Question about Car Audio & Video
Had to jumpstart car, afterwards radio wouldn't work.
Had to jumpstart car, afterward the radio wouldn't work.
    Sergeant:
  • 475 Answers
Did you check to see if you blew a fuse?
Posted on Jan 05, 2013
Hyundai tiburon 2005 factory radio not working? Power issue maybe?
If the radio was on when you jump started car you may have overloaded display, and the radio as a whole may have suffered. You may need to replace the radio. Sorry can't be more help.
May 06, 2017 | 2005 Hyundai Tiburon
Key was left on ignition of camry 2007. Car wouldn't start, jumpstarted and then it started, but no rpm or response to gas pedal.The radio does not work either. My son replaced the fuel fuse but
You most likely blew a relay. It's just like blowin a fuse only a bit bigger. It sounds like maybe your secondary ignition. Your relay box should be on the drivers side, either right on top(when u open the hood) or mounted to either the firewall or the fender
Feb 06, 2013 | Cars & Trucks
Need tie rod ends for right side, is it best to replace both, or just one that needs fixed?
Replace both, as it's recommended to get an alignment afterwards. You wouldn't want to go through that expense, then have the other tie rod fail down the road.
Jun 06, 2012 | 2008 Dodge Avenger
How to fix a sticking choke on a 1977 931018 Ariens Lawn Tractor
sound more like a ignition problem with a choke stuck on it wouldn't run for 5 min that age might still have points and a condenser
Apr 03, 2012 | Garden
I have an emachine desktop pc with vista OS and since windows update added sp2, it won't boot up
I would recommend a reinstall with the disc that came with the system to get a fresh install of the os. Caution: you may lose all files in doing this
Dec 31, 2011 | E-Machines eMachines Desktop PC
I need diagram to to change heater core in chev silverado
I really wouldn't recommend that you try to take on this project yourself. Mitchell sets the labor time at 6.3 to 7.4 hours depending on options in the vehicle. This application requires the dash to be disassembled and removed from the vehicle to access the HVAC assembly. For a DIYer it you could easily spend 2 or more days. Additionally GM states that it is necessary to disconnect the evaporator core lines in order to remove the heater core. This means evacuating and recharging the A/C system afterwards. I strongly recommend that you take this to a professional to have it done. If you still feel like you want to attempt it, make a comment and I'll get you some images, but once again, I wouldn't suggest anyone other than a professional undertake this job.
Nov 04, 2011 | 2000 Chevrolet Silverado 1500
I just installed a new xo vision x349nt dvd receiver in my car . My rockford fosgate p3001 amp turns on but the subs doesnt come on but when i would take the base control out and put it back in i can hear...
Make sure and check the RCA wires in the back of your radio that send audio to the amp and make sure that they're connected to the OUTPUT/SUBS RCA's and not an input rca's. Also, check your ground and make sure no speaker wires in the subs are shorted. Try one speaker at a time see if that helps.
May 18, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
Had to jumpstart 99 jeep wrangler, now it idiles very high.
sometimes , when a battery goe's down, and you replace them, or jump start them, the computer has to reset itself and it will take a few minutes to do this, but afterwards, it should be fine, if you still have the problem, check for trouble codes.
Feb 11, 2011 | 1999 Jeep Wrangler
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
