Question about Refrigerators
How do you clean filter in TG20 portable ice maker
  • thevolatile1 May 28, 2017
    Water filter is inside water tank bottom back / left side. Remove with your finger nail
  • 3422 Answers
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
Posted on Apr 05, 2008
geemarie
  • 876 Answers
SOURCE: ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Posted on Aug 01, 2008
  • 3422 Answers
HI,
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Posted on Aug 24, 2008
  • 93 Answers
SOURCE: WATER DISPENSER AND ICE MAKER JUST STOP WORKING
check your water solenoid possibly cloged or burnt or the actuater arm in the ice bucket to activate the ice cycle thanks from gilles
Posted on Mar 15, 2009
goofduck
  • 490 Answers
SOURCE: ice from ice maker taste bad and can not find a water filter on it.
I would install a filter inline on the water filter I have one under the sink and on the ice maker
Posted on Apr 14, 2009
Suggest me a best portable ice maker that comes with three select able cube sizes?
You can get Ivation Portable High Capacity Countertop Ice Maker that comes with 2.8 liter water reservoir, 3 selectable cube sizes - yield of 26.5 pounds of ice daily. As this is one of the best portable ice maker that one can get for getting the best options for oneself. Also, this is best because it is made with many best features that are best for providing one with many benefits for the overall health of the body. You can also get many different options also that are available and you can purchase them after comparing them from Best Portable Ice Maker
Apr 01, 2017 | Refrigerators
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How do I clean my igloo ice maker
Igloo Ice Maker ICE102-WHITE - Kitchen Appliances Manuals
kitchen.manualsonline.com > ... > Igloo Ice Maker
Igloo ICE102-WHITE Ice Maker User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Igloo Portable Ice Maker Review - YouTube
? 4:02
https://www.youtube.com/watch?v=893Cs66veK0
Jan 3, 2014 - Uploaded by TheVirginiaStew
The Igloo Portable Ice Maker, Model is the ICE 102C Silver and it is great. It can go ... Main thing is to use good ...
Jan 19, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
Heat cannot produce ice
How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
1 How to fix a portable ice machine part 1 of 3 - YouTube
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
Jan 07, 2016 | Emerson Refrigerators
LOST MANUAL - WHAT IS RED BLINKING LIGHT
What is the brand of your ice machine?
I usually get Scotsman doing this ,
Mostly it's because of the clogging of the air filter, and even after cleaning it needed to be reset.
To reset you need only to push the signal button for 5 sec.
And it's done .
Jun 08, 2015 | Danby DIM2500WDB Portable Maker White
What can i use to clean my portable ice maker. It smells like mildew.
I have cleaned Manitowoc ice makers and their company specifically made an ice maker cleaner and sanitizer. Try a google search for this product.
Dec 13, 2014 | Nostalgia Electrics RIC-100 Retro Series...
Water sensor says out of water but it is not
Try cleaning the little filter at the bottom of the tank. This filter is usually the problem and it should be cleaned once a week.
Oct 18, 2014 | Emerson Im90 Portable Ice Maker
How to clean igloo portable ice maker
Maybe scaling has occured, get descaling chemical to clean it. Also remember to remove the dust accumulate at the condenser..
Oct 11, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Refrigerators Logo
251 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
