Question about Unitech PT630 Portable Terminal
How to install maintscp.exe on my pt630
No files on my pt630
Reset unitech 630
ERROR INVALID APPEARS ME PORTABLE TYPE (HT630) IN A PT630 UNITECH AS I CAN SOLVE?
Apr 08, 2013 | Unitech PT630 Portable Terminal
MESSAGE PT630 BIOS VI.94 MEM 4608 KB WHAT SHOULD I PRESS TO PUT IT ON SCAN MODE? (READY) THANK YOU
Press and hold CMD button. Then, option 8 for settings, option 2 for scanner. Use arrows and enter key to select your preferred settings from there.
Feb 02, 2011 | Unitech PT630 Portable Terminal
I have a problem with my hpdv5 1205tx my current windows is vista i repormat in windows 7 now my problem is my digital personel fingerprint was not connected i already down digital personel 4.11 help me...
If you have installed either 64 bit or 32 bit, then you have to run the installation as administrator.
To do this, just right click on the installation file and choose run as administrator.
If this did not help, refer the below steps:
  • Download version 2.01 of DigitalPersona software
  • Install on existing system
  • Export data
  • Boot into Win7
  • Install 2.01
  • Reboot
  • Reset properties for each of 7 EXE files
  • Reboot
  • Register a finger print
  • Import data saved in step 3
  • Download from here:
    http://download.cnet.com/DigitalPersona-Password-Manager/3000-18501_4-201746.html
    Step 3:
    Export is available as an icon choice in the system tray. Save to a file for use in Step 10.
    Step 7:
    The run properties for each of the 7 EXE files in the DigitalPersona install need to be adjusted. The files are:
    DPAgnt.exe
    DPConsol.exe
    DPExpImp.exe
    DpFpLogonManager.exe
    DpHost.exe
    DPRunDll.exe
    DPWinLct.exe
    Select each and set as follows:
    • Compatibility tab
    • Press ã¢â‚¬å“Change settings for all usersã¢â‚¬â
    • Select run in Vista mode
    • Select run at admin near bottom
    Repeat for each of the 7 EXE files.
    Nnags.
    Mar 08, 2010 | HP Pavilion dv6000z Notebook
    AdMINIsTrATor.exe missing
    is a malicious malware code created to open security holes in Windows and give third parties control over your compromised computer. After installation Administrator.exe may stay active in the memory and install nasty files in Windows folders. Administrator.exe is a security risk that may harm your system files and computer hardware.
    Clean and protect your computer from all varieties of malware threats. Scan and remove Administrator.exe malware and all its related files, clones and aliases.
    but Microsoft provides a replacement for the Admin.exe file included with versions 3.2 and 3.2a of Microsoft Mail for PC Networks.
    For complete information about obtaining and installing the Admin.exe file, see the following sections: http://support.microsoft.com/kb/107443
    Nov 09, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
    Total available char can be scan
    The number of characters read is defined in your application and the width of the printed bar code. Also the width of the laser or ccd. One program to develop applications JobGen Plus de Unitech.
    Roberto Martinez
    Aug 16, 2009 | Unitech PT630 Portable Terminal
    Cant open the install.exe file on the software cd
    adobe is generally only for files that end in ".pdf" for a ".exe" file you really should always be able to just double click it with your left mouse button.
    and yes, install.exe is the correct file to get things going if they don't start automatically.
    Feb 11, 2009 | ION Audio iTTUSB Turntable
    How can I change the LCD contrast on the Unitech PT630? Thanks!
    Press the button and hold CMD and then -> to adjust the contrast.
    Dec 08, 2008 | Unitech PT630
    Installing jetflash 2 windowsme
    Download and install the following files and try again. The should also work with Windows ME as it is just a dressed up version of Windows 98.
    For Windows 95, 98 and NT VBRun60.exe - VBRun60.exe installs Visual Basic 6.0 run-time files.
    VBRun60sp5.exe - VBRun60sp5.exe installs Visual Basic 6.0 sp5 run-time files
    For Windows 98 only DCOM98.exe - Extends the support for Distributed Component Object Model (DCOM) for Microsoft Windows 98.
    Apr 10, 2008 | Computers & Internet
    Unitech PT630 files
    What program are you trying to replicate? Is it a third party application? What error you received on the PT630 screen when u run the program.
    Dec 30, 2006 | Unitech PT630 Portable Terminal
    External Program
    Have you tried the ActiveX Control from Unitech? They have a bunch of PT630 utilities available for download here: http://www.ute.com/downloads.php?product_id=29 Function UpLoad() should be what your looking for. If you need more help let me know. El Duderino
    Nov 14, 2006 | Unitech PT630 Portable Terminal
    Unitech PT630 Portable Terminal Logo
    32 people viewed this question
    Top Unitech Computers & Internet Experts
    David Payne
    David Payne
    Are you an Unitech Computer and Internet Expert? Answer questions, earn points and help others
