Question about Vizio VX37L Television
Cannot get picture from DVD to TV screen
How to hook up properly
  • Vizio Master
  • 933 Answers
Which input are you trying to use? HDMI? Component? or RCA?
Posted on Jan 05, 2013
Hitachi57projection tv when dvd is hooked up, have sound and no picture.
check the connection if it was in proper video component input in your tv unit, try other video input if still picture doesn't appear on the screen, make sure you have the right settings with in your tv set. then the connector from dvd player is properly connected to the component video out jack.
Jul 22, 2011 | Televison & Video
I own an iview 2600hd dvd player and im trying to hook it up to my sony trinitron tv...however, no matter how i switch my cables, the dvd player just won't show any picture or audio on my tv...and when...
Try new cables. RCA cables have a tendency to have bad connections internally. Also, triple check that you're on the right input and the wires are properly connected to the DVD player. If all that fails, try the DVD player on a different T.V. and something that uses RCA cables on your T.V, such as a cable box to make sure the input jacks on the T.V. aren't bad, and the DVD player isn't bad.
Through out all of this troubleshooting, you should manage to get the DVD player hooked up.
Jun 20, 2011 | Televison & Video
The DVD player is running a movie with no picture or sound, the TV screen is showing an icon that says no signal...How do I get the movie to run with sound?
try using a different input on your tv. If possible try using a different cord to hook the dvd player to the TV. If neither solution works it sounds like a faulty dvd player.
also try using a different source on the tv like another dvd player, cable etc. etc. hopefully on the same input to make sure the tv is working properly .
Mar 03, 2011 | Dynex Televison & Video
Cant figure out to hook up keeps saying no signal with hdmi cable to tv and blu ray put in
What kind of TV are you hooking the dvd player up to ? You may have to go into the TVs menu and set the input to the proper resolution or input style to see a picture. The dvd outputs a 1080i and if the TV is set to 720p it may not show a picture, the dvd output can also be changed to match the TV.
Sep 06, 2009 | Samsung BD-P2500 Blu-Ray Player
I can't get a picture on tv when turn on dvd player why? brand new, never used before.
have you connected the DVD into the right plugs, also are you using the correct AV channel on the TV?
RED WHITE YELLOW yellow is video red is L sound White is r sound. check both TV input and DVD output
Aug 14, 2009 | RCA DRC8335
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
Will play sound but no picture
1.check your video cable between DVD and TV.
2.in back of dvd one yellow socket only for video out others for some other purpose.
3.open tray conditon .-go to system menu on Remote -go to general set up page-video set up -and switch of .progressive -in OFF-mode.
then try it for video play back
4 if not ok replace the video decoder ic.
Nov 12, 2008 | Philips DVP642 DVD Player
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
Component cables not working properly
Make sure to set the "TV Output Select" in the DVR4200's menu to "Component" not "S-Video". **** Page 19 of the manual.
Jan 09, 2008 | GoVideo DVR4200 DVD Player/VCR
Picture but with blue screen
YOUR CABLES TO THE TV ARE NOT HOOKED PROPERLY OR DAMAGED
Dec 02, 2007 | JVC XV-N55 DVD Player
Vizio VX37L Television Logo
16 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
