Question about Bosch AHS 6000 PRO-T Electric Hedge Cutter
Bosch AHS 6000 PRO-T Electric Hedge Cutter stopped during use and is now 'dead'. no smell, but have I burnt out the motor?
I was cutting conifer branches up to 2cm thick.
4 Suggested Answers
canddplumb
  • 35 Answers
SOURCE: Bosch dishwasher stopped rujnning
Your dishwasher may be pluged into a gfi plug and need to be reset ,you might have wiring short posibly do to a pinched wire. Make sure your door was closed good,that could be the problem,If its a wiring problem call an aplliance repairman or electrician.
Posted on Dec 02, 2009
  • 178 Answers
SOURCE: Hand held electric Bosch hedge
http://www.boschdesign.co.uk/dealer_locator/loc_result.asp?strLocator=&strPostcode=W7%203EL&strType=ysn_garden&intProduct=
Well, I guess you live near london? Click on the above link. If you recognize any of those addresses, than one of those Authorized Dealers may help you. I'm sorry but I live in America and am not sure if this will help.
Posted on Nov 21, 2010
bestrona34
  • 5 Answers
SOURCE: bosch angle grinder acts like its burnt out but motor resistance values suggest not
Hi Brian, running your angle grinder on reduced voltage (through overloading the petrol generator) will have caused the current in the grinder to be higher than it should be. This may not be what you expect, but it is a characteristic of rotating machines, they behave differently to resistive machines such as heating elements. You have not indicated how you come to the conclusion that the windings test OK. If you have just checked with an ohm-meter and see a continuity reading, this does not eliminate the possibility that the overheating resulting from over-current has broken down the insulation (evidenced by the smell and sparks) and you have short circuited windings. The grinder will run without a suppression capacitor, it is just there to minimise interference with you neighbour's (or your wife/girlfriend/daughter's :) ) radio. Replacing the capacitor will not restore your grinder, I reckon you have killed it, in spite of the fact that running it on a healthy supply was to quickest way to cool it effectively.
Posted on Feb 03, 2015
Testimonial: "ok thanks, i tested the resistance between each adjacent bar on the commutator and the the resistance across 180 degrees, each measurement was roughly the same, i also checked for continuity between each bar and the stack and there was none. I checked the four wires of the field coil and there was continuity between each pair but not each other if that makes sense."
What are some tips to cut tree limbs by a pole saw?
safety helmet
safety glasses
cut smaller branches first
cut small lengths
have a friend as a look out for power wires and other obstructions that branches can fall on
never cut while on a ladder
use a trestle and not a step ladder
Apr 09, 2018 | Garden
Borsh chainsaw. Brand new. Used for about 2 hours for cutting conifer hedge. Would not cut the next day. Check chain, tension and oil but would not cut. Chain rotatos okay
Make sure the chain is on properly , that is , the cutting teeth are cutting in the right direction .. Yrs ago , my drukin friends & I reversed the chain on our buddy,s chainsaw . It was a laugh watching him trying to cut a log . Worth checking ..
Dec 27, 2016 | Garden
My Bosch AHS 48-16 Electric Hedge Cutter hit a bit of wire, now there's s clickingn noise when trying to start it. Any help appreciated
It could have possibly damaged the cutting edge of the blades and put a burr on them, meaning that as the blades reciprocate, the 'burr' is catching on the other blade.. Check the blades for damage and use a flat file to smooth off any burrs that could be catching. (Make sure it's unplugged before doing any work on the machine)
May 10, 2016 | Electric Garden
Haveing problems cutting thick branches with chain saw it is sticky with sap and chewing up the blade blunt
If you have a low cc chainsaw, this is what happens with the tougher trees. Check what cc yours is. The more cc the more power!! For example, alot of the chainsaws you see for sale in Home Depot are ranging between 32cc and 40cc... you should have at least a 50cc and up...
Oct 03, 2015 | Ryobi RCS3535CA Petrol Chainsaw 35cc...
The tip of blade will not come together or close.
if it is a hedge trimmer as per the catagory, get a new cutter bar or get a new hedge trimmer
probably from blunt cutters that tried to cut too thick branches
if it is secateurs then do as ray suggests
Oct 02, 2015 | Garden
How to open a Bosch AHS 4-16 Hedge Trimmer ?
Not sure how to open it - if engine runs but clutch doesn't engage on revving perhaps the clutch has seized... point to bear in mind though is if you can't open the gear box (don't know how to) you most certainly won't be able to change a part inside - you will just get fiddly bits everywhere and never get them back where they should be - best get a pro to give you their opinion on whether it is worth the cost of getting it fixed.
Sep 22, 2014 | Bosch Ahs4-16 42Cm 390W Electric...
My Bosch AHS 45 16 electric hedge trimmer start, is there anything you can suggest?
Hi Dan Walsh, When an electric motor won't start, it could be an open temperature device in the winding of the motor itself. If you have brushes and they are worn, then one or maybe two of the brushes can't stay inside the brush holder. They are spring loaded and if worn out can pop out. Also, if the winding are open, then there is not continuity. This will cause the condition you described. Not the best news, but it might answer your question.
Good Luck!
Jun 03, 2014 | Bosch AHS 45-16 Electric Hedge Trimmer
Bosch AHS 6000 PRO-T Electric Hedge Cutter Logo
112 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
