryer
The dryer wont spin
It stop in a middle of a load of laundry
  • James Chandler May 11, 2010
    too vage. more info please
  • 460 Answers
This information is not send to you with the intention of buying anything is just for you to know what is the spin problem
 http://www.youtube.com/watch?v=SSM-2qCC3Po&NR=1
to find out what is the problem test all the part  to see what is the problem.
Need a good meter to check all of this.
Was this helpful?
Posted on May 14, 2009
Dryer no longer hot
Could be the element, thermal overload, loss of one leg of the AC supply, a burned off wire or timer. Do you have fuses or circuit breakers? If you have breakers reset the breaker and see if the heat works. If you have fuses check each with an ohm meter. One leg of the 110VAC will run the motor but you need 220VAC to make the element heat. (that is if this is a 220VAC dryer).
Jan 06, 2014 | Samsung DV306LEW Electric Dryer
My dryer stopped heating and spinning in the middle of a cycle of laundry. Is this the element that has gone bad?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 20, 2010 | Estate EED4300TQ Electric Dryer
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
Maytag dryerthat stopped in the middle of running
Check breaker in your house breaker panel?
Apr 02, 2009 | Dryers
Replaced belt & pulley, now drum won't spin properly
Belt mounted upside down. Slick side goes to tub on this odd ball machine.
Mar 08, 2009 | Maytag SDE2606 Electric Dryer
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
Washer stopped after filling, small load
I would check and make sure the lid is not bent or bowed. If the middle part of the lid is too far down when closed, the machine thinks it's open and wont run an agitate or spin. If it is bent, just bend it back for a quick fix.
Dec 03, 2007 | Amana ALW880WH Top Load Washer
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 73932 Gas Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
