Question about Acer Aspire 5720 6497 Laptop
The jkl are coming up as number,cant seen to unlock it or how!
Every time we press jkluio they come up with numbers its locked and dont no how to unlock it.
    Problem Solver:
  • 5 Answers
MORE DETAILS!
I really need to know operating system and Keyboard make and maybe model to give you a definite answer. I'll do my best though.
1.It could possibly be that your "function" key is stuck.
This key is usually blue or yellow and has "Fn" on it. Look on your keyboard and see if you can find a "Fn" key. If you find it try hitting it a few times and see if it works to change the letters back to numbers and vice versa. If there is no response than it could be stuck Internally.
2. To see if that is the problem try hitting some other keys and see if they come up right or are displaying their secondary "function"
3.If all other keys except jkluio are working normal than then next i would try the "num-lock" or any other "lock" buttons located on your keyboard. These are usually located at the top right hand corner above the number pad or to the right of the "backspace"
4.If that does not work than it is a setting in your computer and you need to restore your settings to default.
a)Hit start and go to the control panel
b)once in control panel select "devices and printers" or "printers and hardware" depending on your OS
c)Once in that menu you should see an icon that says "Keyboard"
Click on that...
d) This menu will vary a ton between different OS's and keyboards and drivers so you need to look around and try to set to default. There should be properties and settings you can adjust. Also a "troubleshooting" option is worth clicking on.
5.If your still not fixed, look in the keyboard menu in the control panel and click on the "Drivers" tab. In this tab you will see options to "Update" the driver and "Roll-Back" the driver. Try each of these once starting with "roll-back"
If NONE of these steps has resolved you issue than i would say the keyboard is broke and to get a new one...
Hope this helps GOOD LUCK!!!!
Posted on Jan 05, 2013
I cant get my keyboard to type the numbers. it keeps typing the chaacters.
Try pressing and holding the number buttons to see if the numbers come up. Also look if the shift lock (A small indicator on the leftmost side shift button) is engaged.. If yes, then press or long press to turn off the shift lock.
Aug 26, 2015 | Samsung Galaxy Tab 4 7.0& 3G T231 8GB...
HOW Do I Get rid of numbers under the letters on the rt side of the keyboard j,k,l. etc
Try pressing the ScrLk/NumLk key that is above the F11 key.
This will turn off the Number lock.
Feb 20, 2012 | IBM ThinkPad T40 2373 Notebook
How do i change the code on a s25e digital safe i cant find the book
if its like my old woolworths one, open the door and press a red reset button on the inside of the door, close the door and dont lock, put in the 4 numbers u wish a press a A button on the keypad, or whatever ur enter button is, then lock it, then press the 4 numbers again and the A button or enter, a light should stay on and unlock :)
Feb 21, 2011 | Safe International Electronic Gun Safe...
I cant work my phone beacuse i was playin around on it and than something popped up saying thant i need a puk code and i dont have it someone please help me
this is a code that unlocks the sim, if you enter in the wrong number more than 10 times it will permanently lock the phone. you need to contact your service provider and they will be able to give it to you. if the ones they give you dont work (ive seen it before) then you will need to get a new sim.
Mar 14, 2010 | LG GW520 Cell Phone
Philips freeview digi box dtr1500
thanks my daughter solved the problem to unlock parental lock or parental pin number she tried four zero digets 0000 no success then she put in four numbers one 1111 and it unlocked the parental lock .hope it can maybe help someone - margaret
Oct 01, 2009 | Philips Universal PH301S Remote Control
I PRESS O AND 6 COMES OUT ALSO LETTER JKL AND NUMBERS123 COMES OU
The number lock has been pressed. To turn off the number lock press and hold down the shift key and press the NumLk/ScrLk key. The NumLk LED will turn off, to indicate that the number lock has been turned off.
Sep 12, 2009 | Lenovo Keyboard
Am using compaq nc6000, when i wants type number ( 1,2,3..) using function its not coming numbers, like jkl is coming instead of 123
Hold down the Fn key while pressing those keys. Or turn on the Num Lock and you don't have to hold down the Fn key.
Jan 17, 2009 | HP Compaq nc6000 Notebook
ACER 5620 Extensa keyboard problem.
Hi, your Laptop has a integrated keypad. You or someone else might of turned this on, thankfully it is easily fixed. Just follow these steps,
1. Find and press the "Fn" key.
2. Find the F11 key there should be in blue letters "NumLk"
3. Press F11 while holding down the Fn key.
This should turn off the integrated keypad
Hope this works ~Kaleb~
Nov 12, 2008 | Computers & Internet
Keyboard
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
Acer Aspire 5720 6497 Laptop Logo
4,964 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
