Question about Coleman Tools & Hardware - Others
Coleman mobile home furnace...Model number DGAA077BDTB...blows it's 20 amp fuse.
I have a Coleman mobile home furnace...Model number DGAA077BDTB. The furnace one went out, but we were able to reset the switch. Now the 20 amp fuse that the furnace is on blows occasionally. We're having some pretty cold weather. Could the furnace have some kind of surge when it kicks on that trips blows these fuses? There is only the furnace, an alarm clock, and room light on the same breaker.
2 Suggested Answers
SOURCE: no problem-just want info
This unit is electronic ignition
Posted on Oct 04, 2009
How do I replace filter panels on Coleman mobile home gas furnace after I have changed filters on them? They won't go back in easily
one post only,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman Heating & Cooling
I have brand new coleman mobile home furnace model # DGAH056BBSB the pilot light (elec. Start) wont stay lit and it blows COLD AIR! PLZZZ HELP Ohio is COLD
here, the last sentence is important.
http://www.ehow.com/how_5615197_light-coleman-furnace.html
Further information here.
http://handymanwire.com/ubbthreads/ubbthreads.php/topics/28213/Pilot_light_won_t_stay_lit
But if the unit is new, it must be under some sort of warranty from Coleman and from the fitter.
coleman website, support, contact and warranty, but the website doesn't list, heaters, or furnaces? I am puzzled.
http://www.coleman.com/warranty/
Oct 23, 2015 | Coleman Heating & Cooling
Coleman furnace dgaa077bdta
The control fuses keep blowing tells me one or more of the control that operate the control on 24 volts is malfuctioning. Most controls operate at about 5 watts and on a clamp on amp meter normally pull about 0.2 amp (p = current x voltage, 5 watts = 0.2 amps x 25 volts) I install 75 watt 24 volt transformer with a resettable overload to save on fuses. I reset the transformer and quickly go to the controls and determine the amp draw. When I find the one >0.2 amps I found the problem. The things to check is the emergency heat sequencer, fan control sequencer, reversing valve for heat pumps, main contactor on the condensing unit and any other 24 volt control loads. I have had to replace the themostat wire because the increase current for the thermostat wire can cause the entire length of wire to form a long heater and cause insulation degradationa and cause the thermostat wire to short out and blow the fuses.
Hope this helps
Aug 30, 2014 | Coleman Mobile Modular Home Gas Furnace...
Coleman Furnace DGAA077BDTB fuse blows when hot is connected
This can be caused be either a short in the wiring, loose connection on the board,or a low voltage connection not secure on the board. Check all connections to make sure they are tight and secure. Let me know what you find.
Jan 10, 2013 | Heating & Cooling
Coleman furnace
Is this a blend air system? If so, there is an upper & lower control board that communicate to each other, and if the exhaust fan on the roof is out, it will give you intermittent issues. The fan mixes or blends outside air with the return of the air handler, & duals to pressurize the attic. These were installed due to mobile homes built too air tight. Without this fan, your roofing shingles will curl, and your roof decking will bow prematurely.
Dec 22, 2012 | Coleman Mobile Modular Home Gas Furnace...
Coleman mobile home furnace pilot light turns off when blower turns on
Heat exchanger could well be split causing it to blow out pilot
Oct 27, 2012 | Heating & Cooling
No problem-just want info
Feb 26, 2009 | Tools & Hardware - Others
Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Tools & Hardware - Others Logo
155 people viewed this question
Top Coleman Tools & Hardware - Others Experts
john h
Are you a Coleman Tool and Hardware - Other Expert? Answer questions, earn points and help others
