Question about Winter Sports
How to replace choke and cable on 1982 yamaha enticer 340t
5 Suggested Answers
bozcro
  • 867 Answers
SOURCE: how to change the choke cable on a yamaha fazer
choke cables normaly last for ever, so it prob needs just a bit of oil. remove upper end of cable, tape a cone on it and pour some 20/50 into it. if it is broken, observe the set up and replace.
Posted on Jul 17, 2009
  • 9 Answers
SOURCE: 1982 yamaha 550 top end
You cannot get replacement pistons, they are not avaulable form Yamaha, and there are no known equivalents.
Best bet is to get a wrecked bike.
Posted on Aug 02, 2010
mycharmingli
  • 389 Answers
SOURCE: I'm looking for a downloadable
Contact Yamaha they will usually send you one for free.
Hope that helps if not let me know and will research further...
Posted on Nov 18, 2010
  • 738 Answers
SOURCE: I just bought a 2001 Yamaha R6 and the choke cable
hi, this is the best way to replace the choke cable, first remove the riders seat, 2 alun key bolts at the rear of the seat turn up the corners of the seat and you will find the bolts,
undo the tank fiking screws at the front of the tank and then prop up the fuel tank , remove the air box by undoing the 10mm bolt in the front of the airbox, then undo the clip/clips holding the airbox rubbers to the carburetors, lift of the airbox, now you will see the carburettors and the location of the choke cable sliding mechanisam,
undo from the handlebar the left hand switch unit and pull the 2 halfs apart you will then be able to remove the nipple of the old cable from the opperating lever, replace the new cable using a small amount of grease on the new nipple,then thread the new cable through the frame following the exact same route as the old cable and connect it to the carbs and check the opperation of the choke lever, pulling it on and off making sure when the choke is off that you have a small amount of frree play in your cable and the lever on the carb end is all the way home, if you are happy you havereplaced the control cable correctly, you can then reasemble the airbox, lower the tank and replace the seat, finaly recheck the operation of the controls before riding the machine on the road, regards, paul
Posted on Jan 18, 2011
My xs400 is hard to star when cold why?
Check the fuel air mixture when cold or if it has a temperature sensor and an ECU, check the sensor.
Jun 19, 2014 | 1982 Yamaha XS 400
How to separate front forks on 2005 yamaha enticer 125
Hi, Anonymous for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
FRONT FORK OF YAMAHA ENTICER SERIES
Yamaha YBR125 Fork tube replacment seal rebuild
Manual de Usuario Yamaha Enticer YBA 125
OEM parts for Yamaha
Oct 20, 2013 | Yamaha Motorcycles
My 1982 Yamaha 650 maxim begins to rev around 4,000 rpm after it warms up for under 5 minutes. I have tried carb cleaner. Can anyone help?
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted or pinched.
2. Idle adjusting screw needs to be backed off.
3. Intake system air leak.
4. Fast idle choke ramp is not releasing.
5. Broken throttle return spring.
6. Damaged diaphragm or slide.
7. Faulty MAP, TPS, ATS, O2, VSS sensors or wiring/connector
Xj650 HIGH IDLE puts itself to full throttle
HELP My bike idles at 4000rpm
Yamaha XJ750 Owners Workshop Manual
http://www.carlsalter.com/pdfs/Yamaha_XJ600SK_Owners_Manual.pdf
Sep 02, 2013 | 1982 Yamaha XJ 650
I have a 1982 yamaha vision 550 i have it runnin but hard to find a smooth idle choke to high idle real fast choke to low it dies
Hi, Renee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Owning Vision FAQ
Hard starting can open choke
Yamaha XZ550 XZ 550 1982 1985 Factory Service Repair Manual Download...
Yamaha XZ550 Vision Carburetor Overhaul Pt 1 Getting Started
Jul 15, 2012 | 1982 Yamaha XZ 550
Have a 1982 yamaha 920cc Varago, 20,000 miles, new starter, battery and relays. Very hard to start, acts like too much compression. Is a stronger battery. Replace everything that has to do with...
chec connections in ignition area and make sure batt has 12.6volts-that motor has alotta horses--carb probly needs overhaul or choke maintenance
Nov 03, 2011 | 1982 Yamaha XJ 650
I have a 1979 yamaha 340 enticer.Recently it would not start, no spark. I tried new plugs and a new ignition coil but still no spark. Don't know what to do next.
Hi, Gmgroot and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Security alarm failing to disarm needs reset
1999 royal venture no spark limited knowledge need help
https://www.tradebit.com/filedetail.php/55384194-yamaha-1983-1988-enticer-excell-340-snowmobile-service
http://vintagesleds.com/library/manuals/yamaha/1980/ET340_80.pdf
http://www.gearhead.com/snowmobile/parts/oem/yamaha.html?aribrand=YAM&s2=snowmobile
Feb 04, 2011 | 2000 Yamaha Royal Star Venture
I'm looking for a downloadable service manual for a 1982 Yamaha Enticer 340 LT. It is a snowmobile. Thank you.
Nov 18, 2010 | Yamaha G5 Motorcycles
1982 Yamaha sr250 runs great but when I come to a stop the idle will run up. I have worked on carb and replace almost every part inside.
Hi, Stephens1302 and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rough Cold Start High Idle When Warmed Up
82 GL1100 Idle speed increases LOTS
Yamaha SR250 Yamaha SR250G Years 1980 1983 Service Manual Download Manuals... $10
http://mybikemanuals.com/yamaha/yamaha-sr-owners-manuals
Oct 10, 2010 | 2001 Yamaha SR 125
1982 Yamaha XJ 400 Maxim replace speedometer
Hi, Tuero33 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Speedometer 1982 XJ750 Maxim
Tachometers Speedometers Mounts Cables
Yamaha XS400 1977 1982 Factory Service Repair Manual PDF Download Manuals... $10
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
Nov 17, 2009 | 1982 Yamaha XS 400
Winter Sports Logo
44 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
