Question about Samsung Digimax V800 Digital Camera
Screen does not work, stays black
The screen of my V800 does not work at all, although otherwise the camera seems to operate normally: takes pictures, flashes, zooms etc. What happened is that I dropped the camera into sea, but the case must have kept most of the water from penetrating. Perhaps the worst mistake was to try to turn the camera on right after this, some shortcut my have occurred. It does not look having been wet inside though. I also tried to clean the connectors, but the screen still won't work. Could it be that the screen has failed (and perhaps can be replaced?) or is some electronics likely to burn in under these circumstances?
    Sergeant:
  • 279 Answers
Water and LCD screens don't mix. I'd say the screen itself is shot, and will need to be replaced. However, I cannot find anyone selling these parts. Your best bet may be to watch for a broken one on eBay - so long as it's not the LCD that's broken, and buy it for parts.
Posted on Aug 30, 2007
The camera takes pictures with flash, but then as you hit display the screen stays black and the picture was never taken. How can this get fixed?
Do you mean that no picture file was actually recorded, or do you really mean that the resulting picture file recorded a black picture?
If you mean that you're camera is taking black pictures, this sounds like a stuck shutter. A stuck shutter is a common failure mode for digital cameras, and it seems to be especially so for any of the Canon A6XX series (although these cameras are awesome otherwise). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 28, 2010 | Canon PowerShot A620 Digital Camera
The srceen stays black when you take a picture
If the menus work, that tells you the LCD is OK, so the next possible thing is the shutter is jammed shut - marginal repair now.
Jun 08, 2010 | Olympus Camedia Stylus 300 Digital Camera
Canon S2 IS LCD Screen Doesn't Work Correctly
Hi, Some leads from the display wires are cracked or broken, if you are accurate enough you can replace it by yourself otherwise bring it to an repairshop.
regards Rob Rotronica
Apr 16, 2009 | Canon PowerShot S2 IS Digital Camera
Dropped Ixus 50 in water...!
place your camera in a hot press, or where your boiler is, on shelf and it might dry out in a day or two, then try it again.
Aug 26, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon sd450 - spilled a little lemonade on the camera
maybe the lemonade was sticky and the shutter can't open? otherwise the circuitry could have been fried if you turned it on before it dried inside.
Nov 09, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
Black screen
If you can play back images ok ( colour & resolution normal ) but in capture mode you have no image then the CCD sensor in your camera is faulty. Replace.
Sep 10, 2007 | Fuji FinePix F410 Digital Camera
Lcd monitor screen stays black
there may have been some kind of damage to the lcd. sounds like you are going to have to send it in to have it fixed.
Jun 13, 2006 | Casio Exilim EX-S500 Digital Camera
Camera will not stay on!! Can it be fixed?
The camera mechanism is probably malfunctioning, and the phone switches you back to the main menu. Get a repair estimate I hope someone here can give you a DIY fix though good luck
May 11, 2006 | Sony Ericsson V800
Samsung Digimax V800 Digital Camera Logo
115 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
