Question about Toaster Ovens
I have a toaster oven with a melted thermal cutoff switch. It's a Thermokey C1-2021-120-017. Does anyone know where I can find a replacement? I found the web site, but can't tell if the cutoff temp is specified in C or F, and don't want to guess wrong! Thanks!
SOURCE: Bulbs for infrared toaster oven
Blue Devil,
The bulbs are available from the Panasonic parts store (Google), however I called Panasonic service and they could not explain to me how to take the toaster apart or tell me how much the repair would be. I partially disassembled the toaster and still could not figure out how to replace the bulb. Sorry. Good luck.
Todd
Posted on Aug 22, 2008
SOURCE: toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Posted on Mar 31, 2009
SOURCE: contract information for durabrand toaster oven
1st solution I can think of is to go back to the Walmart you bought it from and get a manual from another box of the same model. If that is not possible, contact me at gertzdad@comcast.net and I will copy and send you mine.
Posted on Apr 08, 2009
SOURCE: The knob on the bottom
You *can* order parts from the manufacturer directly, but good luck with that. The first time I called, and mind you their 1-800 # is a quagmire of numeric menu selections before you ever get to talk to someone, they said they would be happy to send me one but they were out/backordered and that I should call back in 2 weeks. Instead of putting me on some kind of list and sending me one when they got more...Grrr! Then I tried calling back and made it, again, through the menu maze only to find out they are in Eastern time. Super frustrating!
But I also discovered that the flat head screwdriver is the best temporary solution until I can get my hands on a replacement knob!
Posted on Jul 30, 2009
SOURCE: The knob for the oven temp control broke and needs to be replaced
go to their website www.prodprotect.com or Parts & Accessories: Phone: 1-800-738-0245 (Monday?Friday, 8:30 a.m. to 8:00 p.m., ET) Contact us
Posted on Sep 23, 2009
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
Euro pro to241r
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Oct 10, 2013 | Toaster Ovens
My Breville BOV800XL doesn't have any power.
My BOV800XL did the same thing. Of the three parts you mention the thermal fuse is by far the easiest to test and in my opinion the most likely to go out first. Check it with a meter. If you have trouble locating it read the FixYa solution for "The Breville BOV650XL will not power on." Check it for continuity like you would any fuse.
I found replacement parts at ereplacementparts.com. The thermal fuse assembly was $23 when I checked. Or you could just replace the actual fuse portion of the assembly with a comporable fuse such as http://www.mcmelectronics.com/product/NTE8213. Basically you need a 216*C thermal fuse. These can be had for less than $2 plus shipping. Buy a few just in case.
I just ordered my fuses today so I can't report on the success of my repair, but I am confident the new fuse will solve the problem.
Aug 30, 2012 | Breville BOV800XL 1800 Watts Toaster Oven...
Does anyone know where to order a thermal trip for a Flavel milano 100 cooker. The right hand oven has stopped working and I have been trying to find the spare part to no avail. Cheers
The following address has a list of sites that sell oven parts:
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 14, 2011 | Toaster Ovens
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
Stopped working for no apparent reason.
Probably a blown thermal cutoff fuse, Sefuse Part Number SF169E
Jun 14, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Will Purchase Oven or Parts from Non-Working Oven.
Al, your switch is likely a DKJ/1-60. As you know you can\'t find one, however there is a switch that will fix your oven. It\'s part # 05XDE5218104600 and is made for Delonghi ovens. It looks the same as the DKJ/1-60 and works the same. Get it at The Gourmet Depot website for $10 + shipping
May 13, 2009 | Black & Decker CTO649 Toaster Oven with...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Toaster Ovens Logo
61 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
