Question about GE PTS25LBM Top Freezer Refrigerator
My GE Arctica Profile refrigerator is intermittently stop running and cooling- it will momentary come on occasionally.
Fan and compressor just stop and no cooling- lights working on inside. Turning off for 30 minutes do no good. Started to take stuff out of freezer and fan and compressor came on for about 10 minutes then off. This refrigerator is in my garage in Rochester NY- have had in this location for 2 years with no issues. Temperature in unheated garage is about 30 deg f.
HVACRH20
  • 237 Answers
SOURCE: side by side not cooling
Couple of things... first need to see if the compressor is really hot to the touch and "clicking" on and off every 3-5 minutes due to high heat (trying to start). If that's what is happening you likely have a "start device" failure (little box on the side of the compressor). If the box is white in color and you pull it off and it makes noise when you shake it (along with little bits of debris falling out) you know it's bad. They make a kit to fix that known problem. If the compressor isn't trying to start but actually runs quietly... check that the cooling coil isn't all iced up preventing proper air flow inside the cabinet (take the panel of the rear inside of the freezer section to check it). If that is all a block of ice basically you likely have a defrost cycle problem (defrost t-stat bad, defrost timer bad, etc.). Other than that you should have a little fan right above the coils to move air around, if the compressor is running and the compressor fan (called condensor fan) is running then this fan (called evaporator fan) should also be running to move the cold air around. If that fan is dead then you will have a nice cold coil but no air flow over it to cool the rest of the refer/freezer properly. Let us know what ya find out.
Posted on Dec 29, 2006
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
  • 40 Answers
SOURCE: Top Freezer Not Cooling...Fan Running...everything thawed :(
Check the thermostat in the refrigerator and make sure it's not accidently turned to the defrost mode
Posted on Jan 08, 2009
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Posted on Mar 25, 2009
Compressor running continuously. Hearing surging sound. Both fridge & freezer not cooling.
there may be a blockage in the evaporator tube in the fridge sections and the only way to establish what the fault is will be to have fridge technician run test on it
Jul 25, 2015 | Fisher and Paykel Active Smart E522B...
Frigidaire Refrigerator is warm on top of the frig and freezer but fine on bottom.
Remove the rear lower panel on the unit check to see if the compressor is hot or if its running, should feel the vibration, also listen for any clicking noises.
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
Fridge stopped cooling but freezer works what could it be
Most likely the=> WR09X10041 Defrost Timer
found inside the fresh food section and behind the control panel. Click HERE for the location. Part location number 648 is the defrost timer. Location number 618 is the=> WR51X10038 Defrost Heater Assembly
If you change the defrost heater then you should also change the WR50X10071 Defrost Thermostat
and that is the location number 620 found HERE First I want you to try turning the defrost timer slowly clockwise until compressor and fans stop. Leave like this up to about 30 minutes. You should hear crackling and sizzle noise inside the freezer. If after 30 minutes the compressor and fans do not restart this will indicate the defrost timer and that part will need replaced. Try that first and let me know what happens. I will be here to answer questions if you like, Thanks Sea Breeze
Aug 15, 2012 | GE Refrigerators
Profile Arctica, Air flow fan runs but compressor dont kick in to make anything cold!
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this.
Feb 23, 2011 | GE Profile Arctica 25.4 Cubic Feet...
My 5 year old fridge/top freezer ge profile just stopped cooling, motor running but no cooling
First thing I need you to do is unplug pull away from wall and remove the cover over the compressor. Feel the top of the compressor and if too hot to hold your hand on the top leave the refrigerator unplugged until we can decide if this is the start components or another part like a fan not working all the time. I will send a manual and be available for assistance if you want, Thanks, Sea Breeze
Jan 24, 2010 | GE Profile Arctica Stainless Steel Top...
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE PTS25LBM Top Freezer Refrigerator Logo
59 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
