Question about Seiko Solar SNE100
Sne 100 seiko will not hold charge
After charging watch will not hold charge.
SOURCE: second hand doesent return to 1200 position after replace batt
I just replaced the battery in my 20yr old Seiko chrono sports 100. And I had the same problem. I think I stopped it on 12 while in stopwatch mode and held down the start stop button and the set button at the same time. See if that works dude.
Posted on Dec 31, 2008
Techjoel
  • 79 Answers
SOURCE: I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Posted on Jun 05, 2009
  • 2501 Answers
SOURCE: SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Posted on Feb 20, 2011
  • 823 Answers
SOURCE: I have purchased a new
if the resistance hasnt been reached via water depth or height in air it should be fine. if the incriments havent changed by five mintues after charging seek repair via the store you got it from or the Seiko customer service at
SEIKO Corporation of America - Service Center
1111 Macarthur Boulevard, Mahwah, NJ 07430, U.S.A.
Tel:+1-201-529-3316
Fax:+1-201-529-4525
E-mail:custserv@seikousa.com
Web:http://www.seikousa.com/ chances are it is the mechanism that alternates the current and it is normal.
Posted on Apr 05, 2011
  • 2501 Answers
SOURCE: I have purchased a new Seiko kinetic SUN007 mens
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Testimonial: "Thanks, will do."
I have this seiko solar chronograph watch for one year and stop working, I tried to charge it with sun light with no success, any idea ?
Replace the battery, the solar part doesn't mean it charges from the sun it has to do with the movement of the arms (I'm not %100 what that means) I just know it doesn't charge by the sun or any other light source.
Jan 31, 2015 | Seiko Watches
2006 bought, stopped working, does it need a battery change? Is it worth changing the battery?
It looks like you paid over $100 for the watch, I suggest to give a try changing the battery. Actually if you take it to some watch repair shop.. some of them will NOT charge you if replacing the battery does not bring your watch back to life!
I hope this helps!
Marcelo
Oct 23, 2013 | Seiko Coutura Chronograph Watch
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
Feb 20, 2011 | Seiko Kinetic watch
I am a resent owner of a 5m62 Seiko Kinetic watch. My Question is, How long does it take for my watch to get to full charge?
It should only take about a week of daily wear. Seiko's website may tell you differently, but in my experience it usually takes about a week.
Oct 16, 2009 | Watches
Watch stopped while in hospital and now, although running again, has the second hand moving in two second intervals
Some Seiko kinetic watches and other self charging watches do this when the battery is low. If it relies on you moving to keep it charged that may explain why it stopped in hospital. Try giving it a good shake and see if it starts moving smoothly again
Aug 10, 2009 | Watches
My seiko stops overnight but works during the day
if the watch is solar power it may not be getting enough to last through the night. if it is battery powered it may just be stuck when in certin postion like upside down or somthing
Jun 03, 2009 | Seiko Kinetic watch
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Seiko Solar SNE100 Logo
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
