Question about Dell Inspiron 1501 Laptop
I have a dell inspiron 1501 which I turn on and can not get to the menu screen to get on the internet only a blue screen and cursor appearers. please give me a solution to this problem
    New Friend:
  • 10 Answers
Sounds like you don't have an operating system properly installed.
Posted on Jan 05, 2013
jeff_olymp24
  • 84 Answers
SOURCE: dell 1501 inspiron laptop blank screen
Have you installed any application/program prior to the blue screen? Most blue screen causes your system not to boot to your operating system anymore. It is possible that your hard drive is crashed due to a virus infections or spywares. Incompatibility and corrupted system registry may affect your system to have blue screen as well.
You may try the following steps below.
1. Restart your computer. After you pressed the power button to restart. Keep on tapping F8 key on the keyboard on and off.
2. Boot advanced option will show up on the screen. You may boot your computer to the following option.
a. Last known good configuration
b. Safe mode with Networking.
If Safe mode w/networking works, restore your computer to an earlier using the system restore features.
Keep me posted.
Regards,
jeff
Posted on Oct 18, 2008
  • 3940 Answers
SOURCE: dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Posted on Feb 01, 2009
  • 7 Answers
SOURCE: dell inspiron 1501 push power button no screen or sounds
Have you hooked it up to an external monitor? If you can see windows booting up on the external monitor then u may have a bad lcd screen or inverter or video card? Still lots of questions to ask.
Posted on Apr 11, 2009
Bat1956
  • 585 Answers
SOURCE: can't turn off and on laptop DELL Inspiron 1525
Your last shutdown may have failed to execute correctly, corrupting the boot sector of the hard drive. You could attempt to start up in safe mode (F-8 at boot). If that fails try using a bootable CD such as came with your anti-virus application. That may also provide some helpful recovery utilities allowing you to restore the boot sector. You may need to use F-12 to make the computer boot from the CD.
Posted on May 17, 2009
Geekman
  • 32281 Answers
SOURCE: Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 21, 2009
Dont startup
1 Turn on the computer.
2 As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Dec 14, 2013 | Dell Inspiron 1501 Notebook
When i try to reboot my dell inspiron 1501 to factory settings after i press F8 and click "repair computer" it just starts normally and goes to my desktop.
To restore your Dell computer to it's original factory settings, here's how:
To use PC Restore:
  1. Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
  1. Immediately upon seeing the blue bar, press .
If you do not press in time, let the computer finish starting, and then restart the computer again.
notice.gif NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
  1. On the next screen that appears, click Restore.
  2. On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
  1. When prompted, click Finish to reboot the computer.
note.gif NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
  1. When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the computer was turned on.
  1. Click Next.
The System Restore screen appears and the computer restarts.
After the computer restarts, click OK.
Thanks and have a good one.
Oliver
Jul 28, 2011 | Dell Inspiron 1501 Notebook
Dell inspiron 2650 frozen on blue welcome page
try this...
turn on the laptop,,,
keep pressing F8
a menu screen will appear,, select SAFE MODE using the cursor keys and hit enter,,
once it boots in safe mode click no to use system restore..
follow the onscreen instructions to send it back to a date when it did work,,
it will shut it self down and restart in a propper manner..
if that fails,,
when u turn on the laptop it displays a menu,, it shows to press a certin key to enter system recovery,, press that key,,
follow the onscreen instructions to restor the laptop to factory condition..
Jun 03, 2010 | Dell Inspiron 2650 Notebook
Blue screen
if its a blue screen without error message or any text, operating system cannot load properly. do a repair on operating system.
May 15, 2010 | Dell Inspiron 1501 Notebook
MY INSPIRON 1501 LAPTOP WONT TURN ON. ITS STARTS
Please follow these instruction to predict the possible errors,
Upon powering on the laptop, press and release many time the F8 button of your laptop until this window appear... Select the highligted in yellow... Post the error codes you can see on your screen for the next troubleshooting tip...
Oct 21, 2009 | Dell Inspiron 1501 Notebook
Insperion 1501 boots up only to blue screen,
your os is corrupt so repair the operating system or reload it
Feb 20, 2009 | Dell Inspiron 1501 Notebook
Black screen
It seems your Operating system has corrupted, Its best to use Windows Installation CD to perform Recovery Installation. You can Use the DELL Disk. Before proceed Make sure you have your backup. If you need some advanced access to files you can use UBCD.
Good Luck
Jun 19, 2008 | Dell InspironTM 1501 Notebook
Wont turn on properly
Press the F8 key about 7 times slowly when you see the DELL logo screen after the restart.
Select the option Repair my computer.
The start up and repair window would come up follow the wizard . It should fix the issue .
If it does not , it would give you more options to try repair the system. Try system restore from the options.
If none of the above steps work , it time to reset your computer to factory settings. A corrupt vedio driver update, is the cause of this problem
Thanks
Mandeep
Jun 02, 2008 | Dell Inspiron 1501 Notebook
Black screen
you restore the pc back when it was working fine,you can do in safe mode
May 30, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Laptop Logo
37 people viewed this question
Alun Cox
