Question about Stoves 600SiDOm Gas Kitchen Range
Gas won't flow through range
I recently connected a gas range that has been sitting for a few years. (was used three years before it was disconnected) Since installing the range I've discovered that the gas is not flowing through it and it can not be lit. Could the line just be clogged and is there any way for me to unclog it?
    Novelist:
  • 88 Answers
Might be a clogged line, could be your diaphragm in the regulator that is bad, you will need to disconnect the regulator where you hook up your gas line to the range then from the burners blow compressed air through them, I would suggest replacing the regulator, should cure the problem.
Posted on Jan 20, 2009
How do I troubleshoot my fryer when I cannot get it to start?
In order to turn the knob to the pilot position you need to push the knob in slightly and then turn. Once the pilot position on the knob is lined up with the indicator on the valve, you can push it in and gas will flow to the pilot assembly.
Feb 28, 2015 | American Range AF45LP Deep Fryer
Wfg361lvs oven clicks 1 times, lights and then clicks three more times and turns off.
manually check the burner and the gas jet area for blockage that would prevent lightup.. the safety is kicking in to prevent gas explosion..
Jan 12, 2014 | Whirlpool WFG361LVS Stainless Steel Gas...
Whirlpool/Honeywell hot water heater light flashes 5 then 7 times and won't light. Burner is clean and all contacts are good. Out of warranted.
Copy following link to troubleshoot by type of gas control valve, including directions for cleaning air intake screen, and or replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7 flashes: Gas control valve might be bad.
4 flashes: FV overheat, clean air intake.
Soot indicates clogged air intake slowed combustion venting possibly causing overheating and lockout. Clean air intake screen located on bottom of unit.
Apr 17, 2013 | Water Heaters
JGBP90 gas range - precise simmer burner won't stay lit
Check the "Orifice Spud" to be sure that it doesn't have a partial blockage.
Nov 30, 2012 | Kitchen Ranges
Gas Range has inconsistent gas flow
From what you've described and what I understand; the only part that requlates the gas flow "low or intermitten gas flow/pressure" is the "gas pressure regulator" located where the incoming gas flex-line connects directly.
The pressure regulator is about 3" x 3" metal square blockish' type device and can be replaced fairly easy. However, if and when replacing the pressure regulator, ensure you are using the proper gas - yellow teflyon tape of pipe dope paste to thread in the new part.
What is the model number of the range? (free standing - gas pilot only)
(The above suggestion is assuming you have the proper gas supply pressure to your home/range)
Jan 27, 2009 | Hotpoint RGB745 Gas Kitchen Range
My knob on my oven is frozen
Did you try WD40(in the UK) or Q20(in South Africa)? You can buy it at hardware shops. It is a penatration flued which is a bit oily.
Dec 20, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
JGBP79 Bake Ignitor not glowing, even after replacing
My next step would be to replace the two gas coils. They are located on top the gas valve. Disconnect the elect. leads, pull upward on coils. Replace w/newones. The difference is a primary and secondary, one has two elect. prongs and one has three. Note which one goes where when you remove them and install new ones in the opposite. These tell the gas valves when to activate and allow gas to flow to your igniter. When they malfunction, and they do, you wont have gas flowing.
Dec 06, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Nov 26, 2007 | GE Profile JGSP48 Gas Kitchen Range
Stoves 600SiDOm Gas Kitchen Range Logo
122 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
