Question about Pioneer HTP-071 5.1 3D Home Theater System - 600 W RMS - Dolby Pro Logic II, Dolby Digital, Dolby Pro Logic IIx, Dolby TrueHD, Dolby Digital Plus, DTS, DTS 96/24, DTS Express, DTS-ES, DTS Neo:6, DTS-HD Master Audio, DTS-HD High Resolution - HDMI
What connections need to be made for pioneer htp-071 to an HD tv and Direct tv?
I am having trouble getting my pioneeer htp 071 to my connected TV and Direct TV. In the instructions it is difficult to understand exactly what cable connections I need make.
  • 93 Answers
SOURCE: Subwoofer
I suppose that your system requires an active subwoofer, and that you provide one. Some systems, if SPEAKER SIZE in SETUP are set to LARGE for front or center speakers, do not send signal to sub, system redirect signal to front or center speaker. Try to check this.
Posted on Oct 08, 2007
SOURCE: Pioneer HTP-100-SW
i just installed my htp 100 sw. the scheme was atached to the back of the woofer for me tho. easy. front speakers go into the sub in the two botom inputs from the receiver. the two upper are outputs to the actual speakers. hope it helps
Posted on Sep 22, 2008
SOURCE: no sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
Posted on Jan 03, 2009
MNfisherman
  • 11896 Answers
SOURCE: connecting my comcast hd cable to my pioneer elite hd 1130
you will need the other cables. Hd tv won't work with the old school hookups. rca jacks' can sort out those frequencies
Posted on Jan 28, 2009
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Posted on Feb 18, 2009
How do i fix my remote to work my home theater. i have a htp-071 and my remote stopped working. the battries are brand new. I went away for the weekend and came home, remote didnt work. please help.
Test remote for operation. Problem is with either the remote or the receiver in the home theater.
Clean all battery contacts and install new, tested, working batteries in remote. Turn on am radio and tune AM dial to about 600 - turn up volume. Then bring remote to about one inch from radio and hit button on remote. You should hear a beep as long as you hold the button down. Every button will respond likewise. If nada at all remote is trashed, if works with some buttons then you have a partially operating remote. Try cleaning contacts for buttons that do not work or use some aluminum foil under those non working contacts.
Nov 22, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
How do I get audio from tv to receiver?
There should be audio output's on your TV and cable box. There are usually multiple options on most newer model a/v equipment. If u check the manual look for the page showing you about the various connections on the back, you're lookin for anything to do with audio output, there are many different types optical, digital, and analog. Again depending on your specific equipment there's almost always at least one way you can connect them
Feb 15, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
Install Pioneer surround sound
easy look at the back and treat the holes like a tap water comes out the tap into the drain treat the drain like your amp so what I'm saying connect you tv etc to the inputs of the amp and most people don't need to worry about the out puts on the amp and from the tv or dvd player you need to connect the cable from the out put to the input on the amp :)
Jan 30, 2014 | Pioneer Dolby Digital 5.1, Pro Logic II...
How to hook up direct tv box,samsung hd tv,pioneer vsx-820 receiver,samsung blue ray bd-c5500
If you're using HDMI cables, which I suggest you do, this is how you set it up.
From the TV, you'll connect an HDMI cable to your receiver.
Connect the blu-ray player to your receiver.
There's a small amount of setup required with the receiver, but it's self explanatory.
Mar 12, 2011 | Pioneer Televison & Video
How do i connect my Pioneer DV-250 to my Vizio 32 flat screen and Direct TV Black box???
hi there, is you tv black box hd? if this is hi-def you should have red/blue/green cable in/out to & from tv to box....dvd is out jacks to tv digital in..in order to watch the dvd using remote tune to source tv/av1/av2/cable more
feel free to rate the help
Jul 10, 2010 | Pioneer DV-250
Direct TV satellite to TV connection issue
hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
shaun
Jun 13, 2017 | Toshiba Televison & Video
My subwoofer stop working
I have a Sony 46" LCD TV. I have a Direct TV HD converter box, a Sony Blu-Ray BDP-S360 Blu-Ray player, and a Pioneer DVD-Audio player connected to my Pioneer Elite Home Theater receiver. I have my Pioneer DVD-A player connected via Fiber-Optic cable. When i play a DVD or a DVD-A on my Pioneer DVD-A player, all of my speakers work fine, but when i play a dvd on my blu-ray player, all the speakers work except my subwoofer. How can I fix this problem?
Jul 03, 2009 | Aspire Digital AD-225PSC Subwoofer
No Video
have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Aug 24, 2007 | Pioneer VSX-1016 Receiver
Pioneer HTP-071 5.1 3D Home Theater System - 600 W RMS - Dolby Pro Logic II, Dolby Digital, Dolby Pro Logic IIx, Dolby TrueHD, Dolby Digital Plus, DTS, DTS 96/24, DTS Express, DTS-ES, DTS Neo:6, DTS-HD Master Audio, DTS-HD High Resolution - HDMI Logo
175 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
