Question about HP Computers & Internet
Edifier speaker no sound
Speaker lights up
  • HP Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
Posted on Jan 05, 2013
2 Suggested Answers
SOURCE: i have a EDIFIER MI335F can you please help how can i make it sounds good
simply change ur speaker
Posted on Sep 08, 2012
No sound playing from either speaker on the Edifier Multimedia Speaker M3300 setup.
Go to http://www.edifier.ca/french/speakers/m3300/m3300-EN-FR-manual.pdf and check the troubleshooting guide. I notice it says to check to make sure the mute button on the remote is off. Try it without the remote plugged in, also. Try hooking up another device with a headphone jack like an mp3 player. The only other thingI can think of would be a blown fuse, which sometimes lets a small signal through with some amps, but I don't see any fuse holder.
Dec 09, 2014 | Edifier Audio Players & Recorders
Edifier m1350
As long as the woofer is functional, get a pair of 8 Ohm matching speakers from Radio Shack.
Jan 09, 2014 | Edifier Audio Players & Recorders
I don't sound from my left Edifier M1250 speaker
If possible, swap the speakers side for side. If that same speaker does not work on the opposite side, the speaker is likely defective. However, the connection to your computer could be bad, causing one channel to drop out.
Dec 29, 2013 | Edifier M1250 2.0 Multimedia Speaker...
Edifier C2 amplifier repair
My Edifier HCS2330 Amplifier stopped working and now the system is useless. Any recommendations on where to get it fixed from? Or any place i can buy the amp separately? or maybe even any other brand amp i can buy for cheap price?
Jul 14, 2013 | Car Audio & Video
Edifier bar speaker,no sound
Reboot the computer. Is it connected to the headphones jack? Check the plug. Open the sound device, select the headphones.Open the Device Manager , check the audio is enabled. Re-install the driver for the audio.
Jan 05, 2013 | Computers & Internet
We fixed speakers to my tv but so sound is heard
look first to see if a dvd etc connected to a rear input gives sound.
Nov 05, 2012 | Edifier M1380 2.1 Multimedia Speaker...
I fixed the speakers to my Led tv but no sound can be heard
Nov 05, 2012 | Edifier M1380 Multimedia 2.1 Speaker Two...
Problem with woofer....my edifeier woofer is not in aucuastic mod
Edifier works best in ausctic mode only when played in 5.1 surround mode....does you system hav a sound card ? if not then go for it..im sure it will work as these are THX certified speakers
Goodluck :)
May 07, 2010 | HP Computers & Internet
Computers & Internet Logo
47 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
